Question about Samsung SH-S182D DVD RW Dual Layer Burner
Dvd drive not reconized by windows
I just added a samung dvd burner to my other computer i know it worked in the old one and it was a slave in that one too i want two dvd burners so i can burn two cds at a time in stead of just one but when i put it in to my new computer vista found new hard ware but is asking for a driver it wont find it automaticaly how do i get it to work i went into my bios and it found the drive but windows wants a driver went to website but all they have is firmware update cant use firmware update till drive is installed
model number of drive is samsung sh-s182
  • 728 Answers
Hi ranman3995,
Your not alone with the Vista problems. I'm going to send you to a Microsoft site that will walk you through changing your registry that should fix the problem. HERE.
Good Luck,
Mark
Posted on Jan 14, 2009
Nero problem
You should reinstall your nero software and DVD/ Writer should be on master and CD rom shoul be slave. Then it will work at all.
Thank You
Jul 30, 2009 | Sony Optiarc AD-7170S Burner
No sound output and will not reconize Dvd's, but will reconize cd's
I'll take that as a no,
In fact the default for most types of media is media player but it doesn't include all of the relevant codex's you require for every type of media by default.
Most manufacturers include this software with their computers/DVDROM's but not always.
The reason I assume it is your codex not being installed is simple, you can play CD's, that means the drive works, media player works, sound card works and speakers work. The only common problem that would cause this is a missing or corrupted codex.
try something for me and let me know if it solves the problem.
Install VLC player http://www.videolan.org/vlc/download-windows.html
Then try to play the DVD using VLC player. If it asks to update itself, let it.
Comment back here once you have tried and let me know how you make out.
Chris
May 20, 2009 | NEC (ND-3540A Black) Burner
My new Sony Optiarc AD-7221A DVD drive won't work
for your old sony drive that wont open...
look fort a small hole, like a little bigger than a pinhole, in the front panel of the drive. if you can find this hole, stick a straightened-out paperclip or something similar in the hole, and gently force it in, and this should open the cd drive.
a page file error has to do with ram saving to and reading from the hard drive, using a portion of the hard drive as back-up virtual ram. perhaps there is a bad sector on the hard drive, or some other sort of error with either the hard drive or ram to cause the "page file error" and the inability to play dvd's.
if you can get that old drive to work, that may be your best bet.
Mar 07, 2009 | Toshiba Satellite A100-S8111TD Notebook
Won't reconize DVD burner
Well, the CD ribon cable goes into the IDE 2 slot on the Mainboard and the furthest connector on the other end is the master, the second one closest to the board is the Slave connector. The CD drive has a jumper on the back between where the ribbon and the power connector go, on the case some where it should have a diagram showing the jumper setting to put it in as master or slave. Set it accordingly.
Same with Hard drives.
If the Hard drive has a diferent Cable like a SATA, then be sure to get a SATA as the new one.
Now the IDE cables may be bad check them for damage just to be on the safe side.
Feb 04, 2009 | HP Compaq dc7100 PC Desktop
Adding another DVD RAM drive on gateway computer
I made one drive master, the other one like a slave
Dec 14, 2008 | Panasonic SW-9585 DVD±RW Dual Layer...
Lg 20x external super multi dvd rewriter - not working
well, you can try taking the dvd burner out first and exchange places with the other burner. what i mean is may the dvd burner your primary master or slave. try it and post whats happens.
Jun 12, 2008 | Computers & Internet
Install dvd benq dw1620 in dell 2300 xp
you have to remember to set the Jumpers on the drive to assigh it Master or Slave,  if this is not done it will conflict with the other drive on the IDE cable, (you would usually match the setting of the drive you removed)
This setting is assigned using a jumper on a block of six pins which is usually located next to the 40 pin IDE connector.
Oct 28, 2007 | BenQ 1620PRO DVD±RW Dual Layer...
2 burners on win2000
window 2000 could be a probable cauuse.You could try the following. Update windows by installing the latest hot fixes this would most probably solve the problem if the problem is in windows. if the drives show up in device manager. boot you PC in safe mode and uninstall the drivers of both DVD drives.and reboot normally. If this doesnt work let me know your DVD drive make and model.
Jun 06, 2007 | AOpen DVD1648L (750519138717) DVD Drive
Dvd freezes windows when a disk is inserted
If you have two drives on the same ide cable, one has to be set at master, the other as slave, the hard drive should always be the master. But you should'nt normally put a cd drive on the same ide as a hard drive as this will slow up the read write speed of your hdd. Make sure the ide cable is the correct way around, and that all the drives have been recognised in the bios. To enter the bios press f2 or del on boot up and see if all the drives appear there.
Mar 23, 2007 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Drive doesn't play CD-ROM but plays DVD games...
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer
Dec 26, 2006 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
Samsung SH-S182D DVD RW Dual Layer Burner Logo
159 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
