Question about Coffee Makers & Espresso Machines
Instrutions for La Cimbali M32 Bistro
Have machine and I have no idea how to run or even use this piece of equipment as there is no operating manual with it. Please help!!
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, you may want to try the manufacturer themselves here. Or:
Good luck and Thank you for using FixYa.
Posted on Jan 14, 2009
  • 716 Answers
You Can Submit A Form Here And They Will Send You One. I Cant Find One Around Anywhere.
    President:
  • 1,990 Answers
Welcome to Fixya! Here are two Canadian espresso websites that contain machine manuals: For it
http://www.espressotec.com
http://www.coffeecrew.com
How do I get a operating manual for La Cimbali M49
http://www.manualsdrive.com/captching.php?lang=en&search=LA+CIMBALI+M29+SERVICE+USERS+GUIDE#.VOaFM5N_vbx
Aug 01, 2014 | Gaggia Expresso Machine
How do I set the coffee dose?
Too detailed for direct answer. Get operator's manual for dose instructions. Some machines may require programing key (service tech only)
Sorry for this answer as the dosing control is in-bedded with all dosing variances which is considerable. Though with practice it's possible to set it. Have you service tech walk you though the 'operator' or 'customer' programing steps.
Dec 30, 2013 | Espresso RMI La Cimbali Espresso Machine
La cimbali m31 bistro
It sounds like one or more of your gaskets has failed it depends where its leaking and steaming from.
I find a parts list is helpful in identifying where the problem might be the best I could find on the net for yours is a austrralian website that has on line parts diagrams apparently a lot of the parts are used in a number of their machines the link is
http://www.coffeeparts.com.au/cimbali/cimbali-spare-parts-1
May 31, 2012 | Coffee Makers & Espresso Machines
La cimbali m32 bistro overheats How do i fix this?
Hope it would help by follow the step on this link: http://www.hwl.dk/product-images/mespres32_man.pdf
Apr 14, 2012 | Coffee Makers & Espresso Machines
Hi i have a m32 bisto 2 group that is leaking from relief valve
Replace and or check the pressure stat, it will be on the right side of the machine with 2 small wires going to it, you will also have to replace the safety.
Feb 24, 2010 | Espresso RMI La Cimbali Espresso Machine
How do you change the dosage time on a Cimbali Bistro espresso machine
You can do it one of 2 ways, if the machine has a display then you can go through the program mode by removing the face cover on the display and pressing the programing button then navigating to the dose setting menu, then select a button and change the numbers there. Note the numbers are not ounces rather flowmeter cycles.
Second way is to hold down the stop button for 8-10 secs you will notice the lights flashing and you will hear a faint beeping every second, press the button to program then hit stop when you get thew correct volume, when done with all buttons hit the stop again.
Oct 06, 2009 | Espresso RMI La Cimbali Espresso Machine
La Cimbali Owners Manual Wanted
Operators manual only describes how to install and set up. The Technician's manual is translated from Italian and is purposely vague. (Cimbali wants you to go to tech school). Suggest you ask for a annual preventive maintenance from your local service Cimbali dealer. You may need an overhaul/de-scaling which will be very expensive (+$1,000) in labor and parts. (mostly labor as it takes us about 40-50 hours per machine.) Hopefully you just need to change the worn parts in both groups and a vacuum valve. Good luck!
Mar 13, 2009 | Espresso RMI La Cimbali Espresso Machine
Coffee Makers & Espresso Machines Logo
1,285 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
