Question about HP LaserJet 2840 Printer
Printing half sheet
HP color laserjet 2840 and zI owe two machices and both are during the same.
  • 2 more comments
  • margaretjack Jan 14, 2009
    tried the solution that given and it didn't work, what else can I do? Both of my copier are printing on one side only. HP color laserjet 2840.
    I copy on both using computer and without using the computer, what next? are my machines both worthless?
    this solution didn't work
  • margaretjack Jan 15, 2009
    this was one of the solution already given and I did.
    Sergeant:
  • 221 Answers
There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For as hort fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Posted on Jan 15, 2009
  • 716 Answers
Are They Both Not Printing On The Same side With And Without The Computer?
  • Michael Fisher
    Michael Fisher Jan 15, 2009
    We Have This Answered On Fixya Already Click Here
    Thanks For Using Fixya
    Sincerely,
    Michael Scott
    Brigadier General:
  • 8,619 Answers
Hi
This can be caused by a number of things:
The fuser
The ETB
The toner cartridge
The firmware
The printer needs a cleaning.
The slot in the printer.
Incorrect Media.
Try cleaning the printer, use a lint-free cloth for the ETB, DO NOT touch the belt with your fingers, the oil from fingers will often make things worse.
Always use a lint-free cloth, if you ever encounter dirt inside the printer, dampen the cloth.
Calibrate the printer.
From the printer's control panel menu
Configure Device-> Print Quality-> Calibrate now.
(Press the Checkmark key to advance through menus)
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Jan 15, 2009
    To check if its fuser. Just put a sheet of paper in the manual feeder in the front of the ITB drawer. Print a configuration page and when the back edge of the paper reaches the bottom of the feeder, open the back of the printer to stop the printing. Now open the itb drawer and look at the unfused sheet and see if the defects are present. If they are it is not the fuser. If the defects are gone, then it is the fuser.
    Thanks
    Rylee
    President:
  • 2,110 Answers
Try following..
Figure 1: Smeared print sample
printing half sheet - c00182095.jpg Perform the following to remove the paper from the imaging drum.
  1. Remove the imaging drum from the printer.
  2. Rotate the black dial (jam clearance door lock), located on the top, left-hand side of the imaging drum, counterclockwise. Figure 2: Jam clearance door lock c00182096.jpg
  3. Lift upward to open the black jam clearance door near the green handle on the top of the imaging drum. Figure 3: Jam clearance door c00182097.jpg
  4. Remove the paper from inside the imaging drum. Figure 4: Paper removal printing half sheet - c00182098.jpgttp://i.fixya.net/uploads/images/c00182098.jpg" alt="c00182098.jpg" class="h_mi" />
  5. Close the jam clearance door, rotate the locking mechanism clockwise. Figure 5: Jam clearance door lprinting half sheet - c00182099.jpgism c00182099.jpg
  6. Reinstall the imaging drum in the printer.
NOTE: Do not touch the white sleeve in the imaging drum when removing the paper, as fingerprints will cause print quality issues. If necessary, use a lint-free cloth to gently wipe any fingerprints off the white sleeve.
Posted on Jan 14, 2009
  • HP Master
  • 19,396 Answers
That is probably not any software issue, both the machine have the same memory size , and they are going out of RAM because of the document format.
To find out if it is a software problem , print a copy without using the computer.
    President:
  • 1,990 Answers
Welcome to Fixya! Are these 2 Machines Connected to each Other? If they are, It sounds like a Software issue, Otherwise they would not Both be doing the Same thing. Uninstall and Reinstall your Software and see where we can get. Let me Know.
  • Travis Humphries
    Travis Humphries Jan 15, 2009
    The carousel central axel has been twisted on Possibly Both.
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
I installed an original Q3971A toner into the HP 2840 laser printer, However there is still a notice to install cyan catridge. Can you help please
PDF]HP Color LaserJet 2840 and 2820 All-in-One for small and ...
h10010.www1.hp.com/wwpc/.../clj2820_clj2840_bro.p...
Hewlett?PackardColour laser printing. HP Color LaserJet ... •Convert hardcopy documents into digital format for easy ... Color LaserJet 2820 All-in-One gives you high quality, ... Oth ring. Why HP. Save time. Printing a file. Printing a paper fax. Receiving a .... Install, configure and manage multiple networked ... Replace toner cartridges easily.
HP Environment: Product Safety Information - LaserJet ...
Dec 18, 2015 | HP LaserJet 2840 All-In-One Printer
How we clean the double image of our print?
Need to do a reinstall. Most important is that a page is printed that needs to be scanned into printer as part of setup. Should fixd problem.
Nov 24, 2014 | HP Color LaserJet 2840 All-in-One -...
Hp laserjet 2840 not printing
http://h30499.www3.hp.com/t5/Printers-LaserJet/HP-2840-prints-blank-pages-or-yellow-only/td-p/2326639#.Ur1kMH_lMgU
Aug 04, 2013 | HewlettPackard HP Color LaserJet 2840 All...
HP Color Laserjet 2840 refill problem
It may be that the cartridges are the problem? Usual fix is to go back to before the problem and start again. If you don't have old good cartridges, you may have to get new cartridges.
Feb 15, 2009 | HP Color LaserJet 2550n printer + HP Color...
Needing a users manual to trouble shoot printing issues
Hp has most of their user manuals online. Go to hp.com and you should find yours on the list. God bless.
Jan 13, 2009 | HP LaserJet 2840 Printer
HP 2840 All in one won't print color
printer is ok, check the connecting cable and drivers.
Oct 28, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 2840 Printer Logo
42 people viewed this question
Seeker5211
Seeker5211
