I wanted to know how to tell how many lamp hours are left on a NEC VT47 LCD Projector- also how does the lamp hours work? if you have 2000 hours does that mean the lamp life is over or you have 2000 hours left? if you have 50 hours that means that you have 50 hours left on the lamp or 1950 hours left on the lamp? Help me out quick!!! thanks you!!!!
  • 4 Answers
The NEC VT47 Projector Specifications say that the lamp is good for 2000 hours and it is good for 3000 hours in eco-mode. Lamp hours are typically a counter and not a count down. If your hours are 2000 then you have already used 2000 hours. If a lamp says it is good for 2000 hours it doesn't mean it will not work once you go over 2000 hours, it could last much longer than that, and like headlights on your car, immediately go out at anytime or just dim over time.
Posted on Jan 14, 2009
    Master:
  • 413 Answers
If the bulb has 2000 hours that means it is supposed to last 2000 hours of continual use. It is hard to keep track of the lamp hours though unless the projector has a timer built in. It depends on the manufacturer as to if it is telling you 2000 hours left or used. There should be a way to switch this. But a lamp rated for 2000 hours has 2000 hours of being on is expected lifetime
Audio Jack of NEC VT47 (using external speakers)
go to your menu find the volume settings. i think your volume is 0 or muted.
Oct 07, 2009 | NEC VT47 Multimedia Projector
Replacing lamp on nec projector
http://www.necdisplay.com/Products/Storefront/
Go to the link, the NEC has an online store, or you can use their link to find an authorized reseller.
Usually there is just some sort of door on the bottom or side held in place with a screw or two. Refer to your owners manual, or download it from NEC in pdf format.
Jan 19, 2009 | NEC VT47 Multimedia Projector
NEC VT47 Cropped image on left side
Hi. You can press the auto adjust button on the projector and the image should return back into view. If not then try another resolution on your computer as it may not be compatible with the projector.
Aug 28, 2008 | NEC VT47 Multimedia Projector
Blinking status light
Replacing the lamp with an old one was helpful for me. Good news: the projector itself not faulty. Bad news: I have two projectors with the same issue at the same time (the lamps were replaced also at the same time) after only 400 hours of running.
Apr 01, 2008 | NEC VT47 Multimedia Projector
NEC VT47 Lamp type VT70LP will not power up 2 red lights spear Lamp not working
When the lamp exceeds 2100hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Feb 27, 2008 | NEC VT47 Multimedia Projector
NEC VT47 Blink Sequence but not comming up.
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
Feb 08, 2008 | NEC VT47 Multimedia Projector
Status light blinking red
Oct 23, 2007 | NEC VT47 Multimedia Projector
NEC VT47 lamp won't light
According to the manual, yes . . .probably gone past the recommended hours of lamp use. Press the OFF or the HELP button on the remote for 10 sec, this will reset the lamp hours value and allow the unit to come on. If it don't, NEC will tell you that it has to be sent to a repair center.
Aug 29, 2007 | NEC VT470 Multimedia Projector
Computers & Internet Logo
224 people viewed this question
David Payne
David Payne
