Question about Pantech C300 Cellular Phone
Water damage to c 740
How to disassemble
  • Anonymous Jan 23, 2009
    broken scren
    President:
  • 1,871 Answers
Try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Posted on Jan 17, 2010
Soundworks 740 fuse
See my answer to cd740 sound cutting out. Fuse is inside near the transformer. You'll need to disassemble. There is a good write up for a question about getting to the faceplate. Briefly, there is a sub base that has screws hidden behind the rubber feet pads which peel off easily. The front speaker grills PPP off easily and it hides some screws. The rear plate also has to come off. Check those other questions, the answers will help.
Apr 23, 2014 | Cambridge Soundworks CD-740 Clock Radio
Installed water pump on my Volvo 86 740 ZLE and the Volvo engine keeps shutting off. What could be wrong?
It could be the belts, did you replace them? Does it drive at all..could be the timing belt.
Mar 22, 2013 | 1986 Volvo 740
My mobile is damage by water how can i solve this problem
Get the Phone Out of the water. Do NOT power it on.
This may sound too obvious a step but a few extra seconds that your phone spends in water can reduce whatever chances you had of saving your phone.
If however your phone has spent more than a few minutes in water try removing the battery when the whole gadget is under water itself .
Powering up the phone when it is wet causes the maximum damage to your phone.
2 Remove the battery and SIM card
Water + battery is a bad combination for your phone. Remove the battery as soon as possible. SIM card too must be removed immediately as water on SIM cards may erase all your contacts stored in the SIM.
3 Dry the phone as much as possible
Try and pat dry the phone, the battery and the SIM card. Using a paper towel is advisable for removing water quickly.
4 Metciulously Disassemble the phone completely
This is one of the most important steps on your phone's path to recovery. If possible take your phone to a local mobile phone servicing shop and ask him/her top disassemble the phone completely for you. Make sure the circuits are not powered up by the shopkeeper.
If you are worried that disassembling the phone will make your warranty/guarantee void you need to know that phones come with Water Damage indicators which change colors with the slightest hint of water. No phone warranty covers water damage.
5 Dry all the phone components with a dessicant
After disassembling the phone immerse each component in a bowl of uncooked rice / silica gel packs. These dessicants absorb water effectively and draw out water from all nooks and corners of your phone. Heating / Vaporising the water is a bad idea cause that would leave salts on your phone's circuitry and cause corrosion and eventual death of your phone. Hence drying with uncooked rice/silica gels where water is removed by absorption is the best option. Leave it there for a couple of days.
6 Show patience and let every component lie under a table lamp for a couple of days
Now your phone is almost on its way to complete recovery provided you show Adequate patience. You may keep the bowl of rice under a table lamp for this duration . Changing the rice /silica gels though not a mandatory step, can be pretty effective and useful.
7 Assemble , Pray and Switch on!
Jul 14, 2010 | Nokia 1661 Cell Phone
'90 Volvo 740 2.3l turbo water pump install instructons needed
Go to an auto supply store like PEP boys or Advance Auto, etc., and buy a Haynes Repair Manual for the 740. You may be able to consult one at your local library for free. Even if it doesn't cover your model year, the replacement instructions are pretty much the same for all years. in fact even a 240 Volvo manual would be essentially the same. Pay particular attention to the installation instructions....you have to slide the pump on, and then rotate it a few degrees clockwise to make the upper o-ring seal. Good luck!
Nov 24, 2009 | 1990 Volvo 740
How get pads off calipers
The pins must be driven out spray liquid wrench on them an let stand for a few minutes these pins should be replaced with new ones if they are badly rusted, you don't need to disassemble the caliper just drive out the pins. It is a good idea to clamp the caliper in a bench vise to drive out the pins, use the appropriate size drift or center punch to achieve this.
Oct 03, 2009 | 1992 Volvo 740
If timing belt on a 1991 740 volvo breaks while driving will it damage the engine?
yes, this is a high interference engine meaning high risk of valve and or piston damage is likely
Jan 07, 2009 | 1991 Volvo 740
All belts came off , 1986 740 gle 4 cly. with air nedd to know diagram
On the 92, the belt closest to the engine goes around the power steering pump, water pump, and crankshaft pulley.
The second belt goes around the alternator and the crankshaft pulley.
The third belt goes around the a/c and crankshaft pulley.
Jun 26, 2008 | 1991 Volvo 740
Samsung sch u 740
I had the same problem, it was because of water damage.
Jan 02, 2008 | Samsung SCH-u740 Cellular Phone
Pantech C300 Cellular Phone Logo
60 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
