Lines in LCD tv moving from bottom to top when connectin RCA
The problem is this, if i connect an AV cable (rca) directly from the cable tv box to the tv (video 2) lines can be seen and is very annoying, but if i connect only the coaxial cable that comes from the outside om my home directly to the tv there's no line.
  • goldenboy_17 Jan 14, 2009
    You mean to use the adapter in the tv power cord or the cable tv box cord?
  • goldenboy_17 Jan 17, 2009
    It helped a lot, thank you very much for the help. It can be seen a little but no annoying as before.
  • 3 Answers
Hey there,
There may be a ground loop in your electrical wiring. Try connecting a 3 prong to 2 prong AC adapter between the power cord and the electrical wall outlet. You can find one in any hardware store for around one dollar. This will lift the ground from the TV. If your lines go away you may have an issue with your electrical wiring in the house or on an internal part on one of the components. The least expensive fix is to leave the adapter in place. I hope this helps.
Posted on Jan 14, 2009
  • timon0308 Jan 17, 2009
    On the TV power cord
  • timon0308 Apr 14, 2009
    Glad to hear that it helped you
With set up box audio in to tv causes high pitch sound
I am assuming this should read 'Set top box'. What kind of cable are you using?
Usually the set top box connects via a SCART lead but yours may be HDMI if it is a very new set top box.
If you are using RCA plugs, you may have cross connected the wrong cables. The RCA cables should be colour-coded. RED and WHITE are for audio, Yellow is for video.
Best advice is to switch it all off, remove all the cables you attached, and start again. The instruction manual/user guide usually has an illustration to help you identify what your set up looks like - there are usually several examples.
If the cables you need did not come with the set top box, you will need to purchase them.
When you are connecting audio leads, you should use the 'audio out' on the set top box and the 'audio in' on your TV set.
It would help to know the EXACT model number of LG screen you have and the make and EXACT model number of the set top box.
Good luck.
Mar 07, 2015 | LG 42LC2D 42 in. LCD HDTV
How to hook up an old RCA 14 inch tv to DVD
Easy. All you have to do is to make sure that the DVD player is old the older types that have RCA connectors at the back of the DVD. Latest DVD may have RCA connections but I am not sure if it can send digital signal directly to the analog TV. Try this and see what happens. if your TV is old and does not have Component Video (Red/Green/Blue) RCA sockets (input) but has standard Pal/NTSC sockets (Yellow/Red/Black) hook up the yellow, red and black plugs into a DVD (out) RCA sockets of same colour, then hook up the other end of the cable in the (in) RCA sockets at the rear of the TV.
If it works, then all is well. If it doesn't work, then you have to hook up the cable from the DVD to the (input) RCA sockets of a Set Top Box, so that the Set Top Box will convert the signals for the analog TV. Just pay attention to the inputs and outputs at the rear of them.
On your DVD - plug the RCA cable to the (OUTPUT) RCA sockets. On the Set Top Box - plug the connectors in the (IN) RCA sockets and then use another cable connected to the OUT RCA's of the Set Top Box, then connect the other connectors to the (IN) of the TV RCA sockets. Hopefully you get the picture on what I mean.
Sep 01, 2014 | Televison & Video
I set up teac HDB840 to tv- via coxial cable from wall to set top box, then rca cables output of set top box , then to input to tv.-tried av button on tv showing av1 av2 and av3 but still no picture only...
Hi, Your set top box (PVR) is running on channel 3 or 4. Go to menu and sellect a source TV, DVD
Note: Do not connect more than 1 set of cables to tv or you may damage something.
TV > box connect RCA cable or HDMI not both.
Set top box > connect RCA or HDMI Not both.
audio devices > TV connect RCA or HDMI not both.
Good luck.
Jun 18, 2011 | Televison & Video
How do you connect AKAI model # PDP4290 to cable ?
You will need a cable box/set-top box with this TV. Contact your cable TV provider for this.
It does not have a direct RF connection, only AV connections.
For Cable TV support you can use
  • Composite video (single RCA connector)
  • SVideo (round 4 pin connector)
  • Component Connectors (3 RCA connecters red/green/blu)
Component will give you the highest quality signal (as long has the cable box supports this connection) You will also need to connect the Audio connectors (red/white RCA) from the cable box to the TV as well.
The full PDF manual for your TV can be found here: http://www.managemylife.com/mmh/lis_pdf/OWNM/L0502572.pdf
I hope this helps,
Magoo
Mar 11, 2011 | Televison & Video
Hello I received a lg flatron plasma MZ42PZ14 and just wanted to connect the tv cable to the tv, but i can't find any coax on the tv. what can i do?
This kind of tv u must have cable or satalite tvs pay broadcasting signal cable,so u have a box .Tv have HDMI ports or RCA AV component cable input?The incomming broadcating tv signal go to the cable or satalite boxes.Than u use a HDMI cable or RCA AV component cable go through those boxes than to ur tv HDMI input ports or RCA AV component cable input holes.
Jan 22, 2011 | LG MZ-42PZ14 42 in. Plasma Television
I have recently gotten a Sharp AQUOS Quattron (LC52LE810UN). I have a rogers cable box with a RCA input, but the tv doesnt not have an direct RCA input. It has a input for an audio cable with a component...
Your TV is a High-Def TV (HDTV) therefore you need a Rogers cable box and service capable of High-Definition in order to get the HD resolution you paid for with the HDTV. HD video requires HDMI or component video cable connections. Standard RCA AV (yellow, white, red) will not show HD video.
Having said that, you may want to hookup a game or VCR to the TV and therefore you will need to get a cable known as an AV miniplug. It has RCA (3) on one end for the VCR for example and on the other end is a Mini-plug to connect to the HDTV (Sharp). This cable is like the ones used on camcorders such as Sony. Make sure you get a cable with the right ends as depicted in your manual on page 14.
You'll have to Google online for a supplier. Sparco.com had these cables but are out of stock currently.
Jan 17, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Trying to connect vcr do i connect it to cable box or to back of tv. tv is on the wall thats why I,m asking
If u plan to just to watches video only,than just used a RCA AV component RYW connections hook directly to the LCD tv is find.But if plan to record shows and things to the VCR tapes,than the VCR unit must hook through to the cable box.
Nov 22, 2010 | Televison & Video
Unuseable signal
WHAT HAPPENS WHEN YOU USE A DVD INPUT (AV) OR A SAT/CABLE BOX CONNECTED TO THE AV INPUT'S ,,IF IT CLEARS UP YOU HAVE A SIGNAL BOARD BAD BUUUUUUT YOU CAN BYPASS THAT BOARD AND SAVE MONEY JUST BY USING THE AV INPUT...TUNICA
Sep 25, 2008 | RCA P52926 52" Rear Projection Television
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
No service
  • Make sure that you have connected the cable box properly to the TV.
  • Use the audio and video OUT from the box to the TV IN.
  • Select the correct input on the TV.
  • Connect it using any of the following: A HDMI cable (1 cable for both audio and video), Component Cables (3 RCA's red, green, blue) + RCA audio cables (1 for mono or 2 for stereo), S-Video + RCA audio cables (1 for mono or 2 for stereo), or AV cables - 1 RCA for video (usually marked yellow) + RCA audio cables (1 for mono or 2 for stereo).
  • Consult your TV's owner's manual for detailed instructions or ask me for more information.
Hope this helps. :)
Apr 01, 2008 | Televison & Video
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
