1998 Buick LeSabre Logo
Anonymous Posted on Dec 14, 2012
98 buick heater stop working - 1998 Buick LeSabre
  • Anonymous Dec 14, 2012
    help heater stop working
  • Jonah Oneal Dec 14, 2012
    first check heater blower motor HVAC 25 AMP FUSE.IF FUSE OKAY.REMOVE HEATER BLOWER MOTOR HOT WIRE SEE IF BLOWER MOTOR WORKS IF NOT BLOWER MOTOR BAD IF BLOWER MOTOR WORKS WHEN HOT WIRED PROBLEM IN THE CONTROL MODULE SWITCH..IF YOU HAVE BAD BLOWER RESISTOR ONLY HAVE ONE BLOWER SPEED. MEANT TO SAY ALSO CHECK AC BLOWER MOTOR RELAY. IT COULD BE BAD.
raj somaiya
Level 3:
  • Buick Master 5,370 Answers
  • Posted on Dec 14, 2012
raj somaiya
Buick Master
Level 3:
Answers
5370
Questions
0
Helped
3570338
Points
14579
Its faulty blower motor resistor. The low and medium speed on blower motor is controlled by resistor and its actual speed is high. So because resistor is not working, blower motors actual speed which is high is working.
It can be faulty blower motor or faulty blower motor resistor. Get the blower motor inspected. If it's faulty it has to be replaced.
For blower motor testing and replacing, check the link below: ----
Blower motor Testing/replacing for all vehicles?
http://repairhelpcenter.blogspot.in/2012/02/blower-motor-replacing-for-all-vehicles.html
These will help.
Thanks.
98 buick century turns over wont start
Rose, Can you hear the fuel pump 'buzz' for a few seconds when you turn the key to the 'on' position? Is so. and I know this sounds crazy, but try turning your heater fan switch all the way to the high position and then try cranking it. Another Buick Century owner told about this in another forum and it works for him and others. Apparently there is a fault in the computer and the electrical current draw from the heater fan has a positive effect on it. It's worth a try. If this works for you please post on this site so that others may benefit. Thanks
I have a 2001 buick regal and my heater has stopped working
So your control is not good it dont turn the vents to you
98 Park Avenue Instrument Cluster Stopped working
Always check your fuses first to see if they are blown.
2answers
Imy 98 buick is overheating the water comes out from the pasenger side inside da car..right under the glove box
That is where your Heater core is located. Its like a little radiater that your vents blow thru to get hot air for heating your interior. If thats leaking, its not gunna stop. Take this car in right away before you run your coolent dry and trash your car.
1helpful
2answers
My 98 Buick Le Sabre heater blower works sometimes and sometimes it doesn't. You just never know.
Sounds like a bad heater control switch OR bad connector to the motor itself. I'd try your local salvage yard or EBAY for a replacement switch. Good Luck. . .
I have a 98 buick lesabre. I am a woman and have no clue whats wrong with it and cannot get straight to the point answers of what is wrong with it. When i drive it, it gets hot, my windshield fogs up,...
your heater core is leaking. It is allowing engine coolant to enter the passenger compartment via the air conditioner / heater ductwork. A cheap temporary fix is to purchase a radiator stop leak product and have someone put it in your radiator. Follow directions carefully, as the coolant can be very, very hot and under pressure. The correct repair can be quite expensive. In warmer climates you can bypass the heater core and run without a heater.
Need to know the location of the heater core on my 98 buick century
Well the heater core is located under the dash on the passenger side, usually cased in a plastic housing.You may have to remove the glove box in order to have access to. Post comments for further help or information........
Good Luck!!
Thanks for using FixYa!!
Heater stopped blowing on 98 Buick Century. Digital display stopped working a long time ago but the Goodyear shop didn't have a clue. Can't afford to take it to a dealer and need help figuring out what it...
See if the blower motor will run with a wire ran to it from a 12 volt supply from the vehicle.If so the blower relay needs to be checked to see if it is the problem,if it checks out,replace the control head,the part that does not light up anymore.If the motor does not work with 12 volts ran to it,replace the blower motor.
Heater fan stopped on 2000 buick regal
Check Blower resistor.Most liey culprit.
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
