Question about Sony KP-65WS510 65" Rear Projection HDTV-Ready Television
Bad picture when i turn the tv on.the picture turns a dark red. the picture and sound are still there but can barley see threw the red.what do i do?
    President:
  • 3,130 Answers
You have a bad picture tube or a bad driver signal that drives the CRT. Could be a bad capacitor in the boost voltage circuit also. if you have no TV repair experience, contact an Authorized Sony repair center to have a look and assist you in the repair of this TV set. Good Luck
Posted on Jun 13, 2007
TV picture is dark but has sound, did flashlight test and can see a faint picture.
Usually means inverter or power board is bad! Check power board for voltages. Voltages are usually printed on the header port. if Inverter is bad panel would need replacing. If TV is less than or equal to 12 months contact Samsung for warranty repair.
Oct 19, 2015 | Samsung Televison & Video
The red light turns on but no picture comes on
Get real close to screen and maybe use a flash light to shine on the screen and see if you can see the picture still, it will be dark and almost not visible but you should notice something move. If your screen has picture then you most likely have a back light problem. Most common problems are bad inverters, or the inverter controller card. possibly a bad power supply but most likely inverters, test each circuit, replace as needed.
Sep 17, 2012 | LG Televison & Video
I have a 32inch Westinghouse LCD TV that is dim/dark/low light. i can still see the image in shaded areas of the house. whats the problem i did some reasearch on the web and think its something that has to...
You need to replace the inverter board. The lamp failing is very uncommon, moreover LCD Tvs have more than one lamp, and they do not fail all at once.
The connection cable from inverter to main board must be tested, the inverter must be tested, then the inverter must be replaced.
If you DIY remember that the inverter is an high voltage board.
Jun 25, 2009 | Westinghouse Televison & Video
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
Picture suddenly turned dark
hi the picture tube of ur tv has got damaged and it badly needs a replacement.. so its better to replace ur picture tube..
thank u rate me!!
Feb 08, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Red Lights on the Power button blink and picture goes dark
60PL9200D/37 When I unplug it for a while and turn it back on, the picture starts to come on, but it turns dark. And the red lights on the left and right side of the power button blink. Sound but no picture.
Feb 02, 2009 | Philips 60PP9202 60" Rear Projection...
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No picture but has sound
The problem can be caused by a bad sustain board (Ysus Zsus) , the popping sound is often caused by a capacitor blowing up.
The TV must be taken apart and tested before eventually replacing sustain boards.
Apr 27, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Blue and white picture
It sounds as though you may have a bad red convergence chip. If it's not the chip, you may have a bad Red CRT ( Picture Tube ). You may want to obtain professional assistance unless you have the proper test equipment to check these items. I hope this has helped in some way.
Ed
NC Electronic
Mills, Wyoming
Have a Great Presidents Day
Feb 05, 2008 | Toshiba 55H70 55" Rear Projection...
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Sony KP-65WS510 65" Rear Projection HDTV-Ready Television Logo
85 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
