Question about Durabrand DUR-1700 Portable DVD Player
Loading stopping when we turn on the dvd player it says loadingg then it stops.
  • rella hoffman Jun 13, 2007
    the device is a durabrand model pdv 709 9" dvd player.bought at x mas now it wont play dvds.
    Problem Solver:
  • 6 Answers
If it is not playing dvd the lense may not be able to read the dvd's you can play the dvd's by changing the lense it will be ok
Posted on Nov 07, 2007
DVD player automatically stops and turns itself off, how do I prevent this?
Warning: Laser inside! If you want to open it up and troubleshoot, make sure you don't point toward your eyes.
Check the nylon laser carriage to see if it slides laser from center to outside line. If it sticks, it's probably shutting down from not properly reading a disk.
Aug 03, 2014 | Pioneer DV-343 DVD Player
Hi my logik lpd1001 wont load any dvd it just stays on the loading screen for a few mins then says no dvd, it wont load music either
First try the solutions offered elsewhere, eg cleaning the lens. Then try this -
Put in a DVD. Try to rotate it clockwise. Does it run freely? If not where is it catching? Rock the DVD to see if it is contacting the right hand side of the player causing the motor to stop. If yes, then it is likely that the internal battery has shifted and is distorting the plastic underneath the DVD. Confirm this by turning on the player, apply pressure to the area to the right of the DVD. The player should start/stop according to the pressure.
Remove the 11 screws on the base. Remember their positions as they are not all the same length.
Carefully separate the two halves - there are wires connecting them. The battery is held in place by sticky tape. It may have migrated to be closer to the DVD, causing the motor to stop. Re-position the battery closer to the edge. Use fresh sticky tape if required. Re-assemble the unit.
Check that a DVD spins freely.
Mar 28, 2010 | Televison & Video
DVD stopped working and won't start again
Try cleaning the lense. Use a q-tip and some rubbing alcohol.
Dec 02, 2009 | Zenith DVP615 Portable DVD Player
Dvd won't play or eject
If you want to get the dvd out
you can try this:
First turn of you dvd player at the mains, Then power it up, But the moment it powers up press the eject button a few times so it doesn't start to load. If it doesn't work the first time try it one more time since you may not get the hang of it at first.
then you dvd should eject.
With dvd players like this, corrupt, copied or really scratched dvds may make your dvd player do this.
Regards
Jul 25, 2009 | NexxTech DP3222 DVD Player
DVD says loading.... but keeps turning, stops, turns, stops
It is a problem with the laser. Getting a lens cleaner could help, but it is doubtful. Your best bet, tap the unit while the disk is trying to load.
There is a motor that moves the laser into place. Often the motor burns out or it does not focus correctly after a while. Sometimes, they just get stuck. A tap may kick start the motor into place if it is stuck. Most likely, you will have to replace the unit.
P.S. Toothpaste and electronics don't mix. CD players get extremely hot. You will eventually be cleaning Crest out of your DVD player.
Jul 25, 2009 | Durabrand PDV-705 Portable DVD Player
Nextplay dvd player loading but not reading disc
my nextplay dvd player turns on, whirs, says it is loading but never loads. Then when I push stop, it doesn't stop either. Any ideas?
Jun 04, 2009 | Televison & Video
Disc not loading
You're going to have to switch off the unit and turn it back on to make it stop. the disk is either badly damaged or the infra red in the remote isn't responding to the dvd player vice versa. hope i managed to help. goodluck. PS also clean the lens of the player as dust causes disk loading probs aswell
Mar 30, 2009 | Televison & Video
DVD player wont play just says loading and than stops
there might be dust on the lens. try cleaning both the lens and dvd itself.
Mar 28, 2009 | Durabrand PDV-709
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
Toshiba SD 4800 dvd player
I've had the same symptoms on the last two Sony DVD's that I've rented. I managed to get around this by hitting one of the menu buttons after the loading message stopped.
Aug 07, 2007 | Toshiba SD-4800 DVD Player
Durabrand DUR-1700 Portable DVD Player Logo
80 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
