Question about Nokia 1112 Cellular Phone
Clicking sound I hear clicking sounds under my 1997 toyota corolla 1.6 gli car. They from the front and rear on the right side. Could it be loose ball joint? Help!
First clean the speaker pins ,if its still clicking,then you have to replace the speaker
Posted on Jan 22, 2009
Click click sound coming from left rear wheel when making a right turn
this is an indication of badly worn CV joints. Replace both because the other side will not be far behind it.
May 12, 2014 | 1999 Toyota Corolla
Clicking noise
take a visual look under the car if anything loose. Any lights coming on? ARE left and right signals ok- sometime they make clicking noise.
Nov 05, 2013 | 2006 Jeep Grand Cherokee
Turn signal light right flash
flasher/blinker is busted. this is located under your dash board. remove steering column cover, turn on LEFT turn signal (yes, the one that is working), then you will hear a clicking sound. locate the relay that causes the sound. there you can see 2 relays (one for LEFT, other one for RIGHT turn),replace busted one.
Jun 11, 2013 | 2002 Toyota Tundra
Belt diagram 1997 toyota corolla? alternator belt replacement?
The 97 Corolla has three accessory belts. The alternator belt is the one you see when you look down on the passenger side standing near the front of the engine compartment. If fits over the alternator and the engine pulley. The belt beneath it is the a/c belt (if the car has a/c). It fits over the engine pulley and the a/c compressor. The power steering belt is toward the rear of the engine compartment, on the same side. It fits around the engine pulley and the power steering pump.
Replacing the alternator belt is not too difficult. Standing in front of the car and facing towards the rear, loosen the locking bolt under the right side of the alternator. Then loosen the alternator hinge bolt on top of the alternator. Now you are ready to loosen the alternator belt tensioner adjustment bolt, accessed under the alternator from the front. Turn the tensioner until the old belt is loose enough to remove, then turn it further so that the new belt will go on easily. Replace the belt and re-tension until you have about 1/4 in. to 1/8 in. of play in the belt, tighten the lock bolt and the hinge bolt, and run the engine. If the belt squeals it means you need more tension, but do not overtension. Recheck it after a few days.
Mar 22, 2010 | 1997 Toyota Corolla
1998 Toyota Corolla Electric Door Lock Problem
You'll need to replace the solenoid (motor) that doesn't work. Not hard once you get the door panel off. I suggest you buy the correct part, not a universal one.
Jun 12, 2009 | 1998 Mitsubishi Eclipse
Clicking sounds
Clicking noises on turns may indicate that you have a broken constant velocity joint boot on the front axle. Check that and see if it is torn. It''s the black bellows-looking thing right behind the inner spindle. If it is torn, all of the grease has leaked out, and the clicking is the joint rattling.
Jan 14, 2009 | 1997 Toyota Corolla
Nokia 1112 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
