Question about GE Refrigerators
No water from dispenser ice works fine
GE GSS25JFPD GE Refrigerator New water filter and line is not pinched
My water outlet was frozen and wouldn't let the water through. Turn the fridge off and let it thaw out if this is the case. Regards, Phil, Brisbane Australia
Posted on Jan 14, 2009
Hi, I have a GE pcf23ngtd side by side. It makes ice fine, but it doesn't dispense any ice and intermittently dispenses water. Any thought of what the problem is?
you have a pinched water supply line -
not sure on why it would not dispense ice unless there is some blockage or other -
did you remove all the ice tray and fully inspect the dispenser at both sides of the door -
Feb 13, 2011 | GE Profile CustomStyle PCF23NGT Side by...
My ice maker is working fine. My ice dispenser is working fine, There is no water from the water dispenser. When I push the button, I hear a click but no water.
I had this same issue with my GE refrigerator and figured out it is a common problem with these units. The water line freezes up near the dispenser panel. Fortunately, GE has an inexpensive solution, a water line heater, that fixes the problem with little work. Check out my blog post on my ge refrigerator water dispenser not working for complete details.
Oct 28, 2010 | GE GSH25JFR Side by Side Refrigerator
Not getting any water out of my dispenser. The light indicator is on but when I push in the dispenser lever no water comes out??? My ice despensor is working fine, Indicator lights are working fine. I...
I have the same problem with the same refrigerator, call up GE Customer Service and tell them that you want part number WR49X10173, a water dispenser heater kit. They should sell it to you for a "discounted" price of $25. Good Luck, and don't ever by GE anything ever again.
Jan 15, 2010 | GE GSH25JFT
Water dispenser not working. Ice dispenser works
There should be a water filter inside the water lines to the water spout. This filter could be clogged, or the water lines themselves may still be somewhat frozen and not allowing flow to the dispenser itself.
You can also test the power to the dispensor to make sure it is drawing water. Can you hear the pump trying to pump water to dispenser? The water valve should also be opening. You can test power to the valve that draws in water from the external water lines.
Nov 25, 2009 | GE GSH25JFR Side by Side Refrigerator
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
GE GSS25SGRE side by side water dispenser...
The same thing happened to me. If you pull the refrigerator out and remove the large silver panel, you will see the water lines on the left. The line going to the ice maker was fine, but the line going to the water dispenser was split. You may have the same issue.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Water/Ice Dispenser is not working
at the very least replace that water filter.clogged water filter will reduce water pressure to the line.
Feb 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
310 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
