Question about Sharp EL-1611P Calculator
Sharp Elsimate 1611P 12 digit Calculator
I have been using this calculator for the past 6 or 7 months with no paper. I finally went and got some paper for it and this is where I ran into problems. I pressed the "2nd" button and then pressed the "M+" button which has the "P/NP" over it (for second function). When I did this, the "NP" that was on the top of the screen changed to "P" which should happen, but where the digits appear on the screen, a big "P" appeared and a little "E" is on the bottom right hand side of the screen. There is also a little "F" on the top of the screen about 1/2 inch to the left of the "P". I cannot use the calculator for anything now, none of the buttons work. I have turned off the power and turned it back on. I have taken the batteries out and put them back in. I have pressed the little reset button the back of the machine. Nothing has worked. The big "P" with the little "E" keep coming back. How do I clear this error and get my calculator back?
  • 1 more comment
  • Erin Archer Jun 18, 2007
    I found that the batteries in the machine were strong enough to work the calculator without the paper, but when I tried to switch back to paper, I got the error. I replaced the batteries and it works fine now. Thanks for everyone's help.
  • Anonymous Apr 15, 2008
    same shut
  • annemelgar17
    annemelgar17 Aug 10, 2017
    i am now experiencing the same problem, i have tried all the suggestions listed below but still can not use my machine i have notice a yellowish substance on it, may i know what is that and can it possibly affect the machine ?
    New Friend:
I've been using mine for something like 20 years! I just experienced this for the first time. Mine is so old it does not have the '2nd' key. But I got it to reset by turning it off, holding down the P/NP key while powering it on, then hitting the P/NP key once more to turn the little P in the top right corner to NP. Works great now. Hope yours works now as well because I LOVE this little machine.
Posted on Nov 02, 2015
I had a similar problem but it got totally solved with a 6 volt dc adopter and now no error is given so if there is a problem with the battery and probably the calculator "processor" need for power is not met from the old batteries. Always try new batteries before service or repair as it will solve many of your problems
Posted on Oct 14, 2007
  • 186 Answers
It sounds like there is a printer error. Take of the cover where the paper is. There should be a little ink roller. Try taking this out and look in and see if the rubber band with the numbers on it is broken. If so, the machine is not worth repairing, unless you can get it replace under warranty. If it is not broken, try turning the machine on and off with the ink roll out of the machine. This should reset the print head as long as nothing is in there jamming it up. Good luck John
Posted on Jun 16, 2007
Sharp user manuals
Follow the link here.
http://www.sharpusa.com/ForHome/HomeOffice/Calculators/EL1611P.aspx
Scroll down and click on operation manual.
Hope this helps, don't forget to rate.
Jul 15, 2014 | Sharp Office Equipment & Supplies
Hi I have a Sharp Elsimate EL331A calculator. How do I programme in the new 20% VAT rate, please?
Press the red [C-CE] button twice, then the yellow [+TAX] button.
Then type in the Tax percentage. Press [+TAX] again and then the [C-CE] twice again.
This works for the EL-331A Calculator.
Jan 03, 2011 | Sharp EL-330AB Calculator
I have a Sharp elsi mate EL-1611P and I am trying to get out of the P.E mode. How?
Push as many buttons at the same time as possible. Throw the calculator on the floor. That should do it.
Oct 01, 2009 | Sharp EL-1611P Calculator
Printer Head is Messed Up
Who won the Battle of Lexington andConcord?
Sep 11, 2009 | Sharp EL-1611P Calculator
The calculator keeps displaying a P with a small e
You have to remove the paper roll. See also the manual: www.sharpusa.com/files/cal_man_el1611P-pdf
Apr 01, 2009 | Sharp EL-1611P Calculator
How can I get this calculator to not print[-- I just want to use without paper?
P/NP means Print or no print. I know fairly complicated. Hit the 2nd button then NP. This key is also known as the M+ button. Hint lay off the grass.
May 28, 2008 | Sharp EL-1611P Calculator
Where to buy paper
This Uses standard 2 1/4" paper. You can purchase this from any office supply store online or in your area.
Just ask for a roll of standard 2 1/4" paper for calculators.
Hope this helps.
Good luck.
Mac =)
Please remember to post a rating if I have helped you with your question.
Mar 18, 2008 | Sharp EL-1611P Calculator
Sharp EL-1611P Calculator Logo
3,337 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ed
Ed
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
