Question about Kenmore Elite 45986 Front Load Washer
My machine is "froze" and won't let my clothes out!
Off and on for awhile it would blink "sud"-I would clear and restart and it seamed to be fine. well it happend again and after pushing clear(so my stepdaughter says) it went to start back up and flashed delay-now it looks like it's ready to start, it will let you choose different wash cycles, but it will not start, it will not clear-I even unplugged it for awhile-it will not do anything!!! Now there are clothes stuck inside!
  • 1 more comment
  • wholub Jan 14, 2009
    I don't think it has been 30 min. yet-I will try that and let you know what it's doing-I was thinking of cleaning the pump, etc. as well?
    still the same- no error code now only flashes the cycle time-but wil not start-clear anything except let us change settings etc.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    How long did you unplug the washer for? The manufacturer recommends unplugging the unit for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). If the washer still does not operate after performing a reset, look for any error codes on the front panel display and let me know what they are.
  • 5,911 Answers
Just let me know what the results are, and if any error codes appear. The "SUD" error can be caused by obstructions in the drain pump and/or using too much laundry detergent.
Posted on Jan 14, 2009
  • Jeff Rockwell
    Jeff Rockwell Jan 14, 2009
    Is the control panel locked? If so, have you tried holding the "Drain/Spin" button in for three seconds to clear?
  • Jeff Rockwell
    By the way...if you need to get your clothes out of the washer and the door is still locked, the following link explains how you can access the manual release for the door:
    http://www.fixya.com/support/r622155-ken...
Rl on the control panel
The "rl" (remove load) error code appears when you are running the "Clean Washericon1.png" cycle. You must not have a load of clothes in the washer during this cycle. Remove the clothes from the drum, and restart the cycle. The "Sud" error indicates that the detergent is over-sudsing. The Duet washer automatically combats this by reducing the amount of suds in the washing machine. Let the washer finish the suds-reduction steps. Use less detergent during the next wash cycle.
Oct 21, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Car starts fine after sitting awhile. If you drive awhile then stop and try to restart it won't.
Check the electronics,cam sensor or crank sensor these are the culprits.
Aug 19, 2012 | 2006 Chevrolet Aveo
Dirty whites
probably your soap, or there is a soap contamination issue......run the machine without adding any clothing to it and see if it suds up or not....I'm suspecting you'll get suds...a little to a lot......if I'm right, then turn it to hot, and add a half gallon of white vinegar to it and let it cycle thru....repeat that for one more cycle...then test the machine one more time for suds without adding any cloths or products to the wash......if the suds are gone or just reduced, then keep repeating til the water runs clear
and to clean the dirty whites, try washing in cold water first, then hot..and obviously the whites with just whites, no colors allowed.
once you clear up the extra suds, try CHARLIES SOAP....it workd great and helps keep the machine clean
Apr 22, 2012 | Zanussi F1245W Front Load Washer
My front load washer won't spin fast anymore, any solutions out there?
A leading cause of clothing coming out very wet(not spinning on high speed) is over sudding (too much detergent being used) to see if that is the case start the washer without clothes and see if there is build up of suds (there should be NONE) to clean over sudding run a cold water wash and add a cup of white vinagar that will clean the build up of suds
Jul 18, 2011 | Washing Machines
Last night I tempted to clean the large duet washer with the chlorine program. After starting, I realized I only had clorax bleach for colors and reluctantly used this. Large suds formed. I paused/cancel...
Drop your drain hose to floor level with bucket under it this will drain with no power applied , pour in as much water as you can to flush it out / clear pump .After all suds clear refit / restart ..Should now fill, wash/ empty and spin...I hope ...
Apr 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Suds error
http://www.servicematters.com/maytag_library/docs/16025909.pdf
Here is the service manual for your machine.
When you get the suds cleared out you must use H E soap and or less soap.
You may need to run 3 or 4 cycles with no clothes at all to clear out the existing suds.
Mar 11, 2010 | Maytag Neptune MAH9700 Front Load Washer
Whirlpool Calipso Clothes Washer (yea, that one...) Trouble code ''CA'' means I have to remove tiny cloth clog that faults the water pump, (I'm getting good at that one), but now I have a ''''SL''...
SUDS LOCK:
The motor controller senses a suds lock condition by analyzing the current draw on the drive
motor. If a potential suds lock is detected, the control tries up to 3 times to clean out the unit
with a mini-cycle. See Use and Care Guide for more information.
“SL” is displayed if suds are detected but the unit is unable to clean out suds. This may
indicate a bad pump, an extra heavy load, excessive detergent or excessive suds.
Press STOP/CANCEL to clear the display. MANUAL
Sep 13, 2009 | Whirlpool Washing Machines
Sounds like your pump is clogged. Ill be posting a tutorial at www.shop.washermd.com tomorrow for this fix. Dave
Jan 14, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso Washer
I'm in the process of tearing apart my Calypso, Ugh. I found the diagnostic chart inside the machine. 5L is actually 'SL' which means suds lock, and can be an indicator of a failed pump, an extra heavy load, excessive detergent, or excessive suds. Corrective action is to press Stop/Cancel to clear the display.
Mar 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Wont start and says "SUD"
yes I can the suds is from too much soap it will go thru a flush cycle and should go away after 4 min of opert. let me know if it does not clear you may also get a LD code on the machine to clear press cancel twice
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
115 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
