Question about Brother MFC 420CN All-In-One InkJet Printer
Brother mfc 420cn must lift cover then close to print
LCD after a print job will say "unable to print"; however if I just lift the cover and close it back down it resets and is ready to print and will take the next print job. Then after it prints this job it will again say "unable to print" and I again lift the cover then place it back down its ready to print again. It at least prints but is rather annoying.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Epson printer error codes
The error code E-90 appears when the print head is not able to move back and forth freely.
If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
  1. Turn off the printer
  2. Lift up the scanner.
  3. Press down on the ink cartridge cover to make sure it is completely closed.
  4. Close the scanner and turn the printer back on.
- or, If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
  2. Lift up the scanner to access the printer area.
  3. Remove the tape from the ink cartridge holder.
  4. Close the scanner.
  5. Turn the printer back on
epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-0.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-2.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-5.jpg
Sep 01, 2014 | Epson Stylus DX6050 All-In-One InkJet...
How do I change the ink cartridge in my canon mp495 printer
Make sure that the printer is plugged in and turned on. Close the document cover (if it is open). Lift the scanner unit and hold it open with the support on the right. Wait until the ink cartridge carrier moves to the ink replacement area. Pinch the tabs on one of the ink cartridge covers (front and back) and lift the cover up. Then pull the cartridge up at an angle towards you. Put the new cartridge in at the same angle. Then close the cartidge cover (it should click). Repeat this for the other cartridge, if needed. Lift up the scanner unit and then lower it down to close the printer.
Wait for the printer to do the print head cleaning before sending more jobs to the printer. (It will resume jobs in progress automatically.)
If it takes more than 10 minutes to replace the cartridges, the cartridge carrier will return to the home position. Close the scanner unit and then lift it back up.
I hope this helps.
Mar 21, 2013 | Canon PIXMA MP495 InkJet Printer
Unable to print 70
  1. Open the Outer Back(Rear) Cover (1) at the back of the machine. Pull the jammed paper out of the machine.
  2. Close the Inner Back(Rear) Cover (1) if it is open as shown in the illustration.
  3. Close the Outer Back(Rear) Cover. Make sure the cover is closed properly.
  4. Pull the paper trays (1) out of the machine.
  5. Push the two green levers up on both sides.
  6. Pull out the jammed paper (1) and press Stop/Exit.
  7. Push the green duplex unit up.
  8. Reset the machine by lifting the scanner cover from the front of the machine and then closing it.
    If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
  9. Using both hands, use the plastic tabs on both sides of the machine to lift the Scanner Cover (1) into the open position. Make sure that there is no jammed paper left in the corners of the machine under the plastic covers.
    Note
    • If ink gets on your skin or clothing immediately wash it off with soap or detergent.
    • If the paper is jammed under the print head, unplug the machine from the power source, and then move the print head to take out the paper.
    • If the print head has stopped in the right corner as shown in the illustration, you cannot move the print head. Press Stop/Exit until the print head moves to the middle. Then unplug the machine from the power source, and take out the paper.
    1. Gently close the scanner cover using the finger holds on both sides of it as you push down on the Scanner Cover Support (1).
    Caution Be careful not to trap your fingers under the scanner cover. Always use the finger holds provided on both sides of the scanner cover when opening and closing it.
    1. Push paper tray #1 and paper tray #2 firmly back into the machine.
    Note Make sure you pull out the paper support until it clicks.
Nov 11, 2011 | Brother MFC-6890CDW Printer
SAYS UNABLE TO CLEAN
"How do I clear the message Unable to..." ( "Unable to Change" "Unable to Clean" "Unable to Init" "Unable to Print" "Unable to Scan" )?
Step1: To clear the message follow the steps listed below:
1. Check for foreign objects, such as a paper clip or scrap of paper, inside the machine.Unplug the machine from the power outlet and open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2.If the error continues to appear, the machine may have a mechanical problem.If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. Please make sure you have followed the instructions in the Step1.
3.If the error still continues to appear, move the print head and examine under the print head.
3-1.Disconnect the Brother machine from the poweroutlet.
3-2.Open the scanner cover by pulling up on the lower right corner of the cover.
3-3.Check the print head's position.
3-4.Gently move the print head to the center.
3-5.Examine under the print head. If anything is found, remove it.Use a flashlight if necessary to check thoroughly.
3-6.Close the cover and reconnect the machine to the power outlet.
If the message continues to appear on the LCD, the machine will require repair.
Step2: Check if the machine has faxes in its memory
1.Transfer the Fax Journal Report
1.Press Menu/Set or Menu on the Control Panel of the machine.
2.Press the up or down navigation key until Service appears on the LCD. Then press Menu/Set or Menu.
3.Press the up or down navigation key until Data Transfer appears on the LCD. Then press Menu/Set or Menu.
4.Press the up or down navigation key until Report Trans appears on the LCD. Then press Menu/Set or Menu.
5.The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Black(Mono) Start.
2.Verify and Transfer faxes in memory
4.Press the up or down navigation key until Fax Transfer appears on the LCD. Then press Menu/Set or Menu.
5.If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3. If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Black(Mono) Start .
3.Reset the machine
After the Fax Journal Report and faxes in memory have been transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
Feb 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
009-359 error
There are a couple of things to try in this situation. The first and foremost thing to try is to reseat the image drum. Open the top of the printer and lift the blue drum release latch on the right side, and lift the drum up and out of the printer. Then reseat the drum, locking the release lever back in place. Close the top lid and restart the printer. If the error returns perform the following steps as outlined below and advise of the results once completed.
Run diagnostics on the Bias Transfer Roll (BTR) retractor motor on the 3000cn-/3100cn-series printer.
To run diagnostics on the Bias Transfer Roll(BTR) retractor motor, perform the following steps:
  1. Power off the printer.
  2. Close all printer covers and doors.
  3. Hold down the up and down arrow buttons on the printer and power the printer on.
    A Customer Mode menu appears.
  4. Press the down arrow button until IOT Diag appears, and then press the return%20arrow%203100cn.jpg button.
    On the LCD, Digital Input appears.
  5. Press the down arrow until Digital Output appears, and then press the return%20arrow%203100cn.jpg button.
  6. Press the up arrow button until DO-14 READY appears, and then press the return%20arrow%203100cn.jpg button.
  7. Press the return%20arrow%203100cn.jpg button.
    On the LCD, DO-14 EXEC appears and a motor noise should be heard.
  8. Press the Cancel button to stop the test.
    On the LCD, DO-14 READY appears.
  9. Press the Menu button.
  10. Power the printer off and then back on.
Jan 24, 2011 | Office Equipment & Supplies
What does it mean when it says Drum near end
Order a new drum, part number DR520, from an office supply store or Brother (http://welcome.solutions.brother.com/bsc/public_s/id/us/us/en/monolasermfc/mfc8460n_all/c_o/index.html?reg=us&c=us&lang=en&prod=mfc8460n_all&cao=dr ). The drum transfers the toner onto the paper and has a finite lifetime - approx. 25000 pages (1 page/job). Change the drum when the print quality decreases or the message changes to replace drum or drum end.
To replace, open the front cover and remove the drum and toner cartridge assembly (wait until the machine cools if it has been printing). Avoid the electrodes on the assembly. Hold down the lock lever and take the toner cartridge out of the drum unit. Unpack the new drum and put the toner cartridge in the new drum (when it is locked the lever should lift automatically). Place the assembly back in the all-in-one. Do not close the front cover. Press Clear/Back on the control panel. The LCD should ask "Replace Drum?". Use the up/down arrows to select 1. Yes and hit OK. When the LCD shows "Accepted", close the cover.
I hope this helps.
Jun 03, 2010 | Brother MFC-3320CN Plain Paper Inkjet Fax
E-90 error message on Epson CX6000
If the error code E-90 appears on your Stylus CX control panel display, the print head may not be able to move back and forth freely.
  1. Turn off the Stylus CX.
  4. Close the scanner and turn the Stylus CX back on.
Also
  5. Close the scanner.
  6. Turn the Stylus CX back on.
Aug 07, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Dell Printer 1720dn - Unable to reset drum counter..
"Press & hold the cancel button untill all lights start flashing in a sequence and then i release the button and close the front cover." "DO NOT release the button, but continue to hold down it while you close the front cover.
Printer offline: Right click on your printer in the "Printers and Faxes" folder and "UN Check" use printer off line,
May 11, 2009 | Dell 1720dn Laser Printer
My Brother MFC-235C shows print unable 32 read user manual but I dont have a manual
The message "Print Unable 32" or "Machine Error 32" will appear on the LCD display if paper or labels are stuck inside the printer or drum unit.
This will also appear if there is either a mechanical issue or just a problem with a sensor possibly software.
1) The way to resolve this issue is to make sure there is no paper in between the rollers or on top of the print heads (if applicable).
2) If there is no paper the you will need to hard reset the printer which will restore to manufacuter settings and reset software.
Hold down the Menu botton while plugging in the power cable. The display should read "Maintenance." let go of the menu button and then punch in 91. The display should read "Param Init." The unit will beep once. Then type 99. The unit will exit maintenance mode.
This only works for maybe 30% of the time.
3) If this does not work then : Refer to Manufacturer or return the item.
IF PRINTER DOES NOT HAVE A MENU BUTTON:
1)Turn the printer power switch OFF. Check that the front cover is closed.
2)Turn the printer power switch ON while holding down the GO button until the Toner, Drum and Paper LEDS are lit.
3)Release the GO button. All LEDs will be off.
4)Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the READY LED will be lit.
Feb 19, 2009 | Office Equipment & Supplies
Brother MFC 420CN All-In-One InkJet Printer Logo
46 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
