Question about Toshiba 42HP95 Television
Green shadowing My TV is 18months old and I am getting Green shadowing/Pixeling in my picture. It is in many different areas. Please HELP...... Thank you
  • mike mcdermott Jun 18, 2007
    The Green pixeling does not cover a large part of the screen. Green pixels are displayed approx 3% of the screen and many times it will be fine. Sorry if I am not giving a good description bt I am trying. thanks
    Genius:
  • 1,074 Answers
If your tv is on warranty take it back to the supplier .if the warranty has expired then you will have to look at the convergence board it needs to be adjusted or replaced.also if you have speakers around your tv move them, that too can cause the green color problem.good luck my friend.
Posted on Jun 16, 2007
  • Henry  Thomas
    Henry Thomas Jun 18, 2007
    my friend my best solution for your problem is to have a tech make checks on your tv have him go through the video amplifier and the color modulator it could be a transistor or ic causing your problem.i though that the green was all over the tv.you did not mention if the green pixels is on all the channel you switch to.good luck.
  • 203 Answers
Sounds to me like the video board is bad. If it covers a good portion of the screen it is likely not the panel itself and rather something to do with the processing.
Posted on Jun 15, 2007
  • Benjamin Madison
    Benjamin Madison Jun 18, 2007
    Considering the unit is a plasma it is either the plasma panel or the video processor. And since it is intermittent I would go after the video processing first.
    Most of the plasmas are not really component replaceable.
    I don't have a manual on your unit but my guess is the signal board is bad. Replacement cost is about $220.00.
  • Benjamin Madison
    BTW - the part number for that board is 75004993. If you've got a Y-Sus board issue they are only available with the entire display and that will run you about $2200.00.
Describe your Problem Our sony tv 2 yrs. old has vertiva colorl lines that come on 40 sec. after turning it on.Unplugging does not help.
Can you describe a little more your problem TV, please?. Your TV look like shadows on the picture?.. Thank you
Aug 13, 2011 | Televison & Video
Mitsubishi TV Model #WS65903 - Green Shadow Lines on Screen
Something is not right here--The green is adjustable in the TECH menu--did this person adjust or try to adjust in the customer or the TECH menu?
If you confirm actual model number I can tell you how to get into the TECH menu--yes--green will not adjust in customer menu--it determines geometry and is only adjusted in the TECH menu.
Also, this set requires any convergence adjustments to be done in 480 and then in 1080--if only adjusted in one mode the other will still be bad.
Let me know if you know how to adjust in TECH menu or not--with exact model number I can tell you how to get there.
If this helps you rate this solution as I do this here for free.
SD TECH
Dec 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Distorted Color and geometry of Picture
replace stk 392-110 ( or stk 392-150 same number) , check resistor 2.2 ohms for open or burn beside STK IC's
Apr 13, 2009 | Panasonic PT-47WX53 47" Rear Projection...
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Green effect on top of the picture of my LG ru-44sz51d
it sounds like an adjustment is needed/call for service and a est.$
Nov 10, 2007 | LG RU-44SZ51D 44" Rear Projection...
Colour alignment off
Need to replace the convergence IC in the green vertical circuit. Check the 3.9 ohm resistors located in front of the IC.
Nov 02, 2007 | Samsung HCN436W 43" Rear Projection...
Problem in Screen display
Hi, J ! You didn't say how old you set is, but to me it sounds like you may have a warped shadow mask in you picture tube. A shadow mask could be compared to a piece of screen wire. It's function is to make the electron "beams" from the three electron guns strike the proper phosphor dot to produce the proper color- red-green-or blue. If this is the case the picture tube would requie replacement. Stargazer
Jan 09, 2007 | Sony KV-21CT1 21" TV
Televison & Video Logo
208 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
