Question about Sony SLV-D251P DVD/CD Player w/Built-in Hi-Fi VCR CD Player
Cd door won't work
The cd side will not stay up. when you push the button on the cd player
it does nothing. the door just hangs open....
Thanks BB
  • 85 Answers
Is there a buzzing noise (motor running ) if so either drive belt failed,or has been put out of time in mech
Posted on Jan 15, 2009
I have a panasonic sa ak15 stereo system, the five cd trays have cds in them, i pressed the cd open button but cds don`t come out, the system screen says change, what could be the problem?
The door loader motor isn't working. Sometimes the plastic tray warps and hangs a bit. Mine still hangs, but I can give it a push to close. If you can see the door trying to open you can help it open but you have to be quick or you have to press the open button more that once.
Feb 24, 2015 | Panasonic Audio Players & Recorders
1998 Toyota Corolla CSI Seca. i was trying to replace the light on the roof. while doing this i noticed the CD player and door open indicators are not working. i have replaced the fuse for CD player.
iF YOU HAVE AN CAR ALARM TRY RESETTING, YOUR CAR ALARM RESET BUTTON AND SWITCH ARE NORMALLY DRIVERS SIDE AT THE LEFT KICK PANEL FLIP SWITCH THEN PUSH BUTTON UNTIL YOU HEAR A COUPLE CLICKS. I HOPE THIS IS HELPFUL.
Oct 21, 2014 | 1998 Toyota Corolla
Door locks won't lock/unlock
What kind of vehicle is it?
May 02, 2017 | 1999 Chevrolet Blazer
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Water dispenser doesn't work, side by side, model # GSS22JEPA BB
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Mar 04, 2010 | GE Refrigerators
On my Yamaha CDC-625, I can push the open/close button or the playxchange button, but the changer door will not open. It sounds like a motor is trying to open it, but nothing. Pushing the button again...
The most common problem is a slipping belt.
You have to open-up the player to check it.
If you're not familiar with it, then please don't.
It's not such a big problem, look for a local repairshop.
HNY, Gerard
Jan 01, 2010 | Vocopro CDG-8000 Professional Dual CD/CDG...
Cd tray not staying closed
gently push the cd door back in while pushing the door closed button , untill it closes if it still comes out then the cd laser mechanism is not lifting or something else has happened , then it will need to be tested to determine the exact cause
Oct 16, 2008 | Memorex MKS5001 Shelf System
Stuck cd discs
I think there are a couple of faults here. The first one is maybe a faulty motor on the eject mechanism. The second one is a faulty laser unit as it is not scanning the disc. Hope this helps.
Jul 25, 2008 | Sony RCD-W500C 5-Disc CD Recorder
Having a problem with my CD Player's drawer
This has to do with a mini switch inside the door mechanism that it pushes once but with the bounce phainomenon in electric pulses it thinks that you pushed the cd door inside manualy and it tries to close the door. Try replacing this mini switch. this will solve your problem.
Apr 15, 2007 | Denon DCD-425 CD Player
Sony SLV-D251P DVD/CD Player w/Built-in Hi-Fi VCR CD Player Logo
168 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
