Question about Canon imageRUNNER C6800 Copier
Ir c6800 error code 070sub code 101 please solve the problem
  • 168 Answers
Transfer belt either broke or not turning
Posted on Jan 16, 2009
Canon iR 6001 showed me error code of e000005-0000 what can i do to solve the problem
The error code E000005-0000 means that you need to replace the upper cleaning web for the upper fixing roller. When you pull the transfer unit out and you see the fixing unit with the yellow cover on it. The web is under the cover. It needs to be replaced to solve the problem.. Good Luck
Sep 17, 2012 | Canon imageRUNNER C6800 Copier
Canon IR c6800 gives me error code E000014 - 0001
This code means that the fixing motor can't get enough power due to the fixing roller is not smooth anymore, You will have to replace the fixing roller.
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
Please help e0020-00ff black toner supply????? comes and goes
Check for blockage in toner supply ,located at rear of hopper. Also is the toner ok
Jun 26, 2010 | Canon imageRUNNER C6800 Copier
Canon IR C6800 Error 00003-0042
According to Canon, this code is being thrown most likely because the fixer (fuser on Xerox copiers) is not seating properly inside the frame. Vibration coming from the copier operating is most likely jarring the wiring connector, making it work loose and causing the computer to throw this error code. There is a fix for this but unless you are a certified Canon Copier technician, it is highly recommended you contact Canon to send a tech to fix it. I hope this helps you.
Oct 07, 2009 | Canon imageRUNNER C6800 Copier
HAVE CANON IR C6800 WITH THE FOLLOWING ERROR CODE... E000001-00ff
moz-screenshot.jpgmoz-screenshot-1.jpgIt is a Fuser error code .
Could be a poor connection with the draw connector on fixing feeder unit.
Try shimming all three connectors on the fuser draw side can resolve the issue. Another thing to check is the upper fuser roller for flat spots this can also cause fuser error codes
May 07, 2009 | Canon imageRUNNER C6800 Copier
Canon ir 2018 ERROR CODE E246
check print controller pcb connection, ram & EEPROM
Feb 26, 2009 | Canon iR 2016i Black and White Copier
CANON IR C6800 ERROR CODE ( E000602-0202)
A E000602-0202 code is a problem with the hard drive booting up. Did you try to reseat the boot rom? You can try a F-disk funcation and they to re install the software from your lap top..You can also try to reseat the HD connections. But, I would say that you HD has crashed and it will need tob replaced. Good Luck
Mar 26, 2008 | Canon imageRUNNER C6800 Copier
Canon imageRUNNER C6800 Copier Logo
161 people viewed this question
old marine
old marine
