Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony tv problem is that the picture is stretch horizontally..
My sony tv problem is that the picture is stretch horizontally i think about 1 inch left and 1 inch right...please help me...thanks!
for example the world PARENTAL GUIDANCE, you can view only the TAL GUIDANCE.
If you have a DVR too, there is a pound (#) button on the beside the zero on the DVR remote that stretches my screen off and on. Try that.
Posted on Jan 14, 2009
TV Picture reduces to a narrow horizontal bar
The vertical sweep output section circuit to your TV has the fault. Might be an IC failure, or with some loose solder points at the solder terminals to this IC. As it will be very difficult to detect the exact dry-solder point, it will be best to resolder all the suspected solder terminals to this vertical output section, by applying a little more solder to each terminals, without making any solder bridge short in between adjacent solder terminals.
Jul 30, 2012 | Quasar SP-2722 27" TV
#1 tv has black horizontal line middle of screen, fades away about 80% of the way from right to left. #2 picture is blurry and the colors stretch down in horizontal lines, then picture goes back to...
The tv board that called a T-CON board it is dying to causes these problems.All the tv pictures dots pixel codes go through this board before it show up onto the tv LCD sreen panel.This tv T-CON decodering board sit in the midle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.
Sep 04, 2011 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
HI, I was wondering if there is way to adjust the horizontal position on the screen of Sony KP-57WV600. By adjusting I mean a way to shrink the displayed picture horizontally or vertically.To give you an...
There is button "Wide Mode" on tv remote, press it repeatedly to select desired zoom mode to view best fit picture in screen.
Click Sony Support link to download user manual free copy and check page-48 for details.
Thanks.
Jan 06, 2011 | Sony Televison & Video
Kv-35xbr48 turns on fine nice picture then horizontal lines form distorting picture like interference also is the back hard to take off and put on needs a good vacum thanks for any suggestion
At first the picture is ok, and then distorted with horizontal lines i thinks. If the horzontal lines are parellel acros the screen, with an inch apart across the whole screen, your tv needs screen adjustments. Screen voltage may be high. look into the crt base also. Change it first. These also not resolve the problem, LOT may be faulty, with respect to screen focus pack. May need replacement. Try first setting screen voltage to a lower settings and observe.
Oct 14, 2010 | Sony KV-35XBR48 35" TV
Picture distortion
check the settings on the dvd as if you set the dvd to 4:3 format for instance, the picture will be "squashed" to a letter box format and when you play on wide screen it will become "morphed" and mishaped. also if the tv is set to wide all the time, then this will cause a stretching effect. set the tv to auto picture size or "smart" as it is on sony's, with auto 16:9 on.
Oct 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
SONY KV-DZ29M61 horizontal deflection problem
You cannot use sub parts on sony use sony parts only. Same with hori output transistors. USE SONY PARTS ONLY.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Horizontal Lines when Viewing HD TV
Would you please change the picture mode 4:3 or scan fit to 16:9?
Nov 19, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Screen stretched on JVC AV-28WT5EKS TV
There are some parts that have failed in the horizontal scan amplifier. You will have to have the set serviced by a TV service tech to determine the exact failed parts and have them replaced.
Jerry G.
Jun 27, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
230 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
