Question about GE Profile JTP18 Electric Single Oven
We ran a cleaning cycle on the oven and the door will not open.
The lock signal is flashing and the fan is still running. I am unable to turn the oven off and the door is locked. What should I do?
  • rosey1017 Jan 20, 2009
    We ran a cleaning cycle on the oven and the door will not open. problem, and notify you when a new solution is offered.
    Having same problem.
  • Anonymous Feb 06, 2009
    Same problem.
Fixed itself
Posted on Jan 14, 2009
I have a ge profile oven model starts pt 916 when i broil food the "locked" light flashes, i usually keep the oven door open so i can watch the food after about 5 min the locked light goes off
The only thing spring to mind Mary is that you somehow selected a cleaning cycle which superheats the oven and turns burnt on fat and grease to charcoal. The cleaning cycle never finished and the stove remembers it. The light is flashing to remind you. When the cleaning cycle is in progress, the door locks until it is finished.
Either remove the wall power plug or flip the breaker and leave it overnight. It _should_ erase it from the memory. Or you have to compete the cleaning cycle as per the instruction book.
Sep 05, 2016 | GE Ovens
I locked the door on my GE rapid clean II and ran the cleaning cycle and now I cannot get the door to unlock. Any ideas?
Try to open it in a few hours or in the morning, I think it has to cool down before it will open the door.
If that fails run the self clean cycle again perhaps a second try will get it loose.
TickMagnet
Aug 17, 2011 | GE Ovens
Cleaning cycle finished, oven cool but still locked
Since the clean cycle was interrupted by turning the breaker off it may need to be restarted. Start the clean cycle like you normally would, then after it starts and runs for a couple of minutes, push cancel and see if it unlocks. If not the lock would need to be manually moved by putting a flat thin angled tool or stiff cardboard carefully between the door and oven cavity on the top of the door, slowly move this to the left, you will feel resistance when you get to the latch in the center. If you hit it right it will unlock.
May 07, 2010 | Whirlpool RBS275PD Electric Single Oven
I ran the self-cleaning and the door will not open.
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Mar 06, 2010 | Whirlpool Ovens
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
The oven door must be closed and all controls set correctly for the cycle to work properly.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
If your model has a latch, latch the door.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
On models without a door latch, the door
locks automatically. The display will show
the clean time remaining. It will not be
possible to open the oven door until the
temperature drops below the lock
temperature and the LOCKED DOOR
light goes off.
The oven shuts off automatically when the
clean cycle is complete.
When the LOCKED DOOR light is off,
slide the latch handle to the left as far
as it will go and open the door. If your
range does not have a latch, the door
will unlock automatically.
The words LOCK DOOR will flash and
the oven control will signal if you set
the clean cycle and forget to close the
oven door or forget to latch the door
on models with a latch.
To stop a clean cycle, touch the Clear/Off
pad. When the LOCKED DOOR light goes
off, indicating the oven has cooled below
the locking temperature, unlatch the door
(on models with a latch) and open the door
How to Delay the Start of Cleaning
Make sure the clock shows the correct time
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
start time you can set will appear in the
display.
Using the number pads, enter the time
of day you want the clean cycle
to start.
locks automatically. The display will show the
start time. It will not be possible to open the
oven door until the temperature drops below
the lock temperature and the LOCKED DOOR
light goes off.
The words LOCK DOOR will flash and the
oven control will signal if you set the clean
cycle and forget to close the oven door or
forget to latch the door on models with
a latch.
pad
(on models with a latch) and open the door.
After a Clean Cycle
You may notice some white ash in the oven.
Wipe it up with a damp cloth after the
oven cools.
If white spots remain, remove them with a
soap-filled scouring pad and rinse thoroughly
with a vinegar and water mixture.
These deposits are usually a salt residue
that cannot be removed by the clean cycle.
If the oven is not clean after one clean cycle,
repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to
unlock.
While the oven is self-cleaning, you can
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
small amount of vegetable oil or cooking oil
to a paper towel and wipe the edges of the
oven shelves with the paper towel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Door won't open after self-cleaning cycle is complete
Turns out that the latch is attached to a plastic piece (made by the manufacturer) and the spring melted! To boot, the fuse in the back which aids in heating the oven went out also. Repair man said this was typical after several uses in cleaning cycle. He recommended using a gentle steel wool pad with soap built in to gently remove backed on food instead of using cleaning cycle. It is just too hot for too long, and there seems to be a domino effect with things that will go wrong. Nothing like the old fashioned way and a little elbow grease!
Mar 19, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
"Door Locked" flashing on GE Oven JTP15 - can't unlock
The problem may very well be in one of the micro switches on the self cleaning motor bracket. These switches control the electrical flow to the heating elements. In the owners manual there is/should be a chart that lists the unlock and safety combinations. This would be your best source of information.
Jan 20, 2008 | GE Profile JTP18 Electric Single Oven
Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
most of the time a simple fix.... http://www.geappliances.com/search/fast/infobase/10004586.htm
you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
Print Range - “LOCKED DOOR” flashes in the display
If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Sep 14, 2007 | GE Profile JTP18 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
120 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
