Question about Steam Fast SF-465 Canister Vacuum
Brand new Steamer.. Worked less than a minute and shut off Trying Model sf 465
    Genius:
  • 2,920 Answers
Take it back to the stor where you bought it and get another one or get a refund.
Posted on Jan 14, 2009
Forgot what kind of water to use - distilled or other wise can not find manual, can I get one - Model GS7RW Thanks, Susan
hi.
i am assuming it is the GS7RW garment steamer and not actually a vacuum cleaner.
any electrical item with a heating element should be used with distilled or de-ionised water.
if you live in a "hard water" area where the water contains dissolved calcuim salts, these will cause scaling and furring up of the heater element. easiest way to tell is to look inside your kettle. if there are white deposits on the base or heating element, your steamer will get the same deposits and work less effectively.
another option is to use the scented ironing waters available from many supermarkets for use in steam irons. these will not harm your steamer, and will also make your clothes smell nice as they come in a range of scents.
this link does have some instructions that may help.
http://www.conair.com/instruction_booklets/06PC2349%20gs7rw%20IB.pdf
Jun 14, 2011 | Vacuums
Shark Steam Mop - Gray/ Purple Vacuum: My shark steamer is heating up but not steaming. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
May 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My Europro shark steam mop won't steam, light on but no steam.
Hard water deposits. I ran some white vinegar through mine, like a coffee maker, and it worked for a while, but clogged again. So I unplugged it, let it cool and turned it over in the bathtub and squirted a small amount of Lime-Away into the hole where the steam comes out. Let it soak for 5- 10 minutes and it is working like is is brand new.
Sep 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
CAN,T REMEMBER WHERE THE WATER GOES
Please open the top white lid and unscrew the top black knob with instruction on the back of white lid.
May 11, 2009 | Steam Fast SF-250 Mouse Vacuum
Euro-Pro EP923 CANISTER STEAMER SF169E FUSES NEEDED
You are right, this is a very difficult part to find. I was able to find one source for a compatible thermal fuse, it is a non-stock item, will require special order of a min of 5 fuses at .81 ea plus a 10.00 handling fee and probably shipping. All the info is at this link.
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=090SPEC&MPN=SF+172+A&R=090SPEC&SEARCH=090SPEC&DESC=SF+172+A
Hope this helps.
Please take the time to rate this solution.
Thanks for using Fix Ya.
clarkco
Feb 06, 2009 | Euro-Pro EP923 Canister Steam Vacuum
I HAVE A BRAND NEW HOOVER MACH-3 CYCLONIC THAT CUTS OFF EVERY FEW MINUTES. IT IS DRIVING ME CRAZY! IT'S LIKE AFTER 5 MINUTES OF VACUUMING IT HAS TO SIT FOR A LEAST AN HOUR THEN YOU CAN VACUUM FOR ANOTHER...
If it were mine and it was brand new I would bring it back and exchange it. It sounds like the motor is over heating and shutting off automatically. Does not sound good. My advice return it.
Mar 16, 2008 | Vacuums
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Lost Manual
You didn't mention brand or model #, but try going to the manufactures web site and see if they offer manual downloads.
Oct 31, 2007 | Euro-Pro Shark SC-505 Handheld Steam...
Steam Fast SF-465 Canister Vacuum Logo
Top Steam Fast Vacuums Experts
Are you a Steam Fast Vacuum Expert? Answer questions, earn points and help others
