Question about RCA HD56W66 56" HDTV
I was watching tv and it went 3 demindional,
I unpluged the tv from the cable box. Now i have a red green and blue line at the top of thes screen that arches downward in the middle
  • nriffee Feb 12, 2009
    Same problem as above problem> Any answers?
  • gasssman2005 Feb 16, 2009
    I don't have the option for convergance nor the ability to adjust
  • RCA Master
  • 5,138 Answers
Go to menu then setup if you do not see convergence on menu then you have an open fues FL231 it will be middle Fuse located on right side of FBT flyback transfomer there is 3 of them in a roll small brown looking caps but are Fuses.
Posted on Feb 16, 2009
I have a 2011 Panasonic plasma tv I bought new in 2011 and today there is a red/blue stripped line 1-1.5 inches wide across the top and a dotted green/purple line 3-4 inches below the blue/red line.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jan 17, 2017 | Panasonic Televison & Video
Frozen screen
Unplug your cable box from the wall outlet. Wait 3 or 4 minutes and plug it back in.....TV should now be normal.
Sep 06, 2014 | Televison & Video
My LCDTV has a problem, Model number is 6626LCT, Now on to the problem, While doing yearly cleaning on my tv as normal, after i plugged it in it was normal for 40 seconds, It flickered and the screen went...
Only suggestion is if set was plugged in when you did what you did--unplug it and any box or receiver plugged in and wait a while--plug back and let the equipment try to reboot.
Jun 06, 2012 | Sylvania Televison & Video
The color on the screen is green when I watch movies. How do I fix this problem?
Good day sir, your inquiry about the green lcd screen can be caused by several things. 1. The monitor/tv produces 3 colors, red green and blue, the tv mixes these three colors to produce the picture. a loss of red and blue produces this green screen. so check the cable, specially the red and blue jack of the component inputs, and the red and blue cable. 2. there may be loose contact on the signal cable. try using the video input instead of the component input. 3. the dvd player may have the problem, check the player component out jack. a loose jack port can cause these problem. hope this may help. thanks
Jul 20, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
RCA Projection TV Model HD61W66
convergence power supply not working , there is a mini fuse close to the flyback thansformer , 400miliamp at 250 v resolder the flyback and replace this fuse , there is 3 fuses it look like small squer brown color is the one on the middle , normal repair $200 - 300
May 07, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Unable to properly connect sony dvd to tv to play movie
DVD-3 RCA phono outputs(red & white=audio,yellow=video
I have a DVP-NS700,the same happens on mine.Turn it on,goes green to red(standby),then press eject,it will then power up properly.
Jan 03, 2009 | Sony DVP-NS300 DVD Player
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
LCD TV picture is green
I just called Vizio and they said to unplug the TV, then physically hold in the power button on the TV for 2 minutes.
Nov 19, 2007 | Vizio L37 Television
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
RCA HD56W66 56" HDTV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
