Question about Brother LS-1520 Mechanical Sewing Machine
Brother LS-1520 thread/timing issue?
My sewing machine's timing appears to be off. At least that is what I believe it to be. One thread stays straight in the fabric while the other goes up from the bottom and catches on that. The other one like I said stays straight and does not get pulled through the fabric at all.
I need help and need to try and fix it myself, please someone help me out if you can, I would really appreciate it!!!
  • 1 more comment
  • joandawg8 Jan 14, 2009
    It is straight on the top. When I'm looking at what I've just sewn, it is straight on the top of the fabric.
    Thank you for responding!!
    how do i do that?
    i've turned the tension knob on the top, that doesn't do anything.
  • Jeremy
    Jeremy May 11, 2010
    Is it straight on the top or bottom of the fabric?
  • 65 Answers
Increase your bobbin case tension
Posted on Jan 14, 2009
What causes the bobbin thread not to connect with needle thread
make sure the needle is inserted correctly into the needle holder
and pushed all the way up
make sure the bobbin is turned the right way in the bobbin case
also the sewing machine could have a timing problem
Feb 14, 2013 | Brother LS-1520 Mechanical Sewing Machine
LS-1520 Brother sewing machine hook pick thread up takes it around half way and gets stuck...any ideas. the timing seems to be right??!!
try changing needles
clean under the needle plate & in the bobbin area for loose thread or lint
make sure the bobbin is inserted into the bobbin case correctly--if the
machine won't pick the thread up from the bobbin correctly take the bobbin
out of the case & turn it around & try it that way.
Apr 13, 2012 | Brother LS-1520 Mechanical Sewing Machine
I WAS sewing and my needle hit a pin and know the top thread will not catch the bottom thread
Hi joanncastro6...
Sounds like you have a bent needle...I recommend that you replace your needle and that should solve your problem.
Please take time to rate me
Jul 31, 2011 | Brother LS-1520 Mechanical Sewing Machine
Brother LS 1520 I was in zig zag mode and broke a needle. Now that I have replaced the needle, the needle thread will not pick up bobbin thread.
Are you sure that you replaced your needle right? The flat side must face the rear of the machine and did you put your needle on a straight stitch? I hope it didn't mess up your timing. But try this and I have my fingers crossed for you that it is something simple.
Dec 11, 2010 | Brother LS-1520 Mechanical Sewing Machine
My brother LS-1520 sewing machine is having major tension problem
Try some metal bobbins, #15 or SA 156. that seems to help. If, you don't have a manual go to brother.com and download one for free
Jul 19, 2010 | Brother LS-1520 Mechanical Sewing Machine
The machine is a new, never been used before brother 1520 mechanical sewing machine. The top thread keeps jaming up around the bobbin and it appears to me that the thread is catching on the metal plate on...
Driver?
Refer to the manual for threading and bobbin winding.
Make sure the bobbin is properly installed.
Graphics are always good to have, but sometimes important steps can be missed. Be sure to read the instructions.
Open the manual and lay it next to the machine and follow every step of every feature. No matter how experienced, it is important to learn the ins and outs of every machine you intend to use.
If the problem continues, return the machine.
Mar 10, 2010 | Brother LS-1520 Mechanical Sewing Machine
I would like to adjust the timing on my sewing machine it is not picking up any more can you send me instructions for a brother ls-1520
with the timing you are better off to taking it to sewing machine mechanic it may cost you more by doing it yourself
Nov 24, 2009 | Brother LS-1520 Mechanical Sewing Machine
Threading and Bobbing
http://www.brother-usa.com/manuals/default.aspx?ProductGroupID=3&WT.cg_n=Support&WT.cg_s=Manuals
Apr 07, 2009 | Brother LS-1520 Mechanical Sewing Machine
Brother won't sew
My Brother machine is sensitive. You may have already done this, but...
Rethread the top, following diagrams and instructions precisely.
I have taken the front off the machine to find a nest of thread in the upper part of the machine.
Remove the bobbin and bobbin case, and reseat both.
Check the needle. If it is bent even slightly or not seated well, the whole needle shaft can lock up.
FAQs Troubleshooting LS 1520 Others Brother
Aug 11, 2017 | Brother LS-1520 Mechanical Sewing Machine
Brother LS-1520 Mechanical Sewing Machine Logo
242 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
