Savin sdc410e touchscreen
We have a Savin SDC410e and a co-worker has done something to it to make the touch screen stop working when he went into the service mode to try to clear a error code. He said he cleared the nvram. Thank you for any help
  • 227 Answers
If you cleared NVRAM and you did NOT back it up!!! You may need a new Controller!
Posted on Mar 28, 2009
Savin mp C2503 Service programs
Try this yellowclear button 182806 clar/stop button hold down till screen changes.
Feb 13, 2015 | Savin Office Equipment & Supplies
My SAVIN 2820 SCAN FUNCTION does not connect to my home network.
If you have updated your OS to Vista, Win 7 or Win 8, update the firmware
Oct 15, 2012 | Savin Office Equipment & Supplies
Good morning, I'm Yesid of Colombia, and I have a savin 8035, and the problem is that part of the touch screen serponde no, the other functions are normal. and provided with clear and cccccc 1993 option 1...
looke man first press 1993 and press five cancel red application option revealed to yo ok choose touch screen test open it and press on screen many times in every were in screen ok good luck
Jan 04, 2011 | Savin 8035e Copier
Touch pad control panel on Savin c3030 doesn't work - the rest of the control panel buttons do just not the touch pad for any function?
Hello.I can ASSURE you absolutely what the problem is.Your Savin copier(which is a perfectly fine device) is actaully manufactured by Ricoh.I work for a Savin dealership and Ricoh contacted all dealers WORLDWIDE with the news that due to a manufacturing defect that the touch screens of al models such as yours WILL fail.They sent out free of charge replacement touchscreens to all dealers as they have a record of how many of what type was sold by whom.I mean we had a crate of touchscreens show up at our dock at about the same time we started to get a barrage of service calls for this problem. It was one of the wildest things I've seen.Now it is just the "glass" of the touchscreen that is defective as it actually an "active" part of the op panel's circuitry of the op panel.It is relatively easy to replace.Now the question is, how do YOU aquire one,as it is a known defect and is covered by warrranty.I have to assume you purchased this device on your own and that you do not have a service agreement thru an independent dealer.My advice would be to contact whomever you bought the device from or perhaps Ricoh directly and tell them the problem and that you are aware that Ricoh is aware of the problem and see what they say.I cant tell you how many of these things I have had to replace as it is not a matter of IF there will be a problem with the Savin c3030 touchsreen, but merely when.Good luck, and although I did not "FIXYA" I hope you will acknowledge to the sight that I gave you the facts that you need. :-) Take care
Jun 22, 2010 | Savin Office Equipment & Supplies
How do you reset the savin 8035 sc542 code after thermistor is replaced?
Press the yellow button ( reset button ) then press 107 then press and hold the red button (stop button ) for about 3 sconds until the display changes. Touch copier on the display screen. Now turn the copier off using the on off switch on the left front side of the copier. If the cold comes back the Thermostat in the fuser is most likely tripped and would need to be replaced.
Apr 29, 2010 | Savin 8035e Copier
Savin 9940DP ''Set Key Counter''
Key counters are used when a copy machine is set up for public use where copies are charged on a per copy basis. Key counters look like small boxes that plug into the side of the machine and they have a counter on them that looks like a cars odometer. A user plugs in the key counter, makes copies and then takes the counter to a register to pay for the copies they made. Sounds like that is what you have going on.
Nov 02, 2009 | Savin Office Equipment & Supplies
Trouble mapping Savin to network folder on computer
you will need to have the folder shared on the desktop. you will need user name and password. go to user tools. system settings. administrator. address book. create new user. in new user program, go to folder. enter computer name. browse network. you then enter user name and password for pc. should be done
Oct 21, 2009 | Savin Office Equipment & Supplies
Savin 9935DPE document feeder maintenance
GO ONLINE TO SAVIN: TYPE THE FOLLOWING INFORMATION:
WWW.SAVIN.COM/SERVICE_MANAUL
/TECH_SUPPORT
/SERIVES
/HELP?
CALL SAVIN ASK TECHICAL SUPPORT, ASK FOR A TECHICAIN THAT REPAIRS OR FIXS THAT TYPE OF EQUIPMENT AND EXPLAIN THE PROBLEM AND SEE IF HE HAS ANY IDEAS YOU CAN TRY BEFORE YOU GO OUT AND SPEND ANY TYPE OF MONEY ON THAT PART.
ROD
May 12, 2009 | Office Equipment & Supplies
42 people viewed this question
jasbo
jasbo
