Question about Mitsubishi WT-42311 42" Rear Projection Television
Mitsubishi WT-42311 DLP Bulb Replacement
I need to find out where to locate and how to replace a bulb for a Mitsubishi WT-42311 DLP TV.
  • Anonymous Mar 27, 2014
    Connected a digital antenna to my Mitsubishi WT-42311 TV but got no signal. Owner's Guide calls it a digital TV but do I need a digital converter?
  • 34 Answers
Your access should be a a panel near the back or side. You will see that it is somewhat easily removed and should have maybe one or two screws. You will see the casing to the lamp. Go ahead and remove it. Now unscrew the old bulb and replace it with a new one. There is not a lot of screws holding it together. It's a fairly easy process once you find the lamp. You should see the lamp once the panel is removed.
Posted on Apr 27, 2009
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
Apr 20, 2016 | Hitachi Televison & Video
The TV shuts off as soon as you turn it on.
You need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 12, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi tv model wt-42311, error code 2-2. what can i do?
2,2 IS short protection and 95% chance it means one of the two pico fuses that protect the convergence IC chips are bad.
This model uses two of the chips: STK-392-110 and you would have to pull the light box out to replace them safely (total parts cost will be under 30 dollars).
It involves getting at the chips and the fuses and replacing them: how much skill do you have?
SD TECH
Mar 25, 2010 | Mitsubishi WT-42311 42" Rear Projection...
I have a Mitsubishi WT-42311. Last week the
where you saw blue it sounds like your blue crt is shorting out could be just the video amp so
i would suggest you have a tech look at it for and estimate
Nov 24, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Replacing a bulb in a mitsubishi rear projection tv
Are you sure tube is bad and that projecion fluild isnt contamiated if tube lights up but you can not see a picture clearily or at all fliuld is bad remove old fluid replace with new problem FIXED Call Mats for projection fluild 1-800-628-1118
Sep 18, 2009 | Mitsubishi WT-42311 42" Rear Projection...
I have a mitsubishi 1080 series wt-42311 model. When I turn on the TV the green lite comes on then goes off? The TV wont turn on.
STKs,one of them controls startup if bad TV will not come on.STKs are big black ICs will have part# on them. call Mats for parts you have 2 replace both. 1-800-628-1118
Sep 18, 2009 | Mitsubishi WS-65315 65" Rear Projection...
No red in picture
A DLP set has a BULB sometimes crt's are called bulbs which in a way they are glass bulbs with phosphor and a vacuum
Sep 26, 2008 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
545 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
