MAG 780 LCD Monitor takes 10 minutes to come on when cold.
When I boot up my desktop, the monitor won't even blink for about 10 minutes. I have to keep pushing thepwoer button to see if its ready. The green power light comes on, then goes off, so I have to constantly press it to see if its ready. Eventually, long after the cimputer has booted ( presumably), I press the power button and the screen is on. If I restart, there is no delay, and if I boot after a short time, there is no delay.
  • jfellows Jan 14, 2009
    The power supply, I assume, is a separate black box in the power cord that drops the voltage from 120 to 12 volts 5 amp.
  • jbachorz May 11, 2010
    Sounds like the power supply has gone south. It works after a while because a thermally sensitive component heats up. Does the unit have a separate power supply, or is it integrated into the unit?
Power supply is going in it. if you know of someone technically inclined have them check for bad capacitors in the power supply. this is typical of one that is dryed out and not letting the power supply start up as fast as it should. if it is just capacitors then it should not be an expensive fix, but don't ignore it as other parts will be stressed and fail making it much more costly.
Posted on Jan 14, 2009
MAG LT765s monitor, model 780; where do i plug in adapter
Sometimes the power adapters on flat screens face the floor. So, if you look under the screen under the stand, you will likely see the plug.
May 22, 2010 | Mag Innovision InnoVision LT765 17" Flat...
Power supply to Mag 780 Model
No, it has a normal, seperate power cord. But the socket in the monitor is very small, it's a small round one. When facing the monitor from the back, it's located directly to the right of the monitor-stand, at the bottom-side of the screen. Just put the monitor on it's side to see it clearly.
It's all explained with pictures in your monitor's manual which you can download from the official website here: http://www.maginnovision.com/Support/Downloads.aspx?sn=464
Aug 23, 2009 | Mag Innovision LT776s 17" LCD Monitor
Monitor to black, power LED blinks, hard re-boot and it works
Take a look at your power saving settings. It sounds like the monitor is set to sleep after 20 or 30 minutes. You may want to change your setting to "never". The settings are under Control Panel - Power management
Aug 15, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
MAG 780 Innovations LCD Monitor
The plug end (to the monitor) is a partial square end with three top angles. That plugs into the back of the monitor. You can see the plug socket from the underside.
Jan 29, 2009 | Mag Innovision LT776s 17" LCD Monitor
Mag monitor doesn't display bios post
The BIOS is sending the display information to the monitor but, when you turn your PC on, the LCD will be sleeping and it will take 1~2 seconds to wake up when receiving the display signal. The monitor is working and even if the BIOS messages aren't displayed, you can still press the correct keystrokes to get to the SETUP screen or press PAUSE in the keyboard to see what's going on in the POST.
If your LCD has a bicolor LED indicating the status (Standby/On) keep looking at it, when the LCD gets the video data, the LED turns instantly from amber to Green or blue even if the screen is still black. This way you can have an idea when the LCD gets the initial video signal and to press the keys accordingly.
Your PC will also delay the video output from the secondary video card because it's detected after the onboard card.
May 03, 2008 | Computers & Internet
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Mag Innovision product # LT765s model #780
monitor is looking for the video signals--move mouse and try power on
Jan 07, 2008 | Mag Innovision LT776s 17" LCD Monitor
MAG monitor is all white
please change your ram immeditately or monitor itself because the life of monitor has been came to an end...
Dec 31, 2007 | Mag Innovision InnoVision LT765 17" Flat...
I need this information please
Try this site. I suspect however spares are not available. http://www.fixya.com/support/mag_innovision
Jun 02, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT776s 17 in. Flat Panel LCD
I have the same problem except it usually happens after Ive left my computer idle for a while... i.e . Overnight, I usually turn off the monitor and I hit the button after I come back to turn it on. I get the same flashing light for several minutes. This has been a problem for several months, but only recenly have i gotten the same error message you mentioned. Each time ive booted the computer up cold or restarted it has worked fine but this time it took longer along with displaying the message: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05 Anyone else who can clear this up?
Mar 04, 2007 | Mag Innovision LT776s 17" LCD Monitor
Computers & Internet Logo
567 people viewed this question
David Payne
David Payne
