Question about Mitsubishi VS-60607 TV
Picture goes out after a few hours.
Mitsubishi VS 60607 picture goes out in a few hours and then comes back on much later. Sound is good but no picture and color is good.
    New Friend:
My tv is good condition but video not working
Posted on Jul 14, 2013
    New Friend:
  • 129 Answers
Coul'be overheat solder the cause of a loose connection , and or convergence ic 's almost ready to fail . the cost to repair will be around 250.00 to fix replacing the ic's depending of the tech. or 350.00 at repair shop if you may have more question , let me know Im here to help you. thanks
Posted on Jun 13, 2007
Mitsubishi vs-60607 60" screen is
when picture is getting smaller in size or goes away or moves towards one side then hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 22, 2011 | Mitsubishi VS-60607 TV
Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Oct 25, 2008 | Mitsubishi VS-60707 60" Rear Projection...
VS-45607
YOU HAVE THE DREEDED CAPACITORS GOING OUT...AFTER A FEW YEARS-THE CAPS LOOSE THERE PURPOSE AND DEPENDING ON WHAT CIRCUIT THERE IN --YOU WILL SEE THE ASSOCIATED PROBLEM,,,EXAMPLE--COULD BE SOUND ,PICTURE (YOURS) OR VERTICAL(PICTURE CLOSING UP) ETC... YOU CAN HAVE CHECKED BY A REPAIRMAN BUUUUT ,MAY NOT BE COST EFFECTIVE ,,TUNICA
Oct 24, 2008 | Mitsubishi VS-45607 45" Rear Projection...
I get sound but the sreen is black
Try a "hard restart" , which simply means unplugging the power cord of the TV, then replugging it after 4 hours have passed. This technique helps to reprogram the electronics of the TV.
Hope this suggestion works for you.
Jun 21, 2008 | Mitsubishi VS-60607 TV
No picture
Try a "hard restart"', which simply means unplugging the power cord of your TV, and replugging it after 4 hours have passed. This technique helps to reprogram the electronics of your TV.
Jun 05, 2008 | Mitsubishi VS-60607 TV
MITSUBISHI VS-4543
PVAT!!Look for bad connects--start w/easy first. Power supply,then vertical IC pins,then regulators.Take your time,be thorough.
Oct 01, 2007 | Mitsubishi VS-4543 45" TV
Mitsubishi 55" RPTV - Pictures goes out, sound stays on after on for some time
Sounds very typical of a component failing after heating up for a bit. Often in the Power Supply or Horizontal Output section, WE find the offending component(s) usually by using a can "Freeze Spray" and spraying suspected compnents when the problem stops thats ya faulty one... replace it/them and usually thats it. But if ya no good at doing it yourself.. then it's off to the shop... Generally because of ther size these beasts cost a bit to fix.. If ya have to take this route, ensure ya get a firm "Quote" AND an explanation of whats what. G L. Oh and offer to take it to the Shop, this will.should save ya some $$'s
Aug 08, 2007 | Mitsubishi VS-60607 TV
Mitsubishi VS 4543, Picture go out after a few minutes
I usually find that symptom you describe is caused by cracked solder joints on the power regulators or vertical output IC. I have also seen that symptom caused by loose solder joints on the vertical windings up inside one of the yokes. If you have experience in repairing TV's then you can disassemble the set and pull the main chassis, flip it over and resolder all of the parts mounted on heat sinks. If you do not have experience in repairing projection TV's then allow a qualified tech to handle it for you.
Aug 05, 2007 | Mitsubishi VS-60607 TV
Fluttering
I've worked on a few of these sets and have found C2P08 to cause something like rolling bars in the picture and have found C2P05 to cause lines jumping in the picture.
Feb 10, 2007 | Mitsubishi VS-60607 TV
Mitsubishi VS-60607 TV Logo
110 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
