Question about Canon Rebel XT / EOS 350D Digital Camera
Need to change file name
I would like to change the file name of pictures from IMG_#### to something else.  I would like to change IMG to some other 3 letters.  Do you know how to do it?
  • 20 Answers
This is one of those "it depends" kind of answers. I'll assume that you have copied the picture files from the camera to your computer. If not, let me know and I'll help you through that -- while possible to rename the files when they are on the camera (actually on the "compact flash" memory card), it's not a great idea.
So the pictures are in a folder somewhere on your computer, probably "My Pictures" if you're using Windows, and somewhere similarly named if you use a Mac. On windows open My Pictures, and click the filename (IMG_XXXX) once, then once again and you should be able to type a new name. On Mac, use Finder to locate the file, click it, and select Edit > Rename.
That's the hard way. Chances are you are using some program to help manage the images -- to import them from the camera, to edit them and so on. If you're using the Canon software, forget it -- use Picasa (free from Google at picasa.google.com) on Windows, or iPhoto on Mac (there's a Picasa version coming for Mac soon -- it's awesome). Once in Picasa or iPhoto, renaming should be pretty obvious.
The trick to remember is: the pictures are pretty much just regular computer files like word processor documents or similar -- you can rename them probably in a similar way that you do with other files.
Hope this helps!
Tom
Posted on Jan 14, 2009
Change blend door acturator
REMOVAL PROCEDURE
[img src="http://repair.alldata.com/alldata/brand?fileName=img/content/printer.png" align="asmiddle">
[img src="http://repair.alldata.com/alldata/imagesWLinks?file=//imagebfl300l/17/03/60_gc02ck8pu_1-173b.png&width=528&height=475&displayType=display&imgRotation=&links=" id="image" alt="60_gc02ck8pu_1-173b.png" usemap="#imgMap_1">
1. Remove the air distribution duct.
2. Disconnect the electrical connection from the recirculation actuator (1).
[img src="http://repair.alldata.com/alldata/imagesWLinks?file=//imagebfl300l/17/03/61_gc02ck8pu_1-173c.png&width=544&height=478&displayType=display&imgRotation=&links=" id="image" alt="61_gc02ck8pu_1-173c.png" usemap="#imgMap_2">
3. Remove the recirculation actuator retaining screws.
4. Remove the recirculation actuator.
INSTALLATION PROCEDURE
[img src="http://repair.alldata.com/alldata/imagesWLinks?file=//imagebfl300l/17/03/62_gc02ck8pu_1-174a.png&width=544&height=473&displayType=display&imgRotation=&links=" id="image" alt="62_gc02ck8pu_1-174a.png" usemap="#imgMap_3">
1. Install the recirculation actuator.
NOTE: Refer to Fastener Notice in Service Precautions.
2. Install the recirculation actuator retaining screws.
Tighten
Tighten the screws to 1.6 N.m (14 lb in).
3. Connect the electrical connector to the recirculation actuator (1).
4. Install the air distribution duct.
Nov 12, 2013 | 2002 Chevrolet Silverado 1500
Garmin nuvi 200 SD card
Did you rename the file extensions? On the unit, the map file and map unlock file must be named gmapprom.img and gmapprom.unl
On the SD card they must be named gmapsupp.img and gmapsupp.unl.
Also copy your garmindevice.xml file over to the SD card too.
Feb 26, 2013 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 1350 showing on screen "no map data available"
Shut off the nuvi.
Remove any memory card (if equipped) from your nuvi.
Plug the GPS into your computer via USB cable.
Open the Garmin "drive" icon in "My Computer"
Navigate to the x:/Garmin directory or "folder" (where "x:" is the drive letter assigned to your Garmin). Locate either map files set(s) named: gmapsupp.img or gmapprom.img.
Some units store map files in the hidden x:/.System directory instead. To view the .System folder and contents, you must direct your computer to display both the "system" and "hidden" files.
If you lack large files named either gmapsupp.img or gmapprom.img (about 1 GB or more); your maps are missing from the internal memory of the nuvi and will need to be reloaded.
If you pulled a memory card above, reinsert it and check the directories for the same gmapsupp.img or gmapprom.img files. If they're not present there, the maps should be reloaded.
I hope this helps
Sep 15, 2011 | Garmin nuvi 1350 Car GPS Receiver
I bought a lifetime update from Garmin a few years ago but now my nuvi 270 tells me that I don't have enough memory to install the latest maps and that I must choose only certain regions. I have an 8Gb...
The internal memory of the nuvi is full. Some maps will need to be delete before any new maps can be added. Typically, the map in the nuvi is named GMAPPROM.IMG and a map installed to an SD (or SDHC) memory card is named GMAPSUPP.IMG.
1) Remove the SD card from the memory slot
2) Connect the nuvi to the computer via USB cable.
3) Open the nuvi drive.
4) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
5) Empty the Recycle Bin.
6) Retry the map update of the nuvi.
This method will take some time to perform depending on how many map segments you are sending to the nuvi. Transferring the entire map can take over an hour. A quicker way is to send the maps to the SDHC card directly by inserting the card into a card reader. This eleminates the slow Garmin card reader from the equation and transfers are done in a fraction of the time. No maps will be on the nuvi - they will all be on the memory card instead. To update the SD or SDHC card, do this:
1) Repeat steps 1 thru 5 above. This removes the maps files from the nuvi.
2) Disconnect the nuvi from the computer.
3) Connect a card reader to the computer.
4) Insert the SD or SDHC card into the reader.
5) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
6) Update the map to the SD or SDHC card.
When either method is employed, only one map file set will result. GMAPPROM.IMG or GMAPSUPP.IMG is the name of this file set. You should ensure / change the name to GMAPPROM.IMG. Any subsequent file set added should be named GMAPSUPP.IMG.
I hope this helps & good luck! Please rate my reply - thanks.
Jun 27, 2011 | Garmin nuvi 200W GPS Receiver
I have lost all UK & Europe mapping - except for major roads. This was initially built in to unit. Have SD card for Australia & New Zealand - this works fine.
The maps are stored in specific mapset files with *.img extension in the flash memory of the GPS unit. Each mapset file contains one or many maps in it. Beside that, the Garmin GPS navigator can also recognise and load up one additional mapset file from SD card residing in the "Garmin" folder and named as "gmapsupp.img".
Here are the mapset files supported by Garmin Nuvi 255w GPS navigator:
  • gmapbmap.img - the default base map
  • gmapprom.img - the primary mapset
  • gmapprom1.img - the secondary mapset
  • gmapoem.img - the OEM mapset that cannot be unselect by user (if it exist)
  • gmapsupp.img - the supplemental mapset which you can have one in the GPS flash memory and another one in the attached SD card.
Therefore, the Garmin Nuvi 255w GPS supports up to 6 mapset files, including 1 in SD card. Normally new maps installed by the user will be stored in gmapsupp.img.
You will lost all the maps in the previous mapset file if it is overwritten by a new file with same filename. If you want to keep the existing maps, ensure that you store the mapset file with an unused filename (from the 5 filenames above). Alternatively, you can make use of special tools to merge new maps into existing mapset file.
You can view the name of your base map in Tools > Settings > System > About > Basemap.
You can view the name of maps in the other mapset files in Tools > Settings > Map > Map Info. There, you can tell the GPS to load the map by checking on its name, or not to use the map by unchecking it.
In case there are 2 or more non-overlaping maps available for the same location, the map with the highest priority number (defined in the map itself) will be used by the GPS.
Note that certain map which are locked by vendor need a 25 bytes unlock key stored in a *.unl file in the same folder and with the same name as the mapset file where the locked map is stored in.
You might probably also interested to read:
Mar 13, 2011 | Garmin nuvi 255W GPS Receiver
1)1994 Yamaha YZ125 2 stroker 2)conditions (3400ft elivation, 20c temp outside) 3)engine modifications- Hi compression piston of stock bore 4)settings-swapped in a 320 main jet due to the elivation.. ...
Hi, Rx7_turbo_2 you may have a worn out top end that needs rebuilding for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $9 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
DOWNLOAD Yamaha YZ125 YZ 125 1994 94 Service Repair Workshop Manual...
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
YZ125 Top End Rebuild
Aug 12, 2010 | Yamaha YZ 125 Motorcycles
AXIM X3 Language
1. Download Axim X3 English (A01) setup, link from here --> http://www.slipstreamsolutions.co.uk...dates.htm#Dell
2. run the setup and make a backup ROM of youre x3, save someplace handy. I now have a file named A01-10240300GE.RIS
3. Run setup again, try to upgrade, get an error message - wrong language, etc but in that DELL folder, you now have a file named, in my case, P16R_A04080402EN.IMG
4. Open with a hex editor A01-10240300GE.RIS and copy all lines from 00 to 07
5. Open with a hex editor P16R_A04080402EN.IMG, select all lines from 00 to 07 and paste there the 7 lines from the first file, save with any name WITH .ris EXTENTION!
6. Run setup again, choose backup/restore and point to the modified .ris file. Now you have the same thing in that window, up and down side.
Do like a normal backup, DO NOT TOUCH THE PDA, THE PROCESS CAN TAKE UP TO 12 MINUTES!
The PDA restarts itself and, voila, you have axim x3 with a new language.
Jul 28, 2009 | Dell Axim X3 Pocket PC
Snugli Problem
none of ur pics work.. maybe upload some more and ill try to help!
Jun 25, 2009 | Evenflo Snugli Front & Back Baby Carrier
Recognizing hardware on a Mac OS X Tiger
Try just using the epson scan utility
1. Launch Epson Scan by going into your HARD DRIVE, APPLICATIONS, and EPSON SCAN.
2. If prompted, select your scanner from the list of models and click OK.
3. In the FILE SAVE SETTINGS window, you can designate the location, name and type of file the scans will be saved as.
-LOCATION defaults to HD/USERS/(YOUR USER NAME)/PICTURES. Click CHOOSE if you wish to change this.
-PREFIX determines how the scan will be named. Type any name you like. You can also designate a start number.
-FILE TYPE dictates what format the scans will be saved in. ie. .JPG, .TIFF, .PDF, or .PICT)
-For example: if the prefix is "img", the start number is "1", and the format is "JPG", the name of the file saved in
PICTURES will be "IMG001.JPG"
4. Click OK once settings are changed as desired.
5. The EPSON SCAN window will open and begin scanning in FULL AUTO MODE. In FULL AUTO MODE the software makes all the decisions for you (as to what is being scanned, where it is on the flatbed, etc). This is the easiest way to scan.
6. If you want full control over the scanning process click PAUSE and change FULL AUTO MODE to HOME MODE or PROFESSIONAL MODE. In the latter two modes you can change your scan settings as desired. Click SCAN after you have selected your settings. Click CLOSE once the EPSON SCAN is finished scanning.
7. When scanning is complete, your images will be saved in the location specified on FILE SAVE SETTINGS, with the prefix and in the format you set.
Aug 06, 2008 | Epson Perfection V100 Flatbed Scanner
Canon Rebel XT / EOS 350D Digital Camera Logo
550 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
