Question about Apex Digital AT2702 27" TV
Need power board forGT3215
Capacitor C890
    Sergeant:
    Champion:
  • 346 Answers
If capacitor is bad replace it.you don t need a power board
Posted on Jan 16, 2009
How do I identify a bad capacitor on a Samsung LN55C610N1F power supply board?
you can tell by the top of them,when there bad they bulge ( as if there going to pop )
Nov 26, 2015 | Samsung Televison & Video
Tip
How To Repair LCD Monitor
The most common problems on Samsung LCD monitor/TV:
  • The power can not turn on, the red light flashing
  • the monitor on for a while and then turn off, then the red light flashing.
This is due to the weakening of the capacitor in the power supply module.
let's go hunting for bad capacitor.
I will explain how to:
  • Open the case of the LCD
basically in all LCD monitors have two circuit boards (power supply board and system board)
  • After you open you will see the two boards are
  • You see a board that has a socket for the power source. wrote that the board we're looking for (power supply board)
  • Remove all cables connected to the board and take out the board. (get noted before you unplug it)
  • Now you see it components on board, we looking for capacitor.(see picture below)
  • Looking for damaged capacitors, physically you will see a capacitor on the top like a bloated (see picture below)
  • Replace the damaged capacitor with the same value that you can see on the surface of the capacitor. (In this step you need any soldering tool)
My advice: replace capacitors with higher voltage, like 10V replace with 16V or 25V will be fine.
Have a Nice Repair :)
on Feb 12, 2010 | Computers & Internet
DX-PDP42-09 Won't power up. There is clicking for a few seconds, then led 2 starts blinking. The screen flickers and the red power light comes on. No picture, no sound. Which board do I need to...
Sir before replacing the board try to check first the power supply, this fault is commonly cause by bulging capacitor or leaky capacitor, this bad capacitor is producing a low and unfiltered dc output that causes your unit to malfunction.
This is the bulging capacitor if you see this replace with the same type and observe polarity, capacitor is much cheaper than the whole power supply board replace this and it will fix the problem hope this help good day and best regards.
Sep 21, 2011 | Televison & Video
My Samsung 2493hm monitor quit working after a power surge. The power light flashes slowly but nothing else happens. Can it be repaired at a reasonable price?
Dear showmetoo99,
Surely favicon.icofavicon.icowiki-favicon-sharpened.pngoneriot-favicon.icoyou can fix it yourself with a very low cost.
Feb 02, 2010 | Samsung Computers & Internet
Stuck dvd and no power
I fixed this problem in my DVP642 by replacing a capacitor on the main power board where the power chord hooks in. Take the top cover off (after unplugging player). You'll be able to locate the bad capacitor on the circuit board located on the very right. Look for location marked c316 on the circuit board. A bad capacitor will be bulged up on top. The capacitor you're looking for will be a black barrel shape with an aluminum top, this aluminum top will be bulged up or leaking on the circuit board. Replace this capacitor by desoldering the two leads into the board and replacing with an identical part you can pick up at Radio Shack for a couple dollars. My repair for this identical problem was a success. The blinking light is the tip off for this particular problem on these Phillips models.
Oct 08, 2009 | Philips DVP642 DVD Player
Same problem. red light flashes 3 times, but will not turn on.
The blinking light means the controller QA01 in the AV_TERM system board is booting and driving the TIMER/REC RED LED light accordingly. This failure mode is true for many conditions, not exclusively for the main PS board PE0071. It could be caused by many things, LOW B, SEINE, AV_TERM, LCD, PROTECT, etc.
Specifically for PE0071+12VDC circuit failure, which is the most common , listen for the LINE relays SR80, SR81 coming online. If several (3) or more clicks are present when applying power to the TV set then suspect the +12, 20, +32 VDC inverter is faulty.
As a quick check, you can disconnect P807B. If the relays cycle every 1-2 seconds then is most definitely the +12VDC inverter. Check for voltage level at optocoupler Q881 pin 4 and this should not be cycling. This point is the VCC for the oscillator. Repair or replace board 75002913 as necessary.
TROUBLESHOOTING: (this is my own, not the OEM !, try at your own risk!)
  1. Check for LINE1 input voltage level at inverter on sheet [4].
  2. Check for LINE2 input voltage level at inverter on sheet [3].
  3. Check for STBY +5VDC & +25 VDC ( observe correct GND REF) page [4]of PE0071 POWER
  4. Check for +22 VDC out of regulator on page [3] out of Q822 Emitter
  5. Check P809B connector for :
  • P809B (12) POWER = 3.00 VDC (+/-0.2)
  • P809B (11) POWER_SIG = 0.00 VDC (HIGH to Power on TV)
  • P809B (10) PROTECT = 0.00 VDC
  • P809B (9) ACDETECT = 3.00 VDC (+/-0.2)
  1. Check for PFC_OUT = 368-371 VDC
  2. Check for +12, +20 & +32 VDC inverter page [5] of schematic manual.
For +12 VDC Inverter, suspect components:
Q880 STR-W6765 PSR (works really hot!!)
C888-C890
D884A and related switching circuit components.
Good luck,
mrwindex
Jul 03, 2009 | Toshiba 42HL196 42 in. LCD HDTV
Microwave ws cooking and I heard a funny sound. Now absolutely nothing..no power..nothing..?? wont even turn on...
Ok, this may have been the in line fuse that has failed or , the high limit capacitor may have failed as well. you will need to remove the cover, if possible, to inspect the power board. the hi limit capacitor is locate in proximity of the power board as well. the in-line fuse is on the board itself, connected to the power cord wires, via solder. if the fuse is in good condition, you will need to replace the high limit capacitor. it has failed.
Jun 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Generator dose not produce power,just stop working.
Check the rectifier board installed under gen cover that powers the brushes. This board has a capacitor about 1 inch long and 3/4 inch dia. If the capacitor looks swollen or burned replace board or carefully remove cap and replace with similar. You can use a larger capacitor with same rating, just tie cap to rear cover. Also check the condition of the brushes. Parts are not too expensive. Check with jacksmallengines on the web for parts. enjoy
Dec 04, 2008 | Coleman Powermate Premium Plus 6250W...
Sylvania 6842-PEM 42 in
If you are certain that the capacitor is OK, there could be a different problem on the main power board or even on the sub-power board. The sub-power board should have output voltages even if the main power board is defective.
Jul 17, 2008 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
TV power supply problem
.01 mf 2000 volt. in flyback circuit .it is a timing capacitor. the red high voltage block is bad and that took out the capacitor. also check the horizontal output transistor...it is probably shorted.
Aug 25, 2006 | Sony KV-27V26 27" TV
Apex Digital AT2702 27" TV Logo
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
