Question about Dryers
Dryer stop heating.
An older whirlpool clothes dryer that was in a home I just purchased stopped working shortly after the home was purchased. It still tumbles but no heat is present. Is it possible it is just the "snap thermostat" located on the housing surrounding the heating element or would the element be faulty as well. The snap thermostat appeared to be "fried" by visual inspection. I used a circuit tester on the snap thermostat and on the element. I received a positive indication on the element only. Should the snap thermostat read positive only when warm or at all times. Should I replace the snap thermostat only or both the snap thermostat and the heating element as well.
  • 5,911 Answers
First of all, please include your model number when posting questions as all dryers are not configured the same. I'm not sure what a "snap" thermostat is, but I do know that almost all electric dryers come equipped with either a thermal cut-out, thermistor, or thermal fuse that can cause the heat to fail if blown. These components generally have a low resistance reading (close to a short) and must be replaced if bad. They cannot be reset as many consumers often ask.
A reading of the heating element is about 15 ohms or less on most dryers. NOTE: Make sure you UNPLUG the dryer before servicing, as dangerous voltages are still present even with the dryer turned off. In addition, make sure you disconnect any wire leads connected to components you are testing to isolate them from parallel resistance paths.
For a Whirlpool that still runs, but does not heat, this problem is usually attributed to a defective Thermal Cut-Out (TCO). If the TCO is bad, it is strongly recommended that you replace the Hi-Limit Thermostat along with it. The manufacturer often sells these two components together as a set. If you choose not to replace both components, it may lead to premature failure.
Now...if the TCO has failed, it's generally for a reason. This component protects the heating circuits from an overheating. Most heat related problems are attributed to poor ventilation. Eventually the unit will overheat to the point of failure. If you cannot remember the last time you had your vent ducting inspected or cleaned, I would recommend doing so before you replace any defective components. Leaving a dryer in a clogged condition will result in poor drying or premature failure of replaced components. The following link may be used for assisting you in determining the cause of your dryer heating problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you have questions, or require additional assistance, please let me know. I hope this helps you resolve your problem.
Posted on Jan 14, 2009
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
No heat
Try testing the voltage across both fuses. The time you swapped fuses, and the motor ran without heat indicates to me that one of your hot leads is not getting voltage. On a three wire system, you should have two 110v leads and a common. Make sure that the cord is connected properly, and the same for the receptacle that you plug into. Test the receptacle as well for proper voltage and a good common ground.
Hope that this helps. Please repost if necessary.....Operators are standing by......!
Regards, --W/D--
Jul 18, 2009 | Whirlpool Dryers
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whirpool dryer won't heat up
You need to replace the thermal fuse and the timer. A bad timer will over draw a thermal fuse and cause it to blow.
Please remember to unplug the dryer before servicing
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
My Dryer has stop producing heat
hi mark it the heating coil in the back of the dryer
Feb 10, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer runs but does not heat
the problem could be the wiring in the house. the dryer not only needs 220v but also a good ground/neutral. this is a common misunderstanding when people test their outlets with a meter. this is happening too frequently to be a problem with the dryer(s)
9bed73e.jpg pic borrowed from fixitnow.com
Aug 02, 2008 | Whirlpool LER5636P Electric Dryer
We have an Estate Whirlpool clothes dryer/Model #MY60-G which was purchased (I think sometime in 2002?). It spins, but after it is on for a little while the heat stops and the clothes never dry. We were...
gas dryer ? replace the 2 coils on gas burner the 2 black round dohickys..electric possible bad operating thermostat remove back round object on blower housing
Jul 08, 2008 | Whirlpool Dryers
Whirlpool dryer - element heats, then shuts off quickly
Sounds like you have a stopped up vent on your home, when the vent gets stopped up the dryer can't circulate the air properly in the dryer and causes it to get to hot which causes the high limit thermostat to kill power to the element. If you need more help with this visit the link below:
Appliance Repair Guides
Mar 18, 2017 | Whirlpool Dryers
Dryers Logo
96 people viewed this question
Top Dryers Experts
