It back fires through the intake while trying to start; help if you can please. checked timing marks on over head cam and they are correct.but harmonica balancer mark is not on the timing scale on the cover. its two and a half inches from timing marks on the plastic timing belt cover.its getting fuel and ignation spark.some compression.
SOURCE: dodge durango wont start
The important thing now is, Do you really have gas in it? Check the fuel rail pressure and get that taken of, then check all grounds pertaining to the gauge assembly in the tank, and the dash grounding...accordianman
SOURCE: 95 neon timing belt replacement???
Its at 11:57
If you need further help, reach me via phone at https://www.6ya.com/expert/louis_d357d39108b5f536
SOURCE: 97 dodge neon timing belt broke while going down
I do not have good news for you.
According to the Gates Timing Belt guide 2002 Edition, both engines offered in the Dodge Neon are interference engines.
This means that your engine has likely sustained sgnificant valve, cylinder head or even piston damage. Have you tested the compression?
It is probably least expensive to buy a used engine, change its timing belt and replace your engine with that one.
SOURCE: 92 Dodge Dynasty wont start no spark no fuel
If there is no spark, then there is no signal to crankshaft position sensor. If no power to fuel pump, check relay and power to it.
If you are not getting power to either of them.Then igniitn module or ECM is faulty.
SOURCE: replaced timing belt, but van will not start?
It is possible that this is a zero clearence engine. Meaning that the valves can hit the pistons if the cam timing is off or the timing belt breaks. I would strongly suspect that you have bent valves. This can easily be diagnosed with a compression test. If valves are bent the repair will require at least a rebuilt cylinder head and gaskets. It is also possible that there could be piston damage as well. The reason it is not starting is it has no compression due to bent valves.
