Question about Alpine iDA-X200 Car CD/ MP3 Player
Installing the Alpine IDA-X200
I got all wires connected and the ground on its just the last few wires that shout go in the audio inputs like ( yellow/ white plug ins) but the wires on the deck are different like a purple/black or a grey /white
  • 81 Answers
So it is powering up? On your actual deck will be a picture of the schematics of the wiring. With the system powered up, assuming you taped up the power wires, strip the front left wires coming from the deck and use them as your tester. You now know forsure they are for the front left so as you go through your cars audio wires you will find which wires are for which speakers around your car. Label them as you test them. Hope that helps.
Posted on Jan 14, 2009
96 Marquis LS Poor am radio reception
Do you have the BLUE power antenna wire hooked up?
If not it may help your issue
Jun 12, 2013 | Alpine Wire Harness Ida-x305 Ida-x303...
My ida x200 says intrrupt on screen, no controls
1) Press and hold Func/Setup for more than 2 seconds2) Using the Volume knob go to the sub function called General3) Then go to INT MUTE4) Then set it to OFF
This will sort your problem out hope this helps
Jun 30, 2011 | Alpine iDA-X200 Car CD/ MP3 Player
My alpine ida x200 keeps skipping during songs
All you can really do is use a CD Player cleaner *one that uses fluid* run it thru a couple times and try a disc again. Clean your CD's with liquid car polish an a microfibre towel, it works wonders for new and old CD's. If it still skips, It needs to be pulled for repair. They just replace the transport, usually runs between 100-150 depending on the service center. Hope this helps.
Aug 11, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
I need a manual
if i were you id go to or go to google and try to find the phone number for alpine
May 25, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Sat radio not working
It's a Bad SIRIUS Tuner. there have been lots. If it's in warranty, have it replaced. if not, you can still find that unit for around $50 from Crutchfield etc. Hope this helps.
May 22, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
I just had an alpine iDa-x200 interface unit installed in my car. It connected to my IPod fine the first day. Now it says "no usb device" I've checked the connections and they're fine. Why doesn't it...
Ive had the same problem with pioneer. I reset the unit and it worked once again but wasnt perfect. Id call Alpine cust. service tech to see about any "known" issues.
May 19, 2009 | Car Audio & Video
DC error message
tonite while driving on a bumpy road i had the dc error right after a big bump.
according to user manual,
one of your speakers connector got lose and is touching the metal body of the car giving a shortcut
-> check your speakers wiring
May 16, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
How do you install radio to account for usb port
ipod shows its connected but no audio comes out
Apr 18, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Good luck
Mar 21, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
No sound with USB and IPOD Apline IDA-X100
You connected your blue alpine wire (power antenna) to your blue wire (amplifier remote on) on the BMW harness adapter. You need to undo this, amputate your blue alpine wire (because your E36 has no power antenna) and connect the alpine blue wire with white stripe (remote power) to your blue wire on the harness adapter.
When you switch source from the radio, alpine is shutting off your amplifier through the connected power antenna wire. Since you're not listening to the radio anymore, it sees no reason why it should give it power.
Dec 27, 2008 | Alpine CDA-9851 CD Player
Alpine iDA-X200 Car CD/ MP3 Player Logo
451 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
