Question about GE Profile 20.7 cu. ft. CustomStyle Side-by-Side Refrigerator with Dispenser TPX21PRBWW
The water dispenser in the door suddenly stopped working
It was working one minute and the next no water was coming out. no noise. no other changes. ice dispenser (crushed or cube) works fine.
  • shanarivka Apr 20, 2009
    I'm waiting for current tenants to move out so that I can unplug the frig and let the whole thing defrost. It was suggested to me that perhaps the reservoir is frozen. Will let you know if that solves it, but it will be a few months before I have the opportunity...
  • 3 Answers
Try checking the hose that goes from the freezer to the water pipe it is hooked up to, it may be clogged. If you aren't sure if it is clogged just go to home depot and buy a new hose kit witht eh spout, it cost no more thna $20. This happened to me and when I replaced the old hose and spout with a new one it worked fine.
Posted on Mar 13, 2009
No water coming from door mounted dispenser
To find the problem, follow the water line back from the dispenser to the next connection, disconnect each connection you find, one at a time, if still no water, reconnect and go to the next connection and try there, once you get water coming out, the blockage/problem is between the last 2 points you checked. Water will come out fairly fast so only activate the dispenser for a few seconds, each time and have a towel handy.
Feb 15, 2015 | Refrigerators
Water Dispenser on GE Profile Bottom Freezer Refrigerator Not Working
When you press the water dispenser button, do you hear a noise like water is trying to come as usual. If so then your problem might be frozen chill water tank or failed chill water valve. If you don't hear the regular noise then the problem might be with the dispenser unit.
Nov 26, 2013 | Star Manufacturing GE Profile PFSS5NJX...
Water dispenser on fridge not working - water pressure fine, could the line be frozen and why would that start happening all of a sudden?
Check to see if the water reservoir in the bottom of the frig is frozen. If it is, you will need to turn the frig temp down.
Dec 04, 2012 | Refrigerators
Subzero 695 Ice/Water dispenser problem.
maybe ice formed around chute from leaky air seal??? warm area with hair dryer blowing hot air up into chute for 10 minutes. check for water and wipe all off. unplug refg and plug in after 3 minutes to reset electronics
if helpful please rate me. if not please tell me more.
Mar 03, 2012 | Sub-Zero 695/O Side by Side Refrigerator
Water dispenser is not working. Checked tubing and does not seem to be frozen. I heated the lines anyway with a hairdryer and left the freezer and the refrigerator door open for about 30 minutes. No...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
A strainer before the inlet valve can also get stopped up restricting flow.
Dec 15, 2009 | Washing Machines
My whirlpool suddenly stopped dispensing water.
most fridges stop dispensing water when you open the door. Find the door switch and make sure fridge interior light goes on/off when you manually press door switch. This would show you that the door switch was faulty.
If the water connection to the appliance is one of those watts flood-safe water lines, it may have stuck shut. I've seen this happen when the house water pressure is too high.
Does it still make ice?
If so, then the water connection is good, and either the switch in the water dispenser has failed or the water shutoff valve for the water dispenser has gone bad.
Some models have a problem with the water line getting frozen, such that simply leaving the light on in the water dispenser compartment overnight and/or manually defrosting the unit can get it working again.
Nov 02, 2009 | Refrigerators
Water is not dispensed but icemaker is working
It's more common to be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
If it doesn't come out then disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If the water comes out then check the reservoir.It's behind the crispers in the fridge.
Sep 07, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water Dispenser on freezer door does NOT work
change filter check tap see if water is shut off may be is the water valve
Apr 03, 2009 | Admiral 26 cu. ft. Side-By-Side...
Amana ARB9058CS Bottom Freezer - tremendous frost build-up in freezer on left side near ice maker at top of drawer
  1. I am not expert but this exact same thing happened to me - same model of fridge. The line which brings water in is frozen. I don't know how to solve it permanently, but if you take out the two produce drawers you can see where the water comes through. Put a hair dryer blowing on it for a few minutes and it will get it going again.
Aug 17, 2008 | Amana ARB9058CS Bottom Freezer...
Ice and water dispenser not working but light on constantly
We had the same problem. When we removed the ice receptical the mechanism that turned the ice make was broken and it stopped the ice from being dispensed. I hope it is that simple for you!
Aug 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerators Logo
148 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
