FixYa.com
Tags:
Discwasher VHS HEAD CLEANER
My head cleaner won't work.
By kcw573 - usenet poster
My Discwasher VHS wet VCR head cleaner won't work with my Toshiba M220
2 head VCR.  The VCR acts as though the head cleaner is at the end of
its tape, tries to rewind the head cleaner and stops.  It doesn't
matter whether the cleaner cartridge is rewound fully or not.  The
cleaner worked with my previous VCR.
I suspect that the Toshiba uses a light sensor to detect the end of
tape and the light shines through the cleaner tape which is white and
translucent, fooling the VCR into thinking it is at the end of the
tape.
Does anyone know what the problem is?
Is there some way to fix my current head cleaner?
Does anyone know of a head cleaner that will work with my Toshiba?
Would a dry head cleaner work?
Which type of cleaner is better for a VCR, wet or dry?
        Thanks for any help.
        Tom    t @inmet.inmet.com
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 08, 2005
Not Rated (0)
Ranny
Ranny - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Note that some solvents can cause severe damage to various parts of a VCR,
especially thos parts made of plastics or other synthetic materials (e.g.
the pinch roller).
In addition to cleaning with a solvent, it is also useful to occasionally
use a cleaning cassette which is (slightly) abrasive.  The main reason for
this is that the surface of the heads tends to become scratched and scored
in normal use, due to dust, irregularities in the surface of the tape,
etc.  These scratches have several effects, two of the most important of
which are:
1)      The haed-to-tape spacing loss is increased, resulting in a degaradion
        of  signal-to-noise ratio of the off-tape RF signal.
2)      The scratches can cause damage to tapes played in the machine.
No amount of cleaning with a solvent can remove these scratches. Only
polishing (with the cleaning cassette as mentioned above) can restore the
head surface to a smooth condition.  It is important, however, to observe
the recommendations for proper use of these cleaning cassettes -- if the
instructions say to run the tape for 5 seconds maximum, don't run it for
10 minutes!
        Bruce Lilly             blilly!balilly!br @sonyd1.Broadcast.Sony.COM
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Melissa
Melissa - usenet poster
Rating: 0%, 0 votes
The truth is, those consumer wet or dry head cleaners based on the use
of an insertable cassette really don't do the job.  In fact, some can
do more harm than good.  But VCR cleaning (which includes cleaning of
the heads) is a very necessary operation which should be done every
30-50 hours of operation.
The problems to be addressed stem from:
    * Build up of loose oxide particles on and around the rotating heads
         (no matter how many there are)
    * Build up of the same on the audio and control track heads
    * Build up of tape adhesive on the rollers, capstans, and tape guides
    * All of the above contaminants on the head drum
    * Dust in the machine
In fact, this adhesive buildup problem can be far more serious that
dirty heads, perhaps even damaging the tape or the VCR.
A serious cleaning requires a proper solvent, lintless gloves, lintless
swabs, and special head cleaning pads.  A nice kit with these parts
is available from Radio Shack.  Now comes the hard part.
You must remove the cover of the VCR.  If you have ample hair and a
beard like me, be extra careful of get a surgical cap and mask!  Use
the solvent and a swap to get to the guides, capstans, and rollers.
you may notice that the rollers show the tape's footprint.  After cleaning,
the rollers should NOT be shiny.  Cleaning the head assembly is tricky.
HEADS MUST BE CLEANED ONLY IN THE DIRECTION OF TRAVEL TO AVOID BENDING
OR BREAKAGE; THEY ARE VERY DELICATE.  Wet a head cleaner pad, touch
the crum surface, and rotate the drum, holding the pad stationary.
Look for other dirt, dust, or hair in the machine.
CAVEAT:  This is a tricky operation and could easily lead to damage
of your VCR.  Read directions carefully.  Sincethis type of head cleaning
is considered to be a professional operation, you may want to let an
expert do it and avoid the risk.
=========David Taylor Research Center (a US Navy lab) - Annapolis, MD==========
    /|/| /||)|/  /~_/\| |\|)[~|)/~_  |  "Everyone's entitled to MY opinion."
   / | |/~||\|\  \_/\/|_|/|)[_|\\_/  |      goldb @oasys.dt.navy.mil
"Poor is the man whose pleasure depends on the permission of another."-Madonna
Solution #3
Not Rated (0)
Charlie
Charlie - usenet poster
Rating: 0%, 0 votes
        [VCR cleaning details deleted]
True.  However, if you're adventurous, you might want to check out the
December (I think) issue of Videomaker.  They give a good description about
how to clean VCRs and camcorders.  I followed their instructions to clean one
of my machines and everything went well.  One just needs to exercise care and
patience and everything should go well.  One point to note, though: Even the
Videomaker article says that one should have their VCR cleaned by a pro once
in a while.  They made the distinction that there is more to cleaning a VCR
than just swabbing the tape surfaces with solvent.  Specifically, a true,
thorough cleaning should include demagnetizing the heads, etc.  Just doing
what was mentioned in the article is considered maintenance, not cleaning.
Happy swabbing!
                            Paul Kerchen
kerc @fuji.eecs.ucdavis.edu    - or -  kerc @holly.eecs.ucdavis.edu
Can you Help with these Audio and Video Media problems?
downlod sound drive
compaq laptop presario... Answer This...
Region change on DVD player
Good day my name is Laurence... Answer This...
Awia NSX -A90
Hi in moving house i lost the... Answer This...
sound and audio devices problem
my computer not supporting to... Answer This...
speakers for model #DC-D9U
I need to purchase new speakers... Answer This...
Repair Service
Find Audio and Vid. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
