Question about Maytag PYE2300AY Electric Dryer
Need ohm readings for Maytag Performa Model PYE 3200AYW
My dryer does not heat. I have read other questions/answers, it's not blocked, it tumbles, blower works, just no heat. I have id the 3 different possible problems: heating element, hi limit thermostat or thermal fuse. I think there could be any other possible reasons? But I don't know what the reading should be on the ohm meter for each. Please help.
Maytag Performa Model PYE3200AYW. All I could find was model 2300 info.
thanks
Janna S.
    Scholar:
  • 40 Answers
Go to this site for info on your dryer type, you may find what you need there...
http://www.applianceaid.com/ww-and-mc.html
Posted on Jan 14, 2009
I have a maytag performa dryer wont heat up sometimes
Hello there:
If there is no heat or heat sometimes please try these solutions
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 14, 2010 | Maytag Performa PAV2200
Maytag performa dryer model pye2300ayw, what should the ohms reading be on the thermal fuse?
doesn't matter,it's either good or bad,when you touch the meter to it if it reads 1 and doen't move it's bad if you get any reading it's good,if the dryer is loaded with lint in the duct that the lint filter slides into and the vent line is blocked it will keep popping on you, clean out the dryer,number one cause for popping the thermal fuse
Feb 22, 2010 | Maytag Dryers
My maytag performa pye2300ayw dryer will start but will not heat up. No matter how long I leave it on, it just won't heat up. what could be the source of the problem? the model number - pye2300ayw rev - 10...
You have a thermal overload switch that may be bad. It is located under the top of the dryer. Check first the breakers. Turn them off and then back on, then check the wiring in the back of the dryer and then the element itself. It may take 30 minutes to do all of this, but it will save you a lot in the long run.
Mar 04, 2009 | Maytag Dryers
No power to maytag duet dryer...no light no power I have checked circuit breaker plugged/unplugged??
most maytag "performa" dryers with no power h appen froma blown thermal fuse. It is located under the top and beside the heating element. you can take an ohm meter to both terminals.If you do not get a reading, the part is bad. It comes as a kit with a new safety tstat
Feb 19, 2009 | Maytag PYE2300AY Electric Dryer
Maytag performa dryer vent clogged and dryer stopped
I am not 100% sure I understand your question but if you need to know how to reassemble your dryer after cleaning it out,.use this link .. It has exploed views and parts lists .. http://www.pcappliancerepair.com/model-display.php
If my reply does not answer your question, please clarify your concern and I will assist you.
Regards,
Rick
Dec 01, 2008 | Maytag Performa PAV2200
No heat from dryer.
Do not buy or use a maytag performa dryer model number pye2300ay at all. I fyou have one unplug it and take to the landfill or scrap yard. They are complete junk and nothing but a hassle. One problem after the other on this model no matter what you do. they are complete trash and a waste of your money.
Nov 24, 2008 | Maytag Performa PAV2200
Dryer not heating
hi thanks for the question. disconnect the dryer. remove the front 2 screws remove front. element is on the right in a cylinder check and replace. thanks the appliance doc
Oct 16, 2008 | Dryers
Maytag performa dryer pye/g2200
hi .thanks for the question .no the element does not go bad a little at a time. but the venting gets clogged up a little at a time . remove the venting and clean to the outside wall . also if the dryer is noisy you could have a blower problem. if the dryer is noisy .but check the venting thanks the appliance doc
Oct 01, 2008 | Maytag PYE2300AY Electric Dryer
Dryer turns on doesnt dry
Suspect heating element or thermal fuse. The heating element and fuse can be checked with an ohm meter. The reading should be 0-2 ohms on both devices. If heating element reads infinity (nothing) replace heating element and fuse. If the fuse reads infinity then replace the fuse.
Jan 06, 2008 | Maytag Performa PAV2200
Maytag PYE2300AY Electric Dryer Logo
431 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
