Question about HP Compaq Presario V6000T Notebook
My computer hangs up when i try to copy something from one location to other in my PC.also i cannot open my registry editor or task manager.when i try i get the message that they are disabled by administrator.i did scan my PC but found no viruses.
    Guru:
  • HP Master
  • 829 Answers
Hi , Remove the network cable and boot the system login as an local administrator and go to the task manager check if any service is eating more RAM . End the task and go to run and type msconfig and enter.go to services and disable all and then coneect the network cable to PC and reboot. Check if you are able to copy or can edit the registry , If every instance is fine then type msconfig in run and enable what services is required .
Posted on Jan 14, 2009
I want remove geniune from my desktob
Microsoft has created an application that checks your Windows operating system to see if the copy of Windows you are using is genuine. If it is not, the application launches a "Genuine Microsoft Software Notification" pop-up alerting you that "This copy of Windows is not genuine." This has a purpose. However, many users have reported being flooded with the pop-up notification even when the copy of Windows they are using is genuine. If this happens to you, you can remove the genuine Microsoft software notification. Note that the instructions below apply to the Windows 7 operating system.
Press "Ctrl"+"Alt"+"Delete." Click on "Start Task Manager." The Windows Task Manager opens. Click on the "Processes" tab. Click on "wgatray.exe" and then click "End Process." Restart your computer. Press F8 continually while your computer is booting. The Advanced Boot Options menu will appear. Click on "Safe Mode" in the Advanced Boot Options menu. Click on the "Start" menu and then click on the "Search Programs and Files" box. Search for and delete the following files: (To delete a file, right-click on the file and select "Delete.") "C:\Windows\System32\WgaTray.exe"
"C:\Windows\System32\dllcache\WgaTray.exe" Click on the "Start" menu and type "regedit" into the "Search Programs and Files" box and press "Enter." The Windows Registry Editor opens. Locate the following registry entry in the Windows Registry Editor and delete it. To delete a registry entry, right-click on it and select "Delete." "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\WgaLogon"
b>
Mar 03, 2013 | Microsoft Office Professional 2007 Full...
Can't see the system tray on the desktop
Here's the solution:
1. Ctrl + Alt + Del to bring up Task Manager.
2. Click "New Task..." then click "Browse..."
3. Click My Computer on the left panel. Click C:\ - WINDOWS.
4. Navigate to explorer.exe, right click and copy explorer. Rename it to explorer1 (.exe)
5. Hit Cancel to go back to Create New Task window. Type regedit.exe and click OK.
6. In the registry editor, navigate to the following Key.
With the Winlogon key selected, look in the right side window for the
'Shell" value.
Double click Shell. In the Value Data box, you should see Explorer.exe. Change it to
explorer1.exe and click OK.
Exit the registry editor and reboot the computer.
Nov 06, 2011 | Acer Aspire One PC Notebook
How to activate task manager on my pc
It can be done easily by editing the registry. I will try to explain in detail. Follow these steps
1. Check that your PC is virus free. Install Antivirus program if required.
2. Regisry is enabled. Goto run command from start menu OR Press Win key+R and type 'regedit'. It would show up registry.
3. If registry is enabled you can edit it.
4. Open notepad and paste the following four lines
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
"DisableRegistryTools"=dword:00000000
5. TYPE the file name ENABLETASKMANAGER.REG
6. Choose 'all files' option from 'Save as type'
7. Now you should have a registry editing patch. Please note that its extension is .reg
8. Double click the patch to add it to registry and task manager would be enabled.
9. Alternatively, you can download PROCESS EXPLORER, whichis a replacement of task manager from internet. It works even if the taskmanager is disabled.
Hope this helps. Let me know if you need any further clarification/ help
CreativeTECH
Nov 12, 2010 | Computers & Internet
Fuvirus!!!!! help me provide me with the simplest solution pls.
Since FUvirus is visible in the processes tab of the Task Manager, this can be deleted or disabled manually.
First of, open the Task Manager by right-clicking the TaskBar, click "Processes" tab on the task manager and locate "FUvirus.exe" from the processes lists. Make sure that "Show all Processes from all users" is selected. Once FUvirus.exe is located, right-click and then "End Process Tree" and close the Task Manager.
Now delete the FUvirus from the Registry, follow the instructions:
Open the Windows Registry Editor by clicking on the Windows "Start" button and selecting "Run." Type "regedit" into the box and click "OK." Once the Registry Editor is open, search for the registry key "HKEY_LOCAL_MACHINE\Software\FUvirus.exe." Right-click this registry key and select "Delete".
You also need to search the similar file on your computer, this generally happens, this virus replicates and creates several similar files with the similar name randomnly. Search for "FUvirus.exe" and delete whatever you find with that name. Once you are done, restart your computer and check whether it's gone or not. I would also recommend you to run full virus scan, there are several free antivirus which could easily detect and repair FUvirus like, Avira free, Avg free, Avast free, etc... you can download them from their respective websites.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Note: Don't ever install Multiple Antivirus on a system, this may cause system instability or even system failure.
Oct 21, 2010 | Microsoft Computers & Internet
My task manager doesn't work anymore can u help me fix this?
Try this:
If Task Manager has been disabled, you can re-enable it if you have administrator privileges on the computer.
To enable Task Manager on a computer running Windows Vista Home Basic or Windows Vista Home Premium This procedure requires you to edit the registry. An incorrect change to your computer's registry could render your computer inoperable. We strongly recommend that you back up the registry before making any changes. For more information, see Back up the registry.
  1. Open the Registry Editor by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, typing regedit into the Search box, and then pressing ENTER. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. Navigate to the following location: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies
  3. Double-click System, double-click DisableTaskMgr, change Value data to 0, and then click OK.
To enable task Manager on a computer running other editions of Windows Vista
  1. Click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, type gpedit.msc in the search box, and then press ENTER.
  2. Under User Configuration, double-click Administrative Templates.
  3. Double-click System, and then click Crtl+Alt+Del Options.
  4. Double-click Remove Task Manager, click Disabled, and then click OK.
or you're computer might be infected by a virus, if you're not the one who disabled the task manager.
Try to scan your computer also.
May 08, 2010 | Microsoft Windows XP Home Edition
My task manager has been disabled due to virus attack. help me
There is a registry hack to enable or disable Windows NT TaskManager. The same registry hack applies to Windows 2000 and Windows XP. Hive: HKEY_CURRENT_USER
Key: Software\Microsoft\Windows\CurrentVersion\Policies\System
Type: REG_DWORD
Value: 1=Enablethis key, that is DISABLE TaskManager
Value: 0=Disablethis key, that is Don't Disable, Enable TaskManager
As part of the enhanced management available in Windows 2000 and Windows XP, rather than risking a registry change, as an administrator you can enable or disable Windows 2000 Pro or Windows XP Pro's TaskManager using Group Policy Editor. This can be applied to the local policy. Note: if you are trying to override your organizations group policy, you can't. As soon as you re-authenticate to the domain, the domain or OU Group Policy will rewrite the registry setting. But if the TaskManager was accidently disabled or you need to control this item for a set of standalone boxes this is for you:
  • Click Start
  • Click Run
  • Enter gpedit.msc in the Open box and click OK
  • In the Group Policy settings window
    • Select User Configuration
    • Select Administrative Templates
    • Select System
    • Select Ctrl+Alt+Delete options
    • Select Remove Task Manager
    • Double-click the Remove Task Manager option
And as I mentioned above, since the policy is Remove Task Manager, by disabling the policy, you are enabling the Task Manager.
Mar 23, 2009 | Internet Grisoft AVG Security Full...
Registry editor,task manager not opening
Hi, Yes, you are right !, your system is infected with a serious virus and you cannot use your computer unless you remove the visus.
This problem happens when there is no updated antivirus running.
To fix it, download/ aquire MacAfee antivirus and its latest update.
Boot the system to safe mode, and install the macAfee and update. Run the scanner and remove the virus.
Try and let me know if its not succeeded.
thank you
Aug 16, 2008 | Microsoft Windows XP Professional for PC
Registry Editor, Task manager, Command Prompt Disabled
hi, your computer is attacked by virus .install some antivirus and scan the system to resolve this problem .
Dec 17, 2007 | Microsoft Windows XP Home Edition
HP Compaq Presario V6000T Notebook Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
