I have a 22" Vizio TV (1080P) and need to set up Verizon Fios remote with it, but the codes that came with the remote for Vizio do not seem to work. Can anyone help me with this?
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I have a phillips 42 lcd and i have fios they both work fine with fios remote ill give you the phone number to call they will give you the remote code (412)497-7911 Call tommorow before 6 they will give it to you its verizon pittsburgh number i worked for fios for a few years...Please rate me when you get a chance..
Thanks,
Steve
SOURCE: I can't turn my TV off with the Verizon FIOS universal remote.
Try the following codes. I know you stated that you were given codes so ignore any that you already have tried:
Verizon FIOS
Vizio 0891, 0912,1783
Alternative Codes
1758, 0178, 1756, 0128, 0117, 1017, 1078, 0030, 0056, 0205, 1292, 0057
SOURCE: Need to know code to set up FIOS remote
the Fios guy should have left you with the book for the remote code panasonic is alway in there call their tech support
SOURCE: VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I
left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though.
There was still power to the unit and you could see that the back light
was working, just no picture, no sound, and you couldn't use any of the
buttons. The only way to turn it off was to unplug it. It would then
start up, with the Vizio logo going from orange to white, and then do
the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com
(you can also use searspartsdirect.com). This is the circuit board with
all of the inputs on it (hdmi, cable, etc.) I opened it up,
disconnected the old one, put in a new one and now it works fine.I used
both serial numbers on the board to search for it online. It cost me
$144 to do it, but that's better than $450 for a new TV. My tv is the
vx32l hdtv10a. I hope that helps.
I tried to set up verizon remote to power on vizio 22 1080p tv with codes from
verizon and vizio none worked
