Question about SanDisk Sansa e200 MP3 Player
Sansa e 200 2gb is not recognized in the usb port windows vista
    President:
  • 1,990 Answers
You need to go to the Sansa Website and Download Updated Drivers for Vista
Posted on Jan 14, 2009
My sansa mp3 player isn`t recognized by the computer
It may depend on your operating system, but there are known issues in vista. There is also a hotfix from microsoft. This is from the Sansa Website FAQs at http://www.sansa.com/support/sansa_clip/faqs
My Sansa player is not recognized by my computer when I connect it.
The most common reason for this problem is not having the latest Windows Media Player installed, or having a Windows OS version that is not supported by the Sansa player.
The Sansa players support Windows XP SP2 and Windows Vista and above. If your operating system version is supported by the Sansa player:
SOLUTION 1 – Download and install the latest Windows Media Player
SOLUTION 2 – If that didn’t help, and you are running Windows Vista, apply the following hotfix - KB940199
SOLUTION 3 – If that didn’t help, download and Install the MTP Porting Kit (click here)
SOLUTION 4 – If that didn’t help, try connecting the device to the PC using MSC mode
On the Clip: Go to Settings > USB mode & choose MSC
I hope this helps and please don't forget to rate my answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Sansa c240
Sansa c200 series – Computer/OS Not Recognizing
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
If that fails, unplug the Sansa from the computer. Uninstall all the Sansa software in the add/remove programs section of Control Panel. Reinstall the clean version of the software from Sandisk’s website – make sure you get the files for the c200 series. Then replug the Sansa and try again. The root of the problem is that Sansa has one set of drivers and Windows has another. If you plug the mp3 player into the computer before installing the Sansa drivers, the Windows drivers will trump the Sansa’s.
Here is a helpful link from Sandisk on the problem with extra information on Vista operating systems:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=42&p_created=1221328944&p_sid=8VPwlRmj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzQsNzQmcF9wcm9kcz00JnBfY2F0cz0mcF9wdj0xLjQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jMjAw&p_li=&p_topview=1
-Tha Mp3 Doctor
Jul 29, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
E270 isn't recognized by windows; can't enter recovery mode
Are you running Vista? shame on you for not checking to see if your player is compatible with it
If you are running XP:
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Jul 01, 2008 | SanDisk Sansa e270 MP3 Player
Sansa scan disk mp3 player
guest - you must have Windows Vista - it's not compatible
tooth -
Wizard.
Jul 01, 2008 | SanDisk Sansa m250 MP3 Player
Usb not recognized on sansa e280 (sandisk)
Unfortunately, so simple - although this simple solution does not appear in any manual. the solution: put your Sansa in the rear USB - and the PC immediately recognizes the MP3 or MP4. The USB soccket in the front of the PC does not have enogh power, and when using the rear USB port - it works!
Izi
izimann@lycos.com
Apr 04, 2008 | Audio Players & Recorders
Windows vista supported driver
Change to MSC mode to use with Windows Vista.
Q: How to change to MSC mode:
A: On your Sansa device, press "menu" and go to "Settings" then "USB" choose "MSC".
Then plug it in. My computer finally recognized it.
Nov 21, 2007 | SanDisk Sansa e250 MP3 Player
Sansa media converter will not recognize my mp3 player
The Media Converter will only recognize the device in MSC mode.
Make sure it is on this mode and try all of the USB ports on your PC. If that doesnt work, try uninstalling and re-installing the Media Converter.
Best of Luck.
Nov 16, 2007 | SanDisk Sansa e260 MP3 Player
Windows vista compatibility
ive got vista and ive had no problems with it the only thing i can thing of is that your usb port is not a high performance port
Jul 28, 2007 | SanDisk Sansa e250 MP3 Player
Windows vista, doesn't recognize my sansa e200
Hey, the best solution is to switch your sansa from MTP to MSC mode in USB Mode. Its working for me.......
Regards,
Sajith
Jun 29, 2007 | SanDisk Sansa e250 MP3 Player
Recognise my sansa
to old for vista to recognize
Apr 29, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
47 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
