Question about HP 6730B Notebook
The mute button is completely freezed on my PC
Since 2 days, when I pushed the mute button on my pc (Compaq Presario), I can't hear anything anymore. Can you help me?
(I have Vista)
  • 2 more comments
  • bea_letourne Jan 14, 2009
    Thank you... I tried but it didn't work. The light on the mute button seems freezed. However when I doubled clik the little speaker in the lower right corner it said it wasn't muted, so I clicked the mute button and then it said it was mute. I reclick on the button and I put some music, but no sound, and the light is still there.
    (I have a laptop)
    Thanks
    Thank you
    Once again, it didn't work. I mean, unfortunatly I think I don't have this speaker on my keyboard. =S
    It never happened before, maybe I locked something.
    my laptop is a Compac Presario C-500, and as I said, with Vista. Thanks
    Thank you. The computer is still muted...(the light on the mute button is still there and I can't hear anything....).
    Finally I think I'll go to Staples, (or somewhereelse), to ask an informatician to fix it. (I even tried to take out the battery and then put it back, restart the compu, but nothing again, the button is still light.)
    Thanks
    p.s: If someone can fix it, please, feel free to tell me! =D
    Master:
  • 413 Answers
Double click the little speaker in the lower right corner and unmute the speakers. if there is no speaker in the corner there will be a greater than button (<) and you should see the speaker
Posted on Jan 14, 2009
  • Dan rogers
    Dan rogers Jan 14, 2009
    look for a speaker with lines through it on your keyboard. press the Fn button and on mine it is F2
    Fn + F2
  • Dan rogers
    from what i can find you need to push the mute button you said is on your keyboard and if that does not work you can try to restart and push it again (if the computer is still muted) if it still does not work there is something wrong with the computer itself
Compaq Presario PC SR5710F starts up days trash can corrupt hard drive full cant do anything past ths
completely format the system , if you have 2 -3-4 drives , format the whoile system
Jun 12, 2010 | Computers & Internet
HP Compaq Presario V6101US Notebook PC' push the
There are several reasons why this could be happening. Below are a few diagnostic steps we can start off with to eliminate some possibilities. If there is anything you are not comfortable with doing yourself please consult a local repair technician.
  • Remove the battery from the system and try booting up the computer with only the power cord. The "1" in the diagram below is the battery, "2" is the battery release latch.
  • Try removing one of the memory modules (if there is more than one) from the system by following the below steps.
1. Flip the computer upside down. Remove power cord and battery and ensure the system is completely off.
2.Unscrew the compartment labeled "4" in the diagram below. This is where the battery is held, as well as the WiFi card and motherboard battery. DO NOT do anything to these other components as they are quite fragile.
3. If there is more than one memory module you should remove one. Replace the compartment cover and attempt to boot up with battery and power cord reattached. If nothing has changed try swapping out the memory with the one you just removed.
If still nothing happens, this is not the issue. Comment back and we will move further with your case.
Good Luck,
NOLA Tech
Jan 28, 2010 | Microsoft HP Compaq Presario V6101US...
Compaq c700 vista os frozen
that means your base system is working just fine but your other software is not.try to remember what type of software did u install b4 or on the first day u know your laptop frozen.....fyi, some system cannot work on vista..
May 12, 2009 | Compaq Presario 700 470024-192 Notebook
Pc to pc talk my voice heared very low(input voice low)
you need to install the smart audio driver 221 for your laptop the mute problem should be solved with that and should increase voice qty a little. I guess you are using Win XP
Jan 26, 2009 | Compaq Presario Notebook
Mute button freezes my computer
If its a laptop and it came with vista, its most likely XP isnt compatible witht the hardware do to that it was designed for VISTA.
Try going to the laptop companies website and searching for drivers for it that are XP instead of vista and install them.
You bassically downgraded the machine so XP doesnt know how to use your hardware till you install XP drivers for it.
Good Luck
Dec 01, 2008 | HP 6730B Notebook
Compaq presario sr2109 - beeping sound/wont turn on
Actually if you hear this intermittent sound every two seconds you must check out the RAM of you laptop. If you are a bit technical you can take out the ram cleans its contact with a fibre pencil. Re put it back and restart your pc, if it continues to beep just buy another brand new strip of ram.
If this solution is ok please give weight to my solution, thanks alot
Patrick
Nov 12, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Prescario v6000 mute buttons and sound button dont work
you have to install the driver
get you driver driver through hp site
Oct 04, 2008 | HP Compaq Presario V6000T Notebook
Mute button
Have you tried reinstalling the software that came with your presario? There should be some compaq software that came with that computer that would help those buttons function correctly try going out to Compaq's website and look under support for your model and see what you can download.
Jul 04, 2008 | Compaq Presario Notebook
Compaq wf 1907 monitor speakers--no sound
make sure they have not came unplugged from the computer also on many keyboards there is a mute button, make sure it has not accidentally got pressed
Jun 06, 2008 | Compaq Presario 5000 PC Desktop
HP 6730B Notebook Logo
373 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
