Question about Linksys Wireless-G WRT54G Router
I need to know how to hook up my LInksys wireless-G broadband router. What wires hook where?
  • Anonymous Jan 15, 2009
    i get sign out of my Play Station Network ever time i quit a game
  • Linksys Master
  • 4,338 Answers
Connect a network cable (cat5e cable) from the WAN/Internet port to your cable modem. Then connect a network cable from any port on the router to the computer's network port.
Then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jan 14, 2009
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
Hey, need help here. Got linksys wireless-g
the great thing about the linksys brand is that they are owned by cisco and they will walk you thru the set up no matter when and where you bought that thing and they will spend all the time it takes to make you happy with the product. although the person you speak to will be in "new deli" india so they may need to repeat them selves many times.
have you tried access the router interface page with the computer hook directly to the router NOT wirelessly.???
I think I remember the linksys access page is at 10.10.10.100 in your internet explorer tool bar.
Jun 13, 2009 | Linksys Wireless-G Broadband Router
Need to hookup with 1 wireless and 2 hardwired computers
Here you go, step by step:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4055&p_sid=UcVbWIYi&p_lva=3967#
Click on this link or copy and paste the complete link into your browser.
Thanks, Joe
Apr 17, 2009 | Linksys Wireless-G Broadband Router
No internet connection
one wire which come from modem goes to the wan port of the router and other three goes to the lan port.
Mar 03, 2009 | Linksys Wireless-G Broadband Router
I don't know how to hook up my linksys to my dsl, do i hook to the dsl router or the computer?
i use linksys wireless router with model number IC: ID:- 3839a-w11s4v4
if i connect it to the ethernet on my computer the green light switch on
and it connect to the local area lane.
but i can not access the web page to confirger the router
Feb 21, 2009 | Linksys Wireless-G Broadband Router
Linksys wireless-g broadband is not hook up to comp. the cord from cable modem the by pass is on to the comp.
If you want to use the linksys, you need to connect the cable from the modem to the linksys, then use another cable to connect the computer to the linksys. If it does not work, call linksys technical support, if they cannot help try this http://technicalsupport.blog.friendster.com
Feb 18, 2009 | Linksys Wireless-G Broadband Router
I have just purchased the linksys wireless router and hooked it up according to the instructions numerous times. After putting the installation disk in it stays i am not hooked up properly when i know i...
Hi
Please refer the link http://www.linksys.com/servlet/Satellite?c=L_CASupport_C1&childpagename=US/Layout&cid=1166859678292&pagename=Linksys/Common/VisitorWrapper
it will provide EasyLink Connect tool. EasyLink Connect is a first-time setup application that automates the setup of your Linksys router, including:
  • Cabling Instructions
  • Internet connection configuration
  • Wireless connection and security setup
  • Other devices and computers addition
Please Vote if this is helpful
Jan 02, 2009 | Linksys Wireless-G Broadband Router
Wireless connection
Check the Linksys web site for the manual. Follow the directions. Linksys routers have very easy set up routines and are designed for the novice.
Oct 31, 2008 | Linksys Wireless-G Broadband Router
Wireless broadband
Hi Swanjr
No need to worry...In linksys there is a seperate router for Sprint..Exact model no is WRT54G3G.For reference u can visit this website.here is the link http://www.linksys.com...Hope this info will be useful..Let me know if u have any other queries.
Thanks in advance.
Jun 28, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
51 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
