My saw had not been used in about a year, yesterday I started to cut some 3/8" steel rebar cut two and when I pulled trigger on third it tripped the 20 amp breaker. I reset and tried a couple more times then moved to another plug with same result. I have had mud dobber wasps get into similar tools but armature turns freely and I can't see any problem from the outside of housing. Could it be a switch problem? Any suggestions or help appreciated, John
SOURCE: Tripping 20 amp breaker
if its new, like in the last year or so send it back to milwaukee. they have a five year warranty, so dont dissasemble it, or you will VOID your warranty. I have been selling and servicing milwaukee tools for over 20 years. when your cutting heavy wall tubing the size you are its important to let it cool for a while between cutts and seriously,,, only use the thin 1/8" Milwaukee blades and let them do the cutting with just enough pressure on the tool to prevent glazing on the surface of the blade. you will find your cutting goes a lot easier. blade life is not as long, but it will be much easier on you and the tool. the 3/32 bade they come with is awesome if your doing smaller/thinner material, but use the thinner on thicker rule.
