Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Rolling Screen I have had this Plasma for only 16 months and no the screen is rolling ( I didn't know that TV's did that anymore). Call Tech Support and they could only give me a service center #. There is no color and I have to unplug to shut off. oes anyone have a simple solution?
    New Friend:
  • 129 Answers
Unfortunately there is no a simple solution for that the most simple could be a software upgrade but it depends. the signal board could be defective too. if technical support can't provide parts for it try ebay with your model # hope this answer can help you to make a desicion . let me know thanks
Posted on Jun 13, 2007
Problem rolling bars
It should be a main power regulator baord fault. Contact any service technician.
May 22, 2013 | Panasonic TCP50U2 50 in. TV
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
We have Toshiba 42" Plasma TV about 4 yrs old. The past couple of weeks we've noticed that there is a horizontal rolling band of pinkish color (about 8-10" band.) We really notice it when there are people...
Im pretty sure its not the television. You are getting interference from either through your cable box or your electric in the house. Possible bad dimmer switch.
Dec 14, 2009 | Toshiba 50HP66 50 in. Plasma Television
Changed resolution and Wii will not stop rolling on screen. I have a lcd tv 101cm, will work okay on old 68cm tv.
For best results use the component cable for LCD TV.Make sure the screen is 16:9.Go on Wii menu and check the vertical frequency.If it 50Hz make it 60Hz or back.
Oct 08, 2009 | Nintendo Wii Console
Purple and green rolling lines after lightning storm
I have exact same problem...other posts have cited improper grounding from the Cable...which makes sense as the problem does not occrr with the DVD...I have not figured out how to fix it though...
Aug 12, 2009 | Panasonic TH-50PX75U Plasma HDTV
Horizontal convergence line rolling up the screen
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation and let them recommend an authorized service center in your area. but this is a rather serious problem...
thank u
rate me!!
Jul 15, 2009 | RCA Televison & Video
I have a red and green bar rolling across my screen
call HP case management 877-917-4380, tell them you want this fixed and be firm. They are being very helpful with my problem and keep sending parts until it's fixed , all free of charge with tech at my house
Dec 03, 2008 | HP PL4260N 42 in. Plasma HDTV
Rolling screen
Good Day; lanniejo;
1. VERTICAL ROLLING, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. REPLACE C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. REPLACE C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
It should not be that costly, always get an estimate, if you can't repair it yourself. Don't worry about the light bulb, it should be okay, as long as the picture color is ok. Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Hitachi 43FWX20B picture problem
yea take the set to a tech reprogram.or take out the plug and plug it in after 30 min.if the problem does not go.do as i say.good luck.
Apr 04, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
