Question about Maytag MER5552BAW / MER5552BAQ / MER5552BAB Electric Kitchen Range
The digital clock seems to be set to 24 hr insted of 12 hr time
Could you tell me how to reset back to 12 hr maytag mer5552baw
    Problem Solver:
  • 18 Answers
No Problem here ya go
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
Posted on Jan 14, 2009
    President:
  • Maytag Master
  • 2,651 Answers
Clock
The clock can be set to display time in a 12-hour or 24-hour
format. The clock is set at the factory for the 12-hour format.
12 or 24 hour.
3. Set the time of day following the
directions below
How do I convert clock from 24 hr display to 12 hr display on my GE profile gas oven with digital display?
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
Oct 04, 2017 | GE Kitchen Ranges
Radio Shack atomic clock 63-1438. How do I set it for 12 hr. time rather than 24 hr.?
Some clocks of this type have a 12/24 selection switch on the back.
Dec 28, 2015 | Home
I have a Maytag electric oven model MER5552BAW. Bottom bake element blew out. I replaced the element & now oven will not heat at all. Going nuts!
Go to youtube and type in your model number and ask for repair videos:
https://www.youtube.com/results?search_query=troubleshoot+Maytag+electric+oven+model+MER5552BAW
Feb 20, 2015 | Maytag Kitchen Ranges
How do I reset my Dacor oven clock back to 12 hour not 24
if you have the manual it should tell you in it .
Feb 14, 2015 | Dacor Kitchen Ranges
Reset bar888a to 24-hour clock
If you have the manual, it tells you how to change time format. Also, careful reading of the manual will eliminate much of the confusion you are experiencing in setting up the device. Bear in mind that some functions can fail over time.
Apr 21, 2014 | Oregon Scientific BAR888A Wireless Weather...
Set time format from 12 hr to 24 hr for casio LA670W
Was this problem answered? If yes, can somebody tell me how. My Casio LA670W is in 24hr format and I want it back on 12hr format. My watch have 3 buttons only. Mode, Start-Stop and Timer
Nov 22, 2013 | Casio LA670W Digital Ladies Watch LA-670WA...
How to set the clock using 24 hr and 12 hr clock
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#oval
Add comment and describe timer in detail.
Usually if a timer offers choice between 24-hour clock with 1-thru-24 displaying for current time, vrs 12 hour am- 12 hour pm, then the choice is first thing you set before programming. The choice is made before setting current time, and usually this is accomplished with single button push that toggles between 12 and 24 on the display.
The product manual has specific steps.
Not every timer offers 12-24 choice.
Again, add comment and describe timer in detail, or attach photo for best available resources.
Gene
h
Aug 08, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
I have a blue hat toy co. time and space projection alarm clock. it says it is a 12/24 hr clock but we can only show military time. is there anyway to just show the 12 hr clock. it is confusing to my son....
We also purchased the same alarm clock and I accidentally figured out how to convert to 12 hour (AM/PM) format from 24 hour format. Once the time is set correctly, and you are out of the time set mode, you can press the UP key and it will toggle between the formats.
Dec 26, 2010 | Sharper Image Blue Hat Toy Company Kids...
I have a bell f20 bicycle program...i have been trying to set the time...can someone tell me how to set the time without erasing everything on the program...
Click on the right side of the red button until you reach the clock (after SCAN). Hold down the left side of the red button until you see "12 HR" click--choose "12 HR" or "24 HR" (24 HR is military time). Click on the right side of the button to select the hour and change with the left side to change the hour. Click the right side of the button to change the minutes. Finally, click the left side of the button to move away from the clock. Other settings are intact.
Nov 15, 2010 | Cycling
Coil burner stays on even when in the off position on my maytag range.
The switch control for the burner has gone bad.
If you can get me the model and serial numbers from the tag on the range and tell me which coil is having the trouble I can assist with repair part numbers and tell you how to repair if needed.
May 11, 2010 | Maytag MER5552BAW / MER5552BAQ /...
Maytag MER5552BAW / MER5552BAQ / MER5552BAB Electric Kitchen Range Logo
1,114 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
