Question about Hotpoint WMA40 Front Load Washer
Spinning loudly, drum seems loud when washing
When my machine starts to spin it has become extremely loud this is causing me problems as i live in third floor flat. also when the drum turns when washing,and spinning it is loud and seems to be wobbly.
  • stevefox Jan 08, 2008
    when i start the washing machine the drum starts to spin, then shake quit violently
  • murgy1 May 17, 2008
    washer sounds loud when spinning why?
    New Friend:
  • 129 Answers
Bad bearings , if you have good habilty with your hands you can do it. couple of tools , order the parts , job done. let me know how much help do you need to perform the job or if you prefer call a tech , you now already know what its wrong with it thanks
Posted on Jun 13, 2007
During the spin cycle the washing machine becomes VERY noisy, sounds like its off-balance, but happens EVERY time, even with very small loads. The whole unit doesn't move when it happens, just extremely...
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Sep 16, 2010 | Frigidaire FEX831CS Top Load Stacked...
Extremely loud noise when spinning. Sounds like dry bearing
If you have loud noises on spin it is quite possibly bearings.
You may also find that the inner drum becomes loose and may contact and wear the outer drum..
Replacing the bearings and possibly the shaft going through them is quite a big job. Best left to an experienced tech..
Get quotes before getting the job done. Check new prices also...
Good luck....Nomess
Aug 03, 2010 | Washing Machines
When on a fast spin it is extremely loud, too loud...
Water in bearings causes rust, and rust in bearings creates noise...This is the most likely reason for the noisy spin....Check for any slop in inner drum....Bearings and seals and likely the shaft probably need to be replaced....Quite a big and complex job....Good luck....Nomess
May 18, 2010 | Washing Machines
Very loud rumbling noise during spinning
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Sep 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Knocking in washer
good luck.........
Mar 28, 2009 | Maytag Performa PAV3200
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Looks like the drum has droped
You will need to get the bearings replaced. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Sep 18, 2008 | Frigidaire ATF6000ES Front Load Washer
My wash spins SO loudly
hiya
sounds like your drum bearings are in need of replacing.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 19, 2008 | Washing Machines
How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA40 Front Load Washer Logo
338 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
