Question about Go Software Inc. PCCharge Payment Server (100PROL2000SER)
Trouble setting up PC Charge on wireless network
Cannot get PC Charge to identify/verify the cable modem used at the end of the wireless network to transmit to the bank. I just purchased a computer (same operating system as the old one which worked) but now cannot get the system to find the modem. Any advice?
  • lnaioti Jan 14, 2009
    The reason I came here was that the help desk wants me to spend $150 for a year of service to ask this simple question
    Master:
  • 404 Answers
Call the PC Charge help desk
Posted on Jan 14, 2009
    Problem Solver:
  • 19 Answers
PCCharge wouldn't recognize a cable modem, nor would it need to. If you're running a cable modem, then you should disable modem connections and run via TCP/IP. Depending on which version of PCC you have, and which processor you are using, there should be support for TCP. (Vital and Nova have been on TCP since versions 3 and 4). Some processors (although few at this point) do not yet support TCP connections. If you have one of these processors, then you would still need to use a standard dial-up modem (preferably with hardware control capable of maintaining a 1200 baud connection) or switch processors to one that support IP. All of the modem settings are under Setup -> Modem. This is where you can disable the modem settings for IP. Keep in mind that some processors require extra information and setup to use IP, for example, the First Data platforms need a Datawire ID, which is setup through Datawire (who only speaks to Merchant Service Providers), Paymentech requires a setup for Netconnect which requires a user name and password, and can be requested by a Paymentech account manager. I list of supported TCP processors can be found at http://www.verifone.com/PDF/PCChargeCertMatrix.pdf. Reviewing this should let you know if you need to take any additional steps to use TCP/IP for processing.
Posted on Sep 28, 2009
Station asking to register
Are you running this station wirelessly? Last I checked, pcAmerica does not recommend using wireless workstations. Correct your wireless problem. This is not related to RPE. Or run a temporary line to workstation. Verify you are connected to your network and re-register RPE.
sysadmin@ccybernet.com
Feel free to email me with more details if need be.
Mar 30, 2014 | Pc America Restaurant Pro Express
How do I recover a forgotten password for an overdrivepro63E wireless internet stick
Wireless networking is a common feature in homes and offices.
Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network.
If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu.
Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable.
Open your Web browser. Enter the default address of your router.
The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1."
Enter your username and password.
Many routers use "admin" for the username and password by default.
Locate the wireless security settings.
Disable the wireless security.
Reset to Factory Defaults
Locate the reset button on your router.
Typically the reset button is a small indented hole on the back of the device.
Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings.
Locate the wireless security settings and add security as necessary.
Nov 05, 2013 | Computers & Internet
No network coverage
Set IP Address Configuration
Click the "Start" button and select the "Control Panel" from the right column to open it.
Select the "Network and Internet" section of the Control Panel.
Click "Network Connections" if using Windows XP to view the available network icons.
Or, click "Network and Sharing Center" if using Windows 7 or Vista and select "Change adapter settings."
Right-click your network connection icon which displays either the yellow triangle or red "x" indicating limited or no connectivity.
Select "Properties."
Click on "TCP/IP" to select and highlight it. Click "Properties."
Select both the "Obtain IP address automatically" and "Obtain DNS server address automatically" radio buttons.
Click "OK" and then "Close" in the Network Connection Properties box. Close the Control Panel.
Manually Renew IP Address
Click the "Start" button and choose "Run" from the list.
Type "cmd" in the "Run" box and press "Enter" to open the Windows Command Prompt.
Type "ipconfig /release" in the Windows Command Prompt and press "Enter."
This releases the current IP address of your computer.
Type "ipconfig /renew" and press "Enter" to obtain a fresh IP address.
When renewing your IP address, Windows automatically attempts to connect to the network.
Powercycle Router and Modem
Turn off your computer.
Unplug both the Internet modem and wireless router's power adapter from the electrical outlet. Wait for two minutes.
Plug the Internet modem into the electrical outlet first. Wait for connectivity lights to appear.
Plug the wireless router's power adapter back into the electrical outlet.
Confirm that lights appear on the router indicating that it has established a connection to the modem.
Turn on your computer.
Open "Network Connections" if your computer does not connect automatically to the network.
Select a network from the list, input the network password if one exists and click "Connect."
Open your Internet browser to test the connection.
Update Network Interface Card (NIC) Drivers
Click the "Start" button. Right-click "My Computer" or "Computer" from the Start Menu. Select "Manage." Click "Yes" if a user account control message appears.
Click on "Device Manager" from the list of System Tools.
Find the "Network adapters" listing and click the "arrow" or "plus" symbol to expand it.
Right-click your computer's network adapter from the list and select "Properties."
Click the "Driver" tab and select "Update Driver."
Follow the on-screen prompts to allow Windows to find and install the drivers automatically. Restart the computer when the process is finished and attempt to re-connect to the network.
Reset Internet Protocol (TCP/IP)
Click the "Start" button and select "Run."
Type "cmd" and press "Enter" to open the Command Prompt.
Type the following line into the Command Prompt and press "Enter":
netsh int ip reset resetlog.txt
Close the Command Prompt. Issuing this command tells Windows to remove and then re-install the two registry keys used by the Internet Protocol (TCP/IP) component of Windows.
Restart the computer.
Attempt to connect to the network if a connection is not established automatically.
Sep 06, 2013 | Computers & Internet
I'm having trouble connecting my laptop. I see my secured wireless network and when I try to connect to it, It tells me that it is limited or no connectivity. How can I connect to it?
Hi
Its not letting you connect due your laptop not having or having the wrong wireless password. You need to log on the your wireless router, double check what its set to. then go into your wireless config on your laptop and set it there. If you can let me know what copy of windows you are running i.e xp, vista, 7 etc and what router you are running then I will be able to give you a more detailed guild.
Mar 15, 2010 | Computers & Internet
Trouble verifying my copy of office
I think it is not the problem with the type of browser you are using. You can use any type of browser, once check whether the internet connection is working better or not.
Oct 28, 2009 | Microsoft Office Standard for PC
Network & Telephone Cabling.
Typical telephone cable is 2 pair (4 wires) while ethernet CAT5+ is 4 pair (8wires). While physically you can cut the end off and attach it to an RJ45 jack, you'd have 4 slots without wires. I can't imagine an application for it.
Apr 03, 2009 | Microsoft Office 2000 Professional for PC
Need to reset mcafee wireless home network
You have to delete the existing network and start the setting up of new network.
Jan 29, 2009 | Network Associates McAfee Wireless Home...
I can not use the Gprs by china mobile
HI,
download the pc suit from the net for your chin mobile, or search for the modem driver files in the net, and install the modem. then contact the airtel by sending 'gp' to 750, they will guide you to activate the gprs.
thank you
Nov 11, 2008 | Handmark Software MobileLists (950142) for...
ETHERNET Problem
hmmm so you have a wired router? or you are plugging your laptop directly into your cable/dsl modem and when it doesnt work you are trying the desktop which does work?
If this is the case are you powercycling the modem (unplug power to modem wait 30 seconds and plug it back in...btw if you are using a mta or the modem has a backup battery you will want to find and press the reset button) when you switch devices? (make sure you have the laptop conected before you powercyle)
The folowing directions are if you are using a microsoft operating system:
Does your laptop pull an ip?(if so what is it?) If not then go to start then run enter the command "cmd" then type "ipconfig /release" hit enter the command will reset your ip to 0.0.0.0 then type "ipconfig /renew" and press enter if it takes a while and does not pull a new ip address then you may have a nic card or protocol issue. You can resolve this by uninstalling the network card in add remove hardware and then restarting the laptop. The system will automatically remove and reinstal the tcp ip protocol and all that goes along with it.
BTW if you get a 192.x.x.x for an ip then i am sorry to say but you are plugging into something similar to a router and then another approach must be taken.
p.s. a wireless router is a good investment if you have more than one system in the home. And may be a easy work-around to a NIC(network interface card) issue.
Hope this helps Good luck!!!!
May 31, 2008 | Microsoft Office Professional 2007 Full...
Go Software Inc. PCCharge Payment Server (100PROL2000SER) Logo
310 people viewed this question
Top Go Software Inc. Computers & Internet Experts
Cosma Papouis
Cosma Papouis
Tony Isted
Level 1 Expert
Are you a Go Software Inc. Computer and Internet Expert? Answer questions, earn points and help others
