Question about GE Advantium 120 Convection/Microwave Oven
G.E. convection oven fan stoped working. The fan turns freely with no resistance.
  • Scr2400 Jan 23, 2009
    How do I get to the fan to check it?
  • 25 Answers
Does it have 110 volts on it? If so its bad.
If not then look for a bad relay.
Posted on Jan 14, 2009
Sharp Convectional microwave oven model R990K (R980J) working but convection not working only getting to 70 degrees what are the common problems causing this?
Don't know model but the convection uses a coil and fan( if electric) if gas , flame and fan. I guess you have electric and have a bad coil
Mar 03, 2015 | Sharp Microwave Ovens
The dial on our GE JVM1790WK01 microwave turns freely but does nothing. I checked the knob for damage, none found and the shaft turns freely with a slight bump as it goes around, but does nothing.
turntable problem? it's probably the motor itself. it's easily removed under the bottom panel. you'll need the pricey ge orig. part; as they use a odd 21volt motor. good luck.
Aug 06, 2011 | GE JVM1790 1000 Watts Convection /...
MY CONVECTION OVEN IS NOT WORKING. LOW TEMP AND FAN NOT ROTATING
Whirlpool MH1150XM-series models do not have convection cooking.
Aug 19, 2010 | Whirlpool MH1150XM Convection/Microwave...
Ace 208 comes up with "hot" in display amana tech say not possible no code like this
Hello I´ve repaired a couple of ACE208 with hot message in the display. The problem is in the convection fan located on the back of the oven cavity, turn the oven on and quickly open the door and look inside to see if the fan is spinning (slowing down, the fan stopps when you open the door but you can see it slowing down) if it is not spinning the supporting screws of the fan sometimes loosen up causing the fan to hit the oven walls preventing the fan to spin freely -probably before the problem started to happen you could hear a loud noise- the fan can´t move the air throgh the warming elements causing them to overheat hence the hot message. The fan motor rarely fails so all you need to do is remove the stainless steel cover and the back black cover and tighten the mounting screws of the convection fan and clean it if it´s dirty. Hope this helps, both the ovens with hot message I have repaired get the green tag just by doing this or replacing the motor, I have no knowledge of other problems that may cause this.
Dec 02, 2009 | Amana ACE208 Convection/Microwave Oven
Sharp Microwave Oven over stove fan goes on by itself
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So please post a
NEW question, and please include your brand name and the full model number from the tag in or on the unit, as well as the answers to these questions:
Which fan is it?
The
internal cooling fan, which comes on automatically whenever the unit is microwaving?
Or the hood vent exhaust fan which you can turn on and off manually?
Or the convection fan, if it is a convection model?
When is it coming on?
Is it coming on whenever you cook on the stove top?
Thanks!
Oct 09, 2009 | Sharp R-1870 Convection/Microwave Oven
Control panel seems to be responsive, internal
Make sure the glass platter is correctly seated on the plastic drive. Now gently press down on the platter and see if it resists turning. If the platter turned easily, the plastic drive is spinning on the motor shaft and needs replaced. If the platter resists movement, the motor under the floor needs to be replaced. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 25, 2009 | Sharp R-930AK Convection/Microwave Oven
My GE Profile Convection Microwave Oven - Convection not working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uijjf
Dec 02, 2008 | GE JVM1790SK Convection/Microwave Oven
Fan
Test the motor fan - unplug the oven, wait 5 minutes and discharge the capacitor. remove the oven housing.  First check for any obstructions that may be preventing the fan from rotating.  Turn the blades by hand: if they don't move easily, disconnect the wires from the motor and take out the motor for cleaning and lubrication.  if the fan blades move freely, check for a burning smell and examine the motor windings for discoloration.  If a wire is loose or broken, repair the wire connection.  To test the motor for less visible damage, set a multitester to test resistance.  the motor should have low resistance.  If not, replace it.
Oct 13, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
251 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
