Question about HP w2207 Monitor
My W2207 monitor keeps going to sleep
Hi: My monitor suddenly stopped working when I moved the computer. It keeps giving me a prompt that the monitor is going to sleep. I checked the connections and all is fine...also the display comes on for a second and says no  input and then goes to sleep. Is there a way to manually re-set the monitor. Thanks
  • rudolph_psx Jan 29, 2009
    my monitor suddenly goes to sleep and doesnt wake up..
    i checked the connections but its ok..
    so i have to cut off the power source in order for me to use the PC again,
    because i cant shut it down properly.
    Guru:
  • HP Master
  • 829 Answers
Hi,First there is no signal from the PC . check if the display card has come out while moving the monitor, or just reinsert the display card in the PC , then boot the pc .
Posted on Jan 14, 2009
Hp w2207 monitor randomly goes to sleep randomly, using windows xp
First make sure all the cables are securely plugged in. By randomly, do you mean a set amount of time of inactivity? Try this. If that doesn't work, it may be time to replace your graphics card (or buy one) or time to buy a new monitor.
Good luck.
Mar 07, 2011 | HP w2207 Monitor
I have an HP w2207 flat screen monitor. I have to
I stoped the monitor from sleeping by going into the montitor's menu, management, then sleep. Turn on the never allow to sleep mode. We were having some of your mentioned issues with the icons and with the monitor not waking up. This fixed that. Now the computer will go to sleep and when started the monitor comes on instantly.
Mar 23, 2010 | HP Computers & Internet
I have the following message when I turn on the
If your VGA CARD is the ON BOARD type install one in the PCI slot.
Feb 05, 2010 | HP w2207 Monitor
Hp w2207 monitor says no input when computer is turned on, then says "monitor going to sleep". computer is brand new.
try a different monitor, if the display remains blank on a known good monitor, then it is your video card.
Dec 26, 2009 | HP w2207 Monitor
HP w2207 monitor keeps "going to sleep" then it will not come back on and says no input signal.
most times this is indicator of a video card problem, most times you try booting in to vga mode and see does it go to sleep. if it does not go to sleap you video driver is bad and needs to be reinstalled. if it does go to sleep it is usually video card issue. to boot in to vga mode turn ur pc off and once u press on to put it back on start pressing button F8 and advanced menu will come up and you have to choose boot in to vga mode. if this does not work same way go to safe mode with networking and reinstall video driver by going in to device manager.
Nov 27, 2009 | HP w2207 Monitor
My hp w2207 keeps going to sleep about every 30 misn or so while i am watching movies on it how do i stop this issue?
It is probably going to sleep because it's not getting any keyboard input.
You'll need to go to the control panel and the power options and tell it not to go to sleep or at least increase the time that it will remain idle before going to sleep.
Watching movies is not input, so it thinks you are not using it.
Nov 16, 2009 | HP w1907 LCD Monitor
I have a dell lattitude LS when i press the SLEEP button on my laptop iy does not sleeps
Sleep button may be disabled. Go to control panel and double click "POWER OPTIONS" find the control property that says "When i push the sleep button on my computer..." this should give you the idea.
OR keyboard drivers were not installed properly on your laptop. Go the the dell website and download the necessary drivers for your laptop keyboard to enable the buttons.
Hope this helps!
Mar 15, 2009 | HP w2207 Monitor
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
HP w2207 Monitor Logo
1,909 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
