Question about HP DVD940e Burner
Problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
I am having a problem copying a movie onto a lightscribe 16x hp dvd +r (4.7GB) media disc. It all works fine if i copy the film onto a verbatim 4x dvd +rw disc but just doesnt seem to be working with these lightscribe discs I am using DVD Decryptor for burning and choosing ISO write mode in the program. Is there something i am doing wrong? Basically when i burn the film onto the lightscribe disc it says that everything was successful in DVD Decrypto but then when i go to playback in my dvd player or on my dvd rom drive on my pc it makes a funny clicking noise and doesnt load up Please help.....
  • Lee Pearman
    Lee Pearman Jun 13, 2007
    I have just tried again and i am getting the following log errors:
    W 00:41:52 Failed to Write Sectors 0 - 31 - The semaphore timeout period has expired.
    W 00:41:52 Retrying (1 of 20)...
    W 00:42:51 Retry Failed - The semaphore timeout period has expired.
    W 00:42:51 Retrying (2 of 20)...
    W 00:43:49 Retry Failed - The semaphore timeout period has expired.
    W 00:43:49 Retrying (3 of 20)...
    W 00:44:52 Retry Failed - The semaphore timeout period has expired.
    W 00:44:52 Retrying (4 of 20)...
    W 00:45:50 Retry Failed - The semaphore timeout period has expired.
    W 00:45:50 Retrying (5 of 20)...
    W 00:46:48 Retry Failed - Power Calibration Area Error
    W 00:46:48 Retrying (6 of 20)...
    W 00:47:49 Retry Failed - Power Calibration Area Error
    W 00:47:49 Retrying (7 of 20)...
    W 00:48:50 Retry Failed - The semaphore timeout period has expired.
    W 00:48:50 Retrying (8 of 20)...
    W 00:49:51 Retry Failed - The semaphore timeout period has expired.
    W 00:49:51 Retrying (9 of 20)...
    W 00:50:53 Retry Failed - The semaphore timeout period has expired.
    W 00:50:53 Retrying (10 of 20)...
    W 00:51:54 Retry Failed - The semaphore timeout period has expired.
    W 00:51:54 Retrying (11 of 20)...
    W 00:52:52 Retry Failed - The semaphore timeout period has expired.
    W 00:52:52 Retrying (12 of 20)...
    W 00:53:50 Retry Failed - The semaphore timeout period has expired.
    W 00:53:50 Retrying (13 of 20)...
    W 00:54:53 Retry Failed - The semaphore timeout period has expired.
    W 00:54:53 Retrying (14 of 20)...
    W 00:55:51 Retry Failed - Power Calibration Area Error
    W 00:55:51 Retrying (15 of 20)...
    W 00:56:50 Retry Failed - The semaphore timeout period has expired.
    W 00:56:50 Retrying (16 of 20)...
    W 00:57:48 Retry Failed - The semaphore timeout period has expired.
    W 00:57:48 Retrying (17 of 20)...
    W 00:58:46 Retry Failed - The semaphore timeout period has expired.
    W 00:58:46 Retrying (18 of 20)...
    W 00:59:44 Retry Failed - The semaphore timeout period has expired.
    W 00:59:44 Retrying (19 of 20)...
    W 01:00:42 Retry Failed - The semaphore timeout period has expired.
    W 01:00:42 Retrying (20 of 20)...
    W 01:01:40 Retry Failed! - Power Calibration Area Error
    W 01:02:51 Failed to Write Sectors 0 - 31 - The semaphore timeout period has expired.
    W 01:02:51 Retrying (1 of 20)...
    Dont understand why this would only happen when i copy the movie onto the lightscribe hp dvd+r discs and not the verbatim ones?? kind of odd dont you think?
    please advise somebody. have i just wasted my money on these lightscribe media discs or is there a solution????
    thanks, lee
  • Lee Pearman
    Finally here is the actual error that i got after i tried burning with the verify after write command ticked:
    I/O Error!
    Device [0:0:0] HP DVD Writer 940d 3H23 (F:)(USB)
    CDB:2A 00 00 00 00 00 00 00 20 00
    Interpretation: Write(10) - Sectors:0-31
    Reason: The semaphore timeout period has expired
It wont let me burn a cd at all
Posted on Oct 01, 2008
    President:
  • 2,961 Answers
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Posted on Jun 13, 2007
My dvd not writing but read
There can be several reasons for that. Try to use Nero software if you are using LG SUITE. Also the DVD write speed and format has to match that of your writer. Ate you copying another DVD or writing data or edited media such as movie video or music files? Check compliance format.
Jul 11, 2013 | LG SecurDisc 20x Internal Double-Layer DVD...
A freind let me borrow their hp dvd 1040e external 20x multiformat dvd writer. i can burn the music on cds fine with itunes, but i cant figure out how to use the litescribe to burn images on the tops....
You will need Nero burning software. It will after the normal burn show you a screen where you place the image you want to burn for lightscribe. Another failing with lightscribe is that you must have lightscribe discs!
Jul 09, 2011 | HP DVD1040i 20x Super Multiformat Dvd...
Can't find my installation disc for my HP dvd940e external 18x...
your best bet is to google your product such as (google search "HP DVD940e Burner Software") and see if you can find it, if not contact your dealer and ask for a replacement CD
Sep 17, 2009 | HP DVD940e Burner
Help with burning a DVD
you can't copy the DVD movie as files. although you will see the movies files in chapters.
I don't have any luck using Nero or Roxio for Movies, they are OK with video copy.
I use DVDFAB. there are somting regular DVD writer just can't do.
Jan 08, 2009 | Computers & Internet
Problem wit my DVD writer
NO OS stated
NO PC stated.
NO job stated, just BURN something, vague.....
fail.
to burn a DVD takes skills
what is on said DVD, it can name 100 different vast things,
why not start with the missing story
what is it you wish to make? tell the helper what you are trying to do, a goal, like make my TV SOny DVD player play movies, using DVD movie format. (or bogus copies)
a real DVD movie.
a dvd with MP4 files. videos or 100 other types.
a dvd with data. (like docx files, xls, or ppt files? or?)
a dvd with songs, MP3 or 30 other types.
A dvd with software programs. like a copy of windows 7 install?
what?
Jun 11, 2017 | HP DVD 740VI 16X16 Dual Layer LightScribe...
My HP DVD writer 740b won't recognize disc
You guys are crazy, another person trying to send someone to a repair guy to make money off us when in fact it would be cheaper just to buy a new one. I have the same issue with the same model 740b and this is driving me crazy I have been to a 100 different post andI will tell you what no one has a clue what they are talking about. Oh, restart the system upgrade your firmware, delete your reg file, its all BS. I have did everything in the book and this is what I have come up with. My drive reads some dvd disc I have created but any ISO or Auto play disc it doesnt even see it just keeps trying to load and thats it. So in my opinion HP or Compaq sent a update that did not require you to accept or approve and it updated the firmware with some info about allowing to use writen ISO or autoplay disc. Because it would seem to help with the cutting down of pirated software but the only issue is that if the software is an individuals and they copied it for their own use, who are they to intefere with our equipment. I may be wrong but it just seems kind of funny that every one is stating that this all happened around the same time. So in closing if you dont know the remedy do not suggest to send to a repair shop because you are an idiot then.
Thx Pirate
Jan 15, 2008 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    LG GSA-E40L Burned Discs wont play on any other dvd player
    try using different media ( non light scribe ) and second try using a program such as nero premium or easy media creator 9/10.Most of my dvd's have been successful with good quality especially with nero ultimate/premium
    Oct 05, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
    Not recognizing disc in D drive
    Hi, well the short answer is NO. You cannot use DVD's in a CD Writer at all. So the simple answer is to get some CD-R and copy the files to them. OR get a Combo DVD/CD writer and install that as well.. and then you can use both..
    Aug 06, 2007 | HP (178373133) (Refurbished) (178373133)...
    Copying data on to a DVD
    What type of application are you using? I know that the new nero requires you to choose whether you want to write to dvd or cd before it will work. maybe your application is similar.
    Aug 01, 2006 | HP CD-Writer 9900ci CD-RW/DVD-ROM Burner
    HP DVD940e Burner Logo
    862 people viewed this question
    Top HP Computers & Internet Experts
    Alun Cox
    pankaj rautela
    pankaj rautela
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
