Question about JVC GR-DVL310 Mini DV Digital Camcorder
E 04 error
What is an E 04 error code & how can I fix it?
  • 38 Answers
E04 indicates a drum motor communication problem with the micro. It most often requires solder connection rework on one of the boards where the fpc cable from the drum is terminated. This is a fix for a pro. Good luck, magic seadog
Posted on Aug 12, 2007
    Champion:
  • 287 Answers
E04 IS a drum error. I have seen screws which fall out of the set and get stuck on the maginet of the lower cylinder drum assy. Does the drum spin ? can you turn it? If it is stuck find out what is making it not spin. I could need a new drum but I have also fixed this problem by cleaning the mechanism. I have a $40 cleaning and diagnostic fee. Call me 916-362-8708 Larry
Posted on Jan 24, 2012
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
How do I fix fan wont shut off
In front of the 04 code, what is the "F" code is needed for help you. There are 4 different possible answers for this issue.
FAILURE/ERROR DISPLAY CODES Before proceeding with any corrective action, perform the following steps to enter the Diagnostics mode: 1. To recall last failure code, if not displayed, press the Cancel key to place the range in an idle state. 2. Press the Cancel and Start keys in the following order: CANCEL, CANCEL, START. 3. Verify the error code displayed on the control by observing for longer than 1 minute. If the error returns, use the applicable procedure listed below for the actual error code that is displayed.
With this information, I can narrow down the cause and possible repair on you unit. Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 11, 2016 | KitchenAid Kitchen Ranges
Error code sc 23-04
What model is this machine?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 26, 2014 | Konica Minolta Office Equipment & Supplies
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
How can I correct SC29-04 on Konica 7255?
The sensor is located on the left side of the drum cartridge it is a sensor that is covered with a white cover to the rear of the drum you must remove the drum to see it clean with cloth not a vacuum cleaner Static from vacuum can destroy it. The clear glass sensor is for paper jams! Located in the middle of the cartridge. Mite also want to know when the last 250K copies PM was done?
Nov 28, 2012 | Konica Minolta TN601K Toner for 7155,...
I have a designjet 800ps 42" and send me the 79:04 error code, after this happen i change the belt and all the printheads, but it still send me the same error, it said Error Code:79:04 ...
Who told you to change the belt? 79:04 is a Firmware error.
Switch the Printer Off and wait a few minutes. Switch the Printer On again and check if the Error Code has disappeared. If the Error Code reappears, check for a new Firmware release. If the new Firmware release does not solve the problem, or if new Firmware release was not available, then contact the HP Response Center supplying the following information: - Model and Serial Number of the Printer. - Firmware release of the Printer
- The complete Error Code information, including the linefeed where the error occurred
Aug 19, 2011 | HP DesignJet 500ps (42 in.) InkJet Printer
My sharp phohtocopy showing call for service F2-04 after opening the cover when booting please help me with the code to fix it
F2-04- Improper cartridge (destination error, life cycle error)
Identification error
model error
type error
destination error
data abnormality
Misc error
Jul 03, 2011 | Sharp AR-275 Copier
F2-04 Error code - How do I clear?
Improper cartridge (destination error,life cycle error)
Dec 02, 2009 | Sharp Office Equipment & Supplies
JVC GR-DVL310 Mini DV Digital Camcorder Logo
244 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Roger Goldberger
Roger Goldberger
Level 1 Expert
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
