Question about GE Spectra JBP78 Electric Kitchen Range
Oven heat coil
There are two heat coils in the oven. The larger of the two will not heat. Where do I find a replacement ? Can it be replaced ? Is there a GE parts store in the Western Suburbs of Chicago, Illinois ? Not sure it is actually referred to as a coil ?
  • GE Master
  • 5,568 Answers
Check with Sears in their parts store to see if they have your model illustrated. If they do, you may be able to order it through them.
If they do not, there are several appliance parts stores on line which do and one of them will have your part. Otherwise you can search on the net and I would use: GE "JBP78" "oven element" as search terms.
Posted on Jan 14, 2009
I need the heating coil for the H398BP2 miele double oven
Fixya does not sell replacement heating coils. Check with a local appliance parts supplier.
Oct 23, 2016 | Miele H398BP2 / H398B2 Electric Double...
Oven lights but won't heat up
The coil on the oven may need to be replaced. Unplug the oven and remove the coil. You should be able to find a replacement at a hardware store, online, or at a major appliance outlet such as Lowes, Home Depot, etc.
Please rate this answer! Thanks!
Jun 12, 2011 | Ovens
Tappan Oven 316246653. Preheating the Oven does not work. Bottom Heating Coil (if thats what its called) is not working. The Broiler Coil at the Top does work. Is it the bottom coil that needs replaced...
Usually when the element fails to heat up, It means its usually broke, cracked, or where they plug in gets brittle and breaks. Your best bet is to replace the bottom element.
May 23, 2011 | Microwave Ovens
Oven will not heat up... the bottom coil is cold. What can be wrong, how do replace coil?
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 22, 2010 | General Electric JBP22B Range
When oven is set for heating. it does not heat up
You will need a multimeter to check for th resistance of the coils.remove power plug.
Check from the power plug to the main switch .When the switch is turned on the line must come till the coil.
Now disconnect and test the coils , if open resistance the coils are burnt and must be replaced with the same type /wattage.
However if coil is good then it can be the thermostat cut off(UNIT), the switch or the wires.
Sep 02, 2010 | Electrolux EOB6630 Ultrafan Electric...
Bottom Coil on Oven not Heating Up
yes it is most likely the element (coil) itself burnt out. inexpensive and easy to replace.
Jun 28, 2008 | Kenmore Ovens
GE Spectra JBP78 Electric Kitchen Range Logo
194 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
