Question about Samsung Bluetooth?® WEP200 Headset (81451TMIN)
Samsung WEP200 non-responsive (viral?)
Bought 2 of these - 1 for myself, 1 for my son. he's been using his without problems for 4-5 weeks. i charged mine per directions and didn't pair it to my phone (just didn't get arround to it). weeks later, (yesterday) i set it up to charge so i could pair it to my phone and noticed that the red light was flashing slowly and not steady as i thought i remembered it. left it in the cradle for hours - still red blinking light. decided to attempt to pair - followed directions - paired successfully, i think. while testing, battery died. bluetooth unresponsive; put it in cradle - no light. asked to borrow son's charger - in his charger, steady red light. took bluetooth out of son's charger, put it back in mine to test, nothing. back in son's charger, nothing. son placed son's bluetooth in son's charger, nothing. now neither 200 works , neither will charge, neither responds to buttons. nothing. it can't be true, of course, but it seems that my bluetooth had a virus that crashed itself then its charger then my son's charger and finally my son's bluetooth. help me please (it's still in the house and i'm scared)
SOURCE: unable to pair my bluetooth with mobile
it's junk
Posted on Mar 29, 2008
SOURCE: Samsung t509 won't charge
would something like this work?
http://www.bayho.com/p/PCMB-DC-KE850.html
Posted on Jun 04, 2008
SOURCE: can't power on
Same problem
Posted on Oct 24, 2008
SOURCE: Can not pair cell phone with Bluetooth.
I neglegted to put the Bluetooth in pairing mode.
Posted on Dec 01, 2008
  • 10 Answers
SOURCE: Wireless headset pairing
With the Samsung WEP210 this is a common problem (which is actually just a user error)
This is what you do:
1. Of coarse make sure the headset is charged
2. Make sure the bluetooth headset if OFF
3. PRESS and HOLD the top/middle (on/off) button until the light stays on (it will blink then should stay on continuously). That means it is now in pairing mode.
4. Tell you phone to search for bluetooth devices.
5. It should find the headset, and by default type "0000" to pair your new headset**
**You can use whatever pin code you like......but I would recommend the default which is four zeros.
Posted on Dec 10, 2008
How long should the battery last in my Verizon samsung 4g lte phone?
If your battery only lasts 4 hours tops, it could be defective. Best thing to try is to swap batteries with your son - if your phone lasts longer on his battery, that's the problem. I'd recommend taking the phone back to the Verizon store you bought it from. Also, make a habit of closing out of all apps that you are finished using - apps running in the background use battery as well.
Sep 12, 2014 | Samsung Verizon Wireless 4G LTE Mobile...
Tip
Turn on your bluetooth on your phone and paired with your Samsung WEp200
1. go to your phone click on settings, connection/connectivity, then bluetooth.
2. turn-on your samsung wep200, your cellphone will automatically search/find for available connection.
3. choose your samsung bluetooth wep200.
4. if prompt you want to pair with it, click on yes or confirm.
5. then enter the headset passkey/code/pin: 0000
6. then your all set.
this is the website i used to pair and unlock my wep200 to my samsung impression.its quick and easy.
http://www.alternativewireless.com/samsung/Samsung-WEP200G-quickstart.pdf
on Feb 04, 2010 | Cell Phones
How do I acitivate it
Charge your headset
Charge the headset's battery fully before using the headset for the first time.
1 Put the headset in the supplied charging case and close the cover.
2 Plug the travel adapter into the case's charging socket.
Put your headset in pairing mode
1 Ensure that the headset is off (see Turn headset on/off below).
2 Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Turn on Bluetooth on your phone and pair with headset
1 Set your Bluetooth phone to discover the headset by following your phone's guide.
Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200
headset.
2 Select Samsung WEP200.
3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK.
4 Enter the headset passkey or PIN, 0000.
Your phone and headset are now paired and ready to make and receive calls.
1 Place the headset over your ear.
2 On your phone, make a call to the number you want.
3 If your phone and headset are successfully paired, you will hear ringing on the headset
After you have successfully paired your phone and headset, you do not need to repeat these initial setup steps each time you use the headset.
To turn the headset on
Press and hold the Multi-Function button for4 seconds until you see 4 blue flashes on the indicator light, then release.You will hear a tone and see the indicator light flashes while the power is on.
To turn the headset off
Press and hold the Multi-Function button for 4 seconds until you see 2 blue flashes on the
indicator light, then release.You will hear series of 2 tones and see the indicator light stops flashing.
http://ars.samsung.com/customer/DownloadAnsTempl?AT_ID=70171&SEQ_NO=2
Jun 07, 2011 | Samsung Bluetooth?® WEP200 Headset...
Can i use samsung bluetooth headset WEP200 in Samsung Gravity SGH-T469W cell phone?
yes u can....just turn wep200 on until the blue light stays on not flashing...then the gravity 2 will find it.
Jun 01, 2010 | Samsung WEP200 Headset
Samung wep200 to my samsung instinct
Make sure you do as it says on the pairing section. i was having the same problem (no devices found) until i followed as it said on #2, when wep200 is off press the multi-function key until the blue light comes on solid approximately 8 secs. I have a samsung instinct and it read just fine after that.
Aug 18, 2008 | Samsung WEP200 Headset
No voice
I have the same problem. I bought it from amazon.com a few months ago and had to send the first one back because of the same issue. However, this one did not present the problem until it was past the return window for amazon.com. :-(
Jul 02, 2008 | Eforcity Samsung Bluetooth Headset WEP200...
Samsung WEP200 Headset will not charge up
I've same problem, and I can't turn it On
Mar 08, 2008 | Samsung WEP200 Headset
Charging
just open the main board
and clean with solution
and give a little bit of heat with smd
Dec 30, 2007 | Samsung WEP200 Headset
Endless charging
Dear Chaterbox,
Sounds like your batteries needs replacements, try using new ones.
Sid
Nov 20, 2007 | Samsung WEP200 Headset
I bought this device but...
when you turn on the WEP200, you must continue to hold the button down until the blue light goes solid, that indicates pairing mode. Now, have your device search for it.
Aug 10, 2007 | Samsung WEP200 Headset
Samsung Bluetooth?® WEP200 Headset (81451TMIN) Logo
159 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
